I swapped out my other D40A that had the 5000K XM-L2 with a 5000K 519A. Same result as before - Amazing!
So you don’t have to scroll back and forth, the top photo is the 4000K 519A (left) with the old 5000K XM-L2 (right) vs bottom is the 4000K 519A (left) with the new 5000K 519A (right):
I was planning on dedoming a 5700K 519A too to replace a 219C in a cheapo AA flashlight that I modded 5 years ago. Any insight on how the beam profile will differ between dome vs dedome? The OP reflector is 18x12mm:
the domed 519a has a nice large hotspot, similar to LH351d
(pic does not do justice, this is an xml reflector that has a large bottom hole, which does not produce a clean transition. Your reflector will probably produce a better beam profile)
dedoming will make the hotspot smaller, similar to 219c
(this reflector has a smaller bottom hole, and the pic is more representative)
Kinda figured the hotspot would be smaller and thus more throw, but was concerned about rings and artifacts. But it looks like I should be fine and the improved tint and more desirable CRI (to me) is worth the risk.
Maybe I’ll do a before and after beam profile and post it here.
I haven’t actually modded anything, but I have assembled 4 - LH351D 4000K LEDs on an mcpcb, a led4power LD-A4 driver, a Li-po 3700mAh cell, a switch, a 2 amp TP4056 charger and USB-C port plus a Convoy S2 pill and some copper pieces, into a test configuration for a light I am thinking about making.
I made this the other day. 12V 2A wall wart power with dimmer and 4 12V LEDs to light up a MCM Spaghetti globe.
Final sanding and finish put on it today. Xmas gift… the lighted stand.
Cool! I haven’t seen a spaghetti globe in a while. It’ll be nice with the dimmer.
It might take a while to complete my project, there are other things higher up the priority list. Plus now I need to complete the ways of carrying out the idea I have and turn it into something other than some parts that I have shown actually do work.
Not a flashlight mod but a mod none the less.
I took an old feit 9w led bulb and replaced the original some 2835 leds with some 5000k and 4000k Bridgelux Thrive 2835s. I alternated between 5000k and 4000k trying to get 4500k.
I didn’t take any before measurements with the Opple since I just received it and I had already had taken the bulb apart and was too eager to start reflowing some leds.
Overall I’m pretty happy with the CCT and obviously the CRI is great. I was hoping the tint would’ve been closer to the BBL, but it only cost about $2.50 and less than an hour of my time. So, in the end it was definitely worth it.
I spent many many hours filing, sanding, and polishing a cheapo AA flashlight in order to reuse a 5700K 519A LED that came with a Convoy S2+. I purchased the MAO S2+ with the intension of converting it into a triple dedomed 5000K 519A and it turned out great.
I made a makeshift lathe using a portable drill, a large drill bit, and plenty of tape. I think the host turned out pretty darn good. I added another hole for the lanyard so it will be able to tail stand.
The worse part of trying to use the cheapo AA flashlight as a host is the pressed in driver retaining ring. It’s not reusable and was very difficult to remove. So I took an S2+ retaining ring and added solder to the perimeter. Then screwed it back and forth onto the head along with some oil to cut new threads. Now I’ll be able to use it to secure the new copper (cap) pill and the driver that came with the S2+.
I just ordered the lens, reflector, silicone switch cover, etc. from Kaidomain so will have to patiently wait until the parts arrive.
T3 519A 5000K (dedome + 60 TIR) getting 3600-3750K (had to file down the TIR to fit the T3)
It's little to long like 0.1mm or so, to screw it down all the way, but there's an o-ring, so there shouldn't be a problem with water
WB 5000K, 1/60s, ISO50, f1.8
And teaser (I will try to finish it soon, for now it's a test fit, and it fit perfect)
innovative rotary design, you can change the brightness, and tint, by screwing in different bulb
100% center 3622K Duv -0.0032 97Ra
100% side 3707K Duv -0.0039 96.5Ra
20% center 3726K Duv -0.0040 97.3Ra
20% side 3833K Duv -0.0054 97.4Ra
20% near opple, center 3606K Duv -0.0031 97.3Ra
20% near opple, side 3676K Duv -0.0037 Ra 97.1
did you lock the white balance? at what value?
I don't remember if the picture was on, 100% or 20%. It could be 20%. so it's Duv -0.0040 center to Duv -0.0054 sides, and my wall is white...
that is why I take the photo during daylight when the CCT is about 5300K and the Tint DUV is about 0.0032
I dont know if your photo would look like mine, if you took it at the same time of day… that is why I think it is helpful to compare Opple numbers… they bypass photo WB differences.
anyway… just pointing out how much photos can vary… I do think it is great that you can lock WB… your pic looks great…
