Can’t wait to get mine. My boy Neal said that there are LED shortages or something and offered to let me order another light. I’m in no particular hurry but this puppy will be a fun toy! I like being able to carry an extra pair of batteries instead of sitting there waiting for some stupid proprietary USB charger to take hours to charge the internal battery cough Imalent cough
Vapcell have some P45B but they’re a bit expensive at this point in time. They might be cheaper when they’re more widely available.
I currently don’t have 30T or P45B handy to test. I have Samsung 40T, Vapcell T50, Lishen LR2170HP, various Sofirn/Wurkkos 21700 cells, and some Weltool and Cyansky 21700 cells with built-in USB-C chargers.
SFQ60.3 6000K seems to be out of stock. Nightwatch are making NS59V2 with XHP50.3 HD 6500K. It looks floodier and might hit 38k lumens instead of 31k lumens. I wonder if they’ll continue to make it with SFQ60.3… XHP50.3 looks nice on paper too.
Could you pls explain why you wrote the above? Are you referring to the 2 batteries in the tested light having different voltages? What kind of problem? Thanks.
Thanks for the feedback. The review format that I use is heavily influenced by 1lumen, tacgriz and zeroair. I.e. “User interface and driver” is one section that I try to cover but I rarely delve into details about the driver.
Cells are running in series so the flashlight is only seeing one voltage reading. If one cell isn’t matched in capacity it’s going to discharge lower than the other cell, this is a rather large issue if it discharges past 2.5v
Thanks Tim for the good review. I looked up the Acebeam X75 or Imalent MS18 since you mentioned they are “flooders with longer runtimes if money is not a concern.” After I see the cost of those 2 lights I would say money is always a concern . The Chaos is extremely attractive at $128, but how do I know that it would ship with SFQ60.3 leds?
Sources please. I’m also thinking the XHP50.3 is a good alternative. But all my searches about Nightwatch keeps coming back the Neal. Is it his own brand?
@cannga, when you have cells in series, any deviation in capacity will result in reduced usable capacity and cycle life, which gets worse as they get cycled.
While using an infrared thermometer, I did not notice the tailcap get hotter than the rest of the body. The head was hottest, and it became cooler as I measured closer to the end of the tailcap.
Yeah. The lack of thermal paste is a concern. I am lucky that some LEDs did not burn themselves.
It’s worth replacing the thermal paste and spreading it around properly. The driver wires are a bit difficult to desolder and solder. I cut the wires with flush cutters at the joint, cleaned off solder from the board, added some flux and added some more solder. The solder joints need to be neat and tidy or they might touch the metal reflector and create a short.
It would have been nice to see four screws used instead of one for the MCPCB too. There are four threaded holes but I only found one screw.
This is definitely a budget torch for enthusiasts. Scary fun!
Now you’ve done it; I like to be scared by a flashlight! Kidding aside this has been a fun thread to read not least because of your (and others’) experience & knowledge. I like the teardown’s discussion even though I have no experience re. DIY stuffs. But… I would like to ask an important question since we are after all in the land of “budget lights” (a really unusual name that gave my wife a chuckle the first time she saw it, as in “you, hobby, budget?!”).
What I like about the Wurkkos TS30S is, for me anyway, there is nothing like it at 60 bucks (SBT-90, 1000m throw, ~4000 lm, USB-C).
I know you chose the Chaos out of many lights to review, so it’s special. But could you (or anyone reading this) say the same about the Chaos? Is there anything like it at $120? Any flooder with this much lumen at this price? If you say no, that IMHO would narrow the focus and mean a lot to potential buyers.
I haven’t found anything else around US$100 that can hit 31k lumens.
I pushed a Sofirn Q8 Plus hard with 3x Lishen LR2170HP cells and broke it after reaching 28k lumens on Turbo. 28,987 lm at turn on. 10,544 lm at 30 seconds.
1lumen published a relevant article recently for brightest flashlights:
Nightwatch Chaos NS59v2 is about US$96 after discount so it might fit into the “Brightest flashlights below $100” category. It reaches about 31k lumens which almost enters the category of “The brightest flashlights in the world you can buy today”.
A few budget flooders come to mind:
Nightwatch NS73v2
Nightwatch NSX4
Sofirn SP36 Pro
Sofirn Q8 Pro
Sofirn Q8 Plus
Those Sofirn soda can flashlights have built-in charging and an Anduril user interface. Charging, battery type, user interface etc may be other considerations. I just wanted a cheap flooder for the thrill.
parametrek has a database of flashlights and you can search by lumens. It may not have everything (flashlights that don’t have a product page online might be omitted, e.g. Nightwatch). The price starts to go into hundreds of dollars when looking at 30k+ lumens.
For those willing to mod these: I swapped XHP50.3 Hi’s in mine. 5000K/4000K 90cri tint mix. It has negative DUV and is incredible bright and fun. I recommend.
