TS10 (red, silver, MAO)
Like: high CRI + nice tint, compact size, decent output
Dislike: Bare aluminum threads + vertical groves in female threads = not so smooth action, need to apply pressure to the tube to start threading (not as easy to assemble as my other Wurkkos)
TS25 (pre-production)
Like: high CRI + nice tint, powerful, nice smooth threads, USB-C input and output.
Dislike: mine came with defective button, unnecessarily bright aux leds, not so easy to mechanically lock out by turning the head (not much to grip on), protruding button (accidental activation problem), a little worried whether it has safety features for USB-C charging and output (Can the charging current be too high? Is the output stable so that it does not damage connected devices?)
TS30S
Like: powerful SBT90.2, focused hot spot, nice smooth threads, low power consumption with aux button led on low (0.08mA)
Dislike: No flashing pads. May be heat on turbo? But I rarely use turbo. Even if I do, I use it only briefly so heat is not a major issue.
HD15 - with short tube and magnetic tailcap is my absolute favorite grab-a-light light.
A while ago I had to replace parts of my exhaust air ventilation system in the attic.
A very dark place. No problem: just stick it on any pipe and choose a flood or throw led.
In the past two months, I acquired 4 TS10s and 1 WK03. TS10 really hit the sweet spot for me. And the WK03 is one nice budget, quality, no non-sense compact flashlight! Good job Wurkkos!
I have a couple of suggestions for you guys.
get a TS10 Titanium version out please!
get a TS10 variant with everything the same except a single emitter with throwy optics!
Provide SFT40 or other better options instead of SST40 in your models!
I am sure I will buy more lights from you in the future.
