I am using hard case dedicated for bluetooth speaker Sony SRS-XB10 which has the same dimensions. There is no free space for battery and cable, but I do not mind it since I use extra organizer for these.
Maybe a neoprene beer can sleeve?
I think the ID would be too small for the LT1S, but I don’t find the dimensions in any listings. The ones I have had in the past (I don’t seem to be able to find any now) would have been too tight.
Get to a local music store and have a small flight case made, like the ones used for microphones.
Other than that, a case from www.peli.com for expedition or the like.
But anyway, a case for LT1s, really?
The custom case would be intersting, but likely more expensive and too bulky for my needs…
I have cases for most of the gear that I consider to be important. Cameras, telescopes, guns, many knives… even my toothbrush.
Mine will be stored in a drawer with a bunch of other lights about 80% of the time. No reason to get it beat up unnecessarily.
When going to and from camping trips, it will be in the trunk with lots of other gear… again, a case will keep it from getting potentially damaged. I want it to work when I need it.
Spare batteries in the same place at the same time, without having to remember to grab anything else is a bonus.
You know, different strokes. If one never moves it from a safe shelf unless there is a power outage… probably no need for a case.
So, yeah, really !!
For scratch-protecting things in a backpack, I use socks or other pieces of clothing, towels, bags, things that are there anyway.
A flashlight or a lantern is a tool that must get patina with action.
Hehe, when i look at my Petromax, with all its dents and kinks, a Petromaniac would instantly become pale-haired.
Every one of these blemishes could tell stories of the expeditions it has been used at. Now it sits retired as a decoration, cleaned and polished in the studio. Damn LEDs… I miss the smell. And yeah, it has a box it came with, with layers of stickers on it now, but it could not prevent things from happening.
No point in losing time with cosmetics.
No body ask me if we can find one pouch for LT1S?
Do you need a soft pouch to protect it from scratching or hard case?
This is a great idea. I made the video above but I like this idea a lot better.
These just came in: Tycka Lens Pouches
The medium case has a LT1s sitting on top of 2 battery boxes. The diameter is a little big so I cut 2 strips of neoprene foam rubber. The small case is a perfect fit for a LT1s. I used the large case for my lantern and flashlight accessories. I'll find a use for the extra large case sooner or later.
Glad they are working for you!
Though the link to your picture seems to be broken for me.
Hmmmm, I don't know what happened. Was working, now it's not. I reinserted the picture and added a link to the photo in case the picture stops working again. Is that working for you?
Yes that worked. Looks good!
I found this case for the Sony SRS XB-13 bluetooth speaker that fits perfectly well with the LT1S. It has a space below too that fits the included cable very well
I took a gamble on a Sony SRS-XB10 case from AliExpress.
While it isn’t perfect (no separate compartment for the cable), the fit was good and it was really cheap!
Here’s one listing, but there are plenty of them for around $5 on AE: https://www.aliexpress.com/item/33007801087.html
Link?
I like this better but in case it doesn’t come thru. Page Not Found - Aliexpress.com
I’ll give that one a try or this one. 4.68€ 60% OFF|Ltgem Hardcase kompatibel mit Sony XB10 / Anker Sound core Mini & Mini 2 tragbare drahtlose Lautsprecher Aufbewahrung tasche (nur eine Tasche!)|Lautsprecher Zubehör| - AliExpress
They used to have the small one only for sale. Sold out before I could purchase.
If this fits, seems to be the best option to add to your website
If anyone cares, mine came in and I can fit a flat usb c to usb c cable, dual usb c & lightning charger, flat lightning cable, a usb c lightning cable
All I need now is a huge power bank or solar panel to power/charge everything in an emergency.
I guess that is good, but how well does it fit and protect the LT1s ?
If anything, judging by all of the extra stuff you can fit into it, the case might be bigger than what I am looking for.
Being able to hold the cables and chargers is not that important to me. I have other places to stash those.
But, having a case that takes up as little room as possible is important… for what I want anyway…
I messaged Barry a while ago when looking for a case. He found something similar to what I asked him to try. Looks like he found the one with a a grey lining, I prefer black but it will work the same.
Protects it as well as the cases people use for LT1. The Tycka lens pouch or this would be the most compact. Amazon sells this for a little bit more. 4.68€ 60% OFF|Ltgem Hardcase kompatibel mit Sony XB10 / Anker Sound core Mini & Mini 2 tragbare drahtlose Lautsprecher Aufbewahrung tasche (nur eine Tasche!)|Lautsprecher Zubehör| - AliExpress
I have a lens case that works OK. A bit of a tight fit, but OK. Was looking for something better. But you are right, the lens case is about as compact as I can get. Just not the ideal form factor. A tube shape is inefficient in the use of packing space. Also, it has more padding than is really required.
For $6, I will probably try the one from Sofirn. Fortunately, I am not in a big hurry.
