Test / Review: AmpMax 18650 3100mAh (Black)
Official specifications:
  • Original Panasonic cell from Japan
  • Built-in protection circuit, guards against - Over-charge, Over-discharge and Over-current
  • Triple MOS's for superior high current discharge
  • Improved voltage stability due to low internal resistance
  • PET sheath, environmentally friendly and not easy to crack
  • Steel flat button design
  • Voltage: 3.7V (4.2V when fully charged)
  • Capacity: 3100mAh (discharged at 0.2C)
  • Dimensions:18 mm x 68.5 mm (+/-0.3 mm)
  • Current over-flow protection: 5A+
  • Weight: 48g
The cell used can be discharged down to 2.5 volt, in my test I only discharges to 2.8 volt, i.e. I do not measure the full capacity. But then, not all lights will be able to use the full capacity.
Conclusion
This battery uses a good cell, this secures many things:
  • The batteries does match in capacity, i.e. they can be used in series.
  • The battery is very safe.
  • The battery has the specified capacity.
There is not anything to say about this battery except it is a very good battery.
Notes and links
The batteries was supplied by AmpMax for review.
Thx HKJ!
Thanks very much! Frontpage’d and Sticky’d.
Thanks a lot, again…
BTW, where can we buy it? How much?
Thanks again…
You can find the AmpMax website here: www.ampmaxworld.com, but they do not have any shop on it.
Thanks sir, I just send a mail…
Found these on Ebay.
Expensive: $39.90 for 2
