AceBeam H40
Maybe no Budget Light but not to expensiv (O.K. I see with SST20 High Cri out of stock and more expensive)
AceBeam H40
I need a headlamp which will be used:
So getting a Li-ion headlamp implies getting multiple batteries in a form factor which I do not already have, and maintaining them. I see no advantage in doing that, compared to using what I already have.
Yes, weight matters when I need to use the headlamp for a whole hour in my head. CRI also matters when I need to distinguish the color of two cables, or solder, or some other technical work. CRI also matters if I am camping, specially if I am cooking. I know my needs and what matters to me, so please do not be so condescending and assume I know no better.
Emergency situation for me, not end of the world scenario. I do not want to carry a solar panel + charger while camping, when I can simply carry 8xAA batteries.
According to Manker they are indeed in production as of a month ago, I asked them. Apparently they were going to be available soon, but we will see.
Thanks to everyone, it looks like there is no great option at the moment.
Simon or Manker seem like the best candidates for something viable in the future.
Really? Zebralight is not an option?
74€ shipped. Not a budget friendly option.
I have no idea why you’ve been forced to justify your choices, i find it quite hostile and unsupportive.
Unfortunately i don’t know of anything that fits your criteria, sorry. Hopefully something will become available soon.
There is an option to get a headband like this:
https://www.nitecore.co.uk/products/nitecore-hb02-head-band.html
and use an AA light of your choice, but i’m not sure how well the angles would work as the light would be in the side of your head without any vertical angle adjustment, and you may need to pad the light out for the larger diameter of the loops.
I have one somewhere, if i can find it i’ll see what it’s like in use.
Thanks, I also considered this.
For now, I am using a different “creative” solution: my AA headlights attached with their clip to a cap, which works ok and is kinda comfortable.
If the Manker E03H II comes back, and especially if there is a deal offered, I will most likely get at least one. The E02 II is my most used light because no other light I have tried is better at what I want from a flashlight most of the time. Not 100% certain but would like to test if the AA is still as versatile and unobtrusive as the AAA. I can clip or magnet the E02 II virtually anywhere and the weight is almost undetectable. My TH20 is into 18650 territory for weight, the Fenix clip I have for it is lacking, and of course the stock emitter / reflector are not even close to the excellent TIR and SST 20 high CRI.
No 18650 / 27100 light is ever going to be able to do what the EO2 II can do. The EO3 II just might. If it isn’t too large / heavy the extra battery capacity would be quite nice. As it is now most of the time I just swap batteries before I go out at night so usually it is not a problem.
The TS21 has the same LED (x3) great beam pattern and phenomenal battery life. Too heavy to be usefully clipped to a hat. Too bulky and wrong configuration for using the magnet as effectively in a server closet. It does fit well in a jeans pocket and is nearly always with me because sometimes I actually want / need more light than a AAA is capable of. Small percentage of what I use a flashlight for but also really fun to be able to put out more serious lumen.
Have you tried looking at brands aimed at hiking/ camping like Princeton Tec and Black Diamond? They’ll definitely fit the AAA/ AA criteria, but most likely not CRI or possibly the budget.
I’ve got an older 4 x AAA Black Diamond head lamp and recently picked up an 18650 Sofirn D25L , the Sofirn puts out a much wider, brighter beam and is far more comfortable to wear.
It has certainly fallen out of fashion, but there are a hundred ways you can attach any AA to the side of your head. The key is to give it at least a few degrees of downward aim somehow.
I don’t understand why everyone hating either… I’m also looking for similar. For me 14500 and AA compatibility and thermal Stepdown (which the Manker doesn’t have) would be brilliant
It’s statements like this that make people question your knowledge of lithium-ion and and your refusal to get on board.
And I don’t really believe that anybody here thinks that taking eight AA batteries on a week-long camping trip to feed your main light is a reasonable choice. That is indefensible.
The response is predictable. Most internet-forum-based experience is not going to be from “outdoors people”.
AA/AAA is the default at campsites, and there are perfectly valid reasons to stick with nimh.
Headlamps are also the default for a lot of valid use cases.
Ergo, the person’s question is one of the most reasonable questions we’ll ever see on here. We are the weird ones.
Acebeam H40 and Thrunite TH20 are the first to come to mind. Both are very good headlamps in my experience. Easy easy to swap emitters in the TH20 (probably the H40 as well).
You could wear a cap and use a Sofirn SP10 Pro ? (Or any other of the small AA flash lights with dual clips.)
The light output of the SP10 is impressive even with AA nimh batteries. 14500 is brighter again.
SP10 Pro is absolutely excellent with NiMh, I love that light.
I am going to wait for Manker or Convoy to have something available, hopefully having a bit of patience will pay off.
I have been on the internet long enough to not be surprised at all with the response. I understand that people are passionate about Li-ion in an enthusiast forum, and I own 14500 and 21700 lights myself, but already did my research and need no help choosing the chemistry.
Anyway the thread has been useful to have a more complete compilation of options than what I initially had.
Agreed, except I guess I’m kind of a tint snob. Love the SP10 as well but prefer a warmer tint.
Really hope this format is not neglected and that another production run is forthcoming.
Chemistry has little to do with it from my perspective. Most every light that uses dual chem in this format limit their use for me to NiMh. Moonlight is far more important to me than the extra output from LiIon. A well driven AA is pleanty bright for what I would need most of the time. The few times I need more than that, most likely I would already be using something 18650 or 21700. Without a good moonlight it simply is not acceptable for me.
The reduced mass and ready availability of standardized cells with zero possibility of thermal runaway are things that this format can do that LiIon simply cannot. I think those attributes make this format very worthy of continuing and hope to see more lights in the future.
The SP10 Pro (Anduril 2) moonlight mode with the 14500 works fine - the LED is barely detectable as being “on” in a lit room. That’s when looking directly at the LED.
… Moonlight is far more important to me than the extra output from LiIon. A well driven AA is pleanty bright for what I would need most of the time. The few times I need more than that, most likely I would already be using something 18650 or 21700. Without a good moonlight it simply is not acceptable for me…
Absolutely agree that lows are more important than highs. I’ve been putting up with the nimh low of the convoy t3, though, and am finding I can tolerate a lowest mode that is right at the low functional edge of dark-adjusted-vision trail-walkable. In fact, it’s sort of nice to just always switch on to a “perfect low”. I’d rather have this perfect lowest mode than have it spanned by moonlight and too-bright, but I guess if you’re an Anduril fan, that is not a concern.
Used the TH20 clipped to my parka for walking the pooches last night. Remembered one thing that it does that many lights would not be able to do. It went through a complete wash and dry cycle! Actually I think it has went through a couple of wash cycles. The thing is very well made. Not very likely that any of the USB charging with flaps would survive that.
I still think it is a very nice beam pattern and quality — provided it isn’t side by side with an sst20 4k. Moonlight is too bright with the 14500 but the light is fine with AA. When people say it is easy to mod I assume that is LED swap. What I really would mod would be to give it a clip. I use mine with an old Fenix clip. That really makes the light more useful. What I would really like is a clip as good as the one on the EO2 II.
