The There Are No Stupid Questions Thread
I recently ordered a heat gun. Should I get a hot plate in addition? What do you do with a hot plate?
I bought a temperature & air flow controlled heat gun during the recent sale. It is called “T12 Heat Guns OLED Digital Display Temperature Soldering Station”. I thought having a heat gun can be useful. I can think of several interesting uses for my heat gun. Heating flashlights to loosen glued threads, heat glues and stickers for easy removal, and possibly remove and reflow LEDs.
However, I heard that reflowing LEDs on MCPCB using heat guns may not be easy because MCPCB can soak up a lot of heat and LEDs can be damaged by heat. Temperature controlled hot plate seems to be an adequate tool for working on LEDs. However, I don’t think I will replace LEDs often. Many of lights I own have RGB aux leds and they are not mod friendly because of the small wires and tight spaces.
If I am not going to reflow many LEDs, what are other uses for a hot plate? Only other uses that I might have is heating cold coffee on the hot plate. The model of hot plate I have in mind is MECHANIC ET-10 hot plate. Price is not bad at 30 USD.
Good question! Wondered about that myself but never thought to ask.
Yes, the mcpcb will soak up heat, as it should. Once it’s saturated then the heat output of the gun will start to be more controllable. It’s as easy as other methods as long as you have a good way to hold the board so that both hands are free (gun and tweezers/flux). It depends on the emitter, but generally yes, you want to use as low a temperature as possible to let things flow and get the job done without undue delay. Most of our white emitters are pretty tough but sometimes the domes will become soft or damaged with extended heat, so be careful not to bump them hard with tools. UV emitters are much more sensitive to heat. Most manufacturers state that their emitters should only be reflowed twice but we frequently do that another time or two and things seem well. The heat guns that are able to provide adjustable heat and adjustable flow are the best…often low air flow but still having moderate to high heat is a great combination (so you don’t blow tiny components off the board…). There’s no need to get overly precise about it but the graphic below that I borrowed from the internet is kind of a typical reflow heat profile (geared more toward hot oven work than hot plates or heat guns, but same difference for the most part). You can see that there is both a peak maximum temperature that should be avoided really, but a companion time frame at which the emitter should be able to tolerate that heat without damage…and the profile ramps up slowly (heat saturation and to avoid thermal shock) before leveling out when the solder melting temperature is reached and you can do the job…then remove the heat as soon as possible and let it cool. Usually the temperatures are just about the same for all emitters but you can always check the data sheets for an emitters specs/numbers. And again, for a heat gun and hobby work, this reflow profile is just a good guideline that we can try to emulate without precise controls. Heck, people successfully use cigarette lighters and propane torches to do this job…ok when done smartly. :slight_smile:
Tiny tiny components are challenging by hand. The heat gun and different nozzles are what pros use for handwork with this stuff…just some flux and tweezers (and magnification if you need it) and a whole world opens up compared to trying to use an iron. But with the right techniques and iron tips (and flux flux flux) there’s still a lot that can be done without a heat gun if you have the skills. Heat guns are also fantastic for bending many plastics, gently preheating a surface for paint or glue, and drying small parts with nooks and crannies after a bath.
The hot plate could be used for other electronics work, especially with single-sided boards. Some adhesive mixing or curing, some catalyst coatings like a little heat for mixing (really niche stuff). If you were doing some solder or bending work on larger-but-small metal things then putting the item on the plate for heat saturation makes some jobs easier or for prolonged work that might be a pain in the butt with a torch or iron. And of course making your own chemistry lab experiments…ha. I’ve come to prefer a little hotplate for doing my emitters. I got the tiny Miniware version and love it…but man it’s tiny. That Mechanic’s version looks great and it’s very affordable (and probably better than many of the larger cheap versions out there for labs and such).
Thank you very much for the quality info. Looks like I would not have much use for a hot plate. I came by some youtube videos on the Miniware hotplate. I liked the idea, but they were pricy for my budget for hot plate. By the way, I recently received Miniware TS101 soldering iron. I really like compactness of their tools. It is very small so it can be easily put away inside a drawer.
I have a magic arm and a clamp (photo equipment), so holding the heat gun should not be an hard. However, I remember reading a post that heat guns should be applied from the bottom not from the top. That seems to be quite awkward to work on.
Would it be okay to put the MCPCB on silicone soldering mat and blow hot air from above? I think it would be okay if the air temperature is controlled…
What is a DC Fix ? Also, what does DC stand for?
Bottom or top…you can kind of decided based on the piece really. With a metal mcpcb it just makes more sense to heat from the bottom and keep a little heat away from the emitter dome/phosphor that way. If you’re using it for populated driver boards then pick the lesser of two evils just in case you melt the solder on parts that you’re not aiming for. The board for a tail spring…maybe best to use a soldering iron there but using a heat gun from the top will help keep the spring metal hot (and for switches, definitely recommend an iron there…the plastic in switches is super easy to melt accidentally, even from just an iron if you aren’t careful).
On the silicone mat…they’re great for a lot of tasks but keep in mind that they are not dissipative AT ALL like a normal grounding electronics mat. Emitters and other components can be zapped by ESD and most silicone mats can really build up a charge, but despite the data sheets the emitters and chips we use seem to be pretty robust. I don’t worry about static anymore when I use my silicone mats but if it’s particularly staticky I’ll sometimes wait for more humid weather and/or actually do a grounding strap. Lots of people just hold the mcpcb with a clip or hemostats that are held in a vise or on the table edge with some weight, then apply the heat to the bottom of the board…all in the air and no mat…that works fine although a pan/skillet/hot plate is preferred. The first several I did were just on an electric range in an old shallow sautee pan and I’d use a small piece of 1/4” aluminum plate to try and buffer the temp/speed of heating a little. Most important is to just be as gentle and quick as you can with getting the solder melted. Practice a bit with some of the solder paste you’re using just to see what heat level and how much time it takes, then you can adjust a little with heat output, fan speed, nozzle size, or distance if you feel like you need to fine tune. You don’t need to totally duplicate those ramp profiles but if you have to err then faster heating and quick work before removing heat completely is much better than allowing the heat to soak for a longer time.
It’s a trademark/brand for various kinds of plastic film. They have a LOT of them in all kinds of colors, patterns, textures. I think there are just three or four of the clear ones that flashlight folks have been using. Sometimes they help to soften a beam profile to reduce rings or color aberrations, homogenize and widen the spot a little. Reduces output a tad as you’d expect…not sure if anyone has ever tested but I’d imagine that it’s a little more than what textured plastic optics do. Boaz here and Vinh at Skylumen both make small pieces available to us for cheap, which is nice. You can buy a small roll for not too much money but it’s more than you’d use in a lifetime of flashlights, probably.
On the D-C…I’m stumped. I just looked all around and I can’t find any reference to that. It’s a German company and it looks like they’re connected with or under the giant Continental conglomerate umbrella. None of their sites I looked at gave a clue that I could find.
What is the maximum temperature setting for Anduril one?
70C? 80C?
Thx
Thanks for the reply. I kind of figured it was some kind of diffusing product from reading the posts. The lack of info on “DC Fix” on Google makes sense now that it is some kind of brand name from a certain company.
Thank you for the detailed explanation! It helped a lot.
My heat gun was delivered a couple days ago and I was able to remove a led with ease with the heat gun. I just put the MCPCB on my silicone mat and applied 250C heat with 80% air flow and one led (four leds are installed on my MCPCB) was easily removable. However, my cheap and skinny silicone mat began deforming (balloon up) upon heating. Luckily my desk underneath the mat was not damaged and the mat went back to its original shape when I removed the heat.
My solder paste has not arrived yet, but trying to solder back the removed led using original solder and additional flux did not seem to work as well. I think removing component requires significantly lower temp than installing. So, I think I need to apply more heat. However, since hotter air can potentially damage dome or other weak part of led I think it makes much more sense to apply heat from the bottom and closely monitor the solder.
Today, a cheap hot plate ($4) I purchased was delivered. Reflowing was much quicker and easier. The cheap hot plate was able to reach over 200C (it stabilizes around 250C) in less than a minute. Using it, I was able to reinstall the previously removed led using existing solder with additional flux paste. I understood right away why using a hot plate is much easier. By the way, I had to unplug the hot plate pretty quickly because when the plate reached over 200C the reflowing was already done. I was able to check the boing (in the famous video by Matt https://www.youtube.com/watch?v=B3F68ubfBkk ) and was able to push out extra solder after the plate was unplugged. It was $4 well spent! I have also ordered a small copper block that can be attached to a soldering iron, so I think I can use that to slow down the heating. Thank you for the tip!
I wonder if Boaz might know the answer. It’s been a long time but if memory serves I think he tested all kinds of them and decided that DC was the better product for various reason, including the adhesion qualities. I have half a mind to email the company now and see if they can reveal the name origin. :slight_smile: First guess is that the D stands for decorative or similar.
You’re welcome! That’s interesting about your mat ballooning. I have one of the usual cheap phone/electronics types and then I got a large slightly thinner plain mat that was advertised for kitchen use. Messing around I started playing with heat settings on a medium hoof iron tip and both of those silicone mats were remarkably resistant to heat. I think it was around 400C with a few seconds of dwell time that one might finally showed a burn mark that wouldn’t wipe away. Small surface area from the tip, but there was no deformation or anything. I’d imagine that these are all the same type of silicone formulation (heck, probably all made in just one or two factories, too).
It’s possible that your emitters used lead-free solder…that takes more heat and usually takes significantly more heat on subsequent melting. Flux does help but lead-free can be a bear to work with. The usual 63/37 leaded solder is great stuff, and it’s eutectic so it solidifies instantly when heat is removed (that’s nice when you’re working with fiddly connections or in a cramped flashlight head)…has a bit lower melting temp, too, 183C or so (and generally find that I need around 220C or a touch more to desolder that, depending)…wire or paste, either way.
Congrats on the success! It’s a good feeling isn’t it!
I got my soldering silicone mat for $1.66 on recent sale. It was among three items that I could order for $5. It is heat resistant for a short period of time just as you described. However, when it was exposed to heat for a longer period of time, it started to deform. I experienced this using my heat gun and my cheap hot plate. In the case of heat gun, I applied heat directly. And for the hot plate, the heating element was very closely located above my mat (because my hot plate has very short legs to keep it off the ground)
I agree that the factory solder could be lead free. However, all of my recently purchased soldering materials are all 63/37. I hear they are easier to work with and more robust and resilient (less crack) compared to lead-free solder.
Thanks! Seeing the led find its place on its own (the boing!) and small droplet of solder popping out under the led felt really good indeed!
Why does Santa wear a big black belt?
It's outside his coat so it isn't holding up his pants. His coat has buttons. There's no tools or sidearm hanging from it.
It’s a hernia belt, but he’s vain.
Those elves sure know how to make hernia belts look rad.
Just a question. why has there not been an over build BLF flashlight fabricated to hold turbo for like 30 to 45 minutes?? The tech is there right? I’m talking like 1500lms , just a number off the top of my head, nothing crazy like 4000lms. Can’t the body be made twice as thick with a big old copper driver heat sink with a moon light level down to .5 lms. A smaller torch easy to carry, nothing like the BLF GT. On cold nights it seen like it will hold turbo forever. I know it would cost more do to materials but it would be nice to have that max output for more then just a few seconds to minutes. Call it the BLF M1 Abrams, drop it of a 10 story building strong, whatever. A 26650 cell with a 3/8’’ thick body and a 7/16th thick head. 3/16’’+ copper driver and led boards. Run a higher end emitter at a lower setting? Can this be done or am I just smoking clovers?
Depends if you’re talking about 1500lm at 20C ambient without breeze or outside at 10C with breeze, and at which regulated temperature.
In this Zebralight SC700D review Zebralight SC700d – A Short Technical Review (lumens/runtime graphs/temperature/PWM/current draw)
It does 900lm inside, 2000lm inside with fan, and ~1700 outside at 7C ambient with wind gusts.
The SC700D uses an XHP70.2 5000K 90CRI driven by an efficient boost converter in a light body so that’s pretty impressive already, a low CRI LED would do even better.
I wonder how well a D4Sv2 (with boost driver) with low CRI cool white LH351Ds would do (most efficient 3535 3V LED), XHP35.2s would do a bit better, and with a 5050 MCPCB, XHP50.3s, I’m thinking it would be pretty close to the 1500lm target at room temp.
As for copper, it’s not really useful except for adding weight and increasing a bit turbo duration thanks to its ~1.4 volumetric heat capacity vs aluminium, but that doesn’t matter for sustained output.
Convoy M3-C
Indeed, according to 1lumen review it does 1500 (or just slightly under) with 45C body temp.
