Very nice build, (as always :) ).
I would add some extra isolation between the positive tab and the cell since the tab is usually sharp and this shrink wrap is very thin.
That is a good idea YuvalS. Thank you.
After a light sanding with 320 grit paper the wood surfaces had a water based clear finish applied. The finish I used is made by Varathane. It is an exterior finish, chosen because it has UV inhibitors. These exotic woods usually darken after a while when exposed to UV light. They also usually darken when exposed to air; oxygen is the culprit. A good clear coat with UV inhibitors drastically slows or stops the darkening. This wenge is different. It can get lighter when exposed to oxygen and UV. This finish is only available in a brush on. Most clear coats do not have the UV inhibitors.
For the final coats I prefer a spray finish as that eliminates any chance of brush marks. I prefer lacquer as it dries fast and does not require sanding between applications.
The clear coat does deepen the colors of the woods a little. Five thin spray coats were applied. Lacquer dries for a re-coat in 30 minutes or less; more like 15 to 20 minutes with the generally low humidity where I am. It is best to let it sit for a day before handling very much.
Time to begin the final assembly. First up is the heat-sink unit. I cut some narrow strips of double sided heat resistant tape.
The heat-sink unit was pressed in place. In the past I have somehow managed to mix up the connections for the bi-color indicator led’s. That is a real pain to unsolder and re-do. This time since I have room to add a perf board pin header P did so in order to use plugin connections. The next image shows a three pin strip ready to be soldered to the charger board. The white wire had a terminal on each end; one to fit one of these pins and the other to connect to a leg of the bi-color led.
Here are the three connector wires hooked up. The led is about to be glued in place. It tests as being wired correctly. The USB-C port was also glued to the back plate.
Next the padauk window frame was fitted with a small piece of the Warlon Washi Shoji paper. It is a remnant from a previous project. It is made in Japan for use in Shoji screens. The paper is laminated with a thin plastic sheet for durability. It is affixed to the shoji frames with a thin double sided tape that has excellent grip.
The tape is 5mm wide. There are a couple of varieties for thinner and thicker papers. The instructions are quite detailed.
Here I have started the installation of the shoji material. After sticking the main strips to the window frame I trimmed the width with an X-Acto knife. The center strips of adhesive tape were trimmed before installation. The paper has been started by stripping off the protective layer of the single end piece of tape. Then the paper was aligned and pressed in place. It has been rolled back to expose the other tape pieces which still have the protective covering in place. If this was a larger frame I would also apply tape to the horizontal center rail.
…With the shoji paper held back the covering was removed from the tape…
The paper was firmly pressed into the tape and this is what it looks like from the front side…
On to the PCB board. It fits inside the box with very little slop. I cut two thin strips of scrap maple to act as retainers for the pcb. I used more of the double sided heat-sink tape to adhere the maple to the sides of the box. If I need to remove the pcb for some reason the maple strips can be pried off using a thin blade. I did not use the shoji tape as it is very difficult to pull loose.
On a suggestion by BLF member YuvalS I added some tape to the ends of the cell to help protect against the tabs cutting through the cell wrapper. I used kapton tape. I soldered needed wires to the tabs on the 18650 Samsung 35E cell…
Here everything is wired up and ready for the back plate to be installed…
The window frame is to be secured to the body of this light with two small pieces of the heat-sink double-stick tape. Test have shown me that this tape will come loose before the shoji tape in case I need to remove the window frame. However, it grabs enough to prevent falling apart on its own.
Several images of the completed and assembled light will be posted soon
Here are five images of the completed light.
Front 3/4 view with 18650 cell for scale.
Lamp only
Lamp turned on with low brightness setting
Rear view
Rear view with USB cord plugged in. Red = charging.
And finally, here is a video clip…
(It appears at the end of this video that Youtube automatically advances to one of the video clips of the logging feller/buncher machine.)
It’s amazing that so much work goes into something with such simple and elegant lines. Well done Don, as usual. Another beautiful light!
She’s pretty. Once again nice work.
Beautiful light. Great job.
Don, what a beautiful project. That turned out great! Following along, I must confess that it wasn’t until you papered the window that I finally understood what form the lantern would be. It has such a classic heirloom look to it…the kind of thing like old desk and mantle clocks that could be found on top of furniture in every home. Wonderful job, really.
Thanks for all the kind comments. I truly appreciate them.
This is going to be gifted at Christmas.
I love this. Want to build something similar for my wife to keep near the bed.
MtnDon, I have to say this: you are an inspiration! Not only because of this build, but because of the others you’ve been doing throughout these years!
I love the concept, I really liked the heat sink driver mount, and it is a classy and good looking build
Well done
I want to take a moment to note that after operating on maximum output for an hour or so the body of this light does get warm to the touch. However, it never develops a hot spot and never gets more than warm to the touch. Not warm enough to get out the IR thermometer and take a reading. Same thing for the temperature at the heatsink while re-charging the cell. Warm, but that is all.
Thanks to everyone who had a look at what I did.
I appreciated the numerous fabrication related tips and tricks you shared with us in this build thread.
Aw shucks … thank you.
Beautiful craftsmanship Don!
Thank you. I hope you have a better New Year.
Fun to look at these photos of an excellent project again, and I hope whomever received this light for Christmas is enjoying it!
I wanted to say that I noticed that nifty Klein tubing cutter in the photos…on a whim I decided I needed it. Really nice tool - I have a few decent tubing cutters but this is quite excellent.
I just cut some micro bushings with it using 10mm x 0.2mm stainless tubing. 1mm wide and 1.5mm wide. Slid a transfer punch inside for support and I’ll be darned but this cutter actually tracked so accurately and handled that ultra narrow cut just perfectly. A minimum amount of strokes on a stone to make them neat. They’ll be used for some 3" saw blades I got, advertised as a 3/8" arbor but in reality a 10mm…these tiny bushings fit perfectly and make the blade useable now at high rpm’s. The most difficult part was accurately scribing a mark so close to the end of the tubing.
So…thanks for the excellent photos and always including your tools and such in the process.
Our son received it at Christmas. Yes, that is a great tube cutter. Klein has made excellent tools for many decades and still produce a large number in the USA. They have assorted lines with a big share in the electrical field. I have a variety.
Not only did I enjoy the craftsmanship but the artful merging of exotics was extremely satisfying!
Well done!
