Thanks - that copper D4V2 sure is a pretty face .
Yeah I don’t really need another light, but felt like the BAM led is “collectible” class.
Unfortunately per Simon new S21D is only black for now.
One issue I can see is that since 1) angular tint shift makes the hotspot of a light warmer, and 2) this combination has throwy warm emitter and floody cool emitters, the resulting beam profile will have EXTREMELY bad tint shift, with an orange center and purple spill.
I would recommend keeping all emitters domed or dedomed, or to mix low CCT domed with high CCT dedomed.
I disagree. The rosy-purplish “goodness” is revolting even for some flashaholics. The more creamy, sunlight-like tint of the 519 is easier for the eyes and easier to exaplain as a good thing.
Very interesting discussion as always, but could you explain the part I underlined?
Domed 519a (with the dome causing tint shift no?) has higher CCT than a dedomed 519a, so shouldn’t it be “angular tint shift makes hotspot of a LED/light cooler”?
I was disappointed the Nightwatch Chaos is not available to buy for Xmas gift, but I think this Wurkkos TS32 would more than ease the pain.
14000 lm of Nichia goodness from twelve 519a’s in a soda can light. What I hope to use it for is to light up my front garden for viewing or night photography for example. A floody pattern of light AND a lot of light even for short moments would be great.
No doubt Wurkkos has been on a roll, releasing some great AND compelling inexpensive lights such as TS30s and TS10 (let’s not talk about TS21 lol ). I once thought Wurkkos is just Sofirn’s sidekick little brother, but somewhere along the line they’ve become a force to be reckoned with.
Angular tint shift refers to variations in tint as a function of angle, within the same emitter. It does NOT refer to the CCT change going from domed to dedomed.
Domed LEDs tend to send bluish light forward and yellow-green light to the side. The emission collected by a reflector/TIR into the hotspot is mostly the sideways emission, which is warmer than the average/integrated CCT of the emitter, hence a warmer (and greener) hotspot.
If you are ok with angular tint shift, this is a completely fine configuration. If you care about beam consistency like me, this is not the way to go. It's all up to personal preference.
Thanks very interesting; I think I got it now. Central is warmer but the integrated CCT is higher.
BTW your description fits exactly behavior of SBT90.2. I’ve always wondered why there is a slightly green-yellow central spot.
One more question pls - if I understand correctly: The dome causes a tint shift and that’s why in the 519a LED, de-doming lessens/eliminates (?) the tint shift? If so… why does my dome-less E21a has a “worse” tint shift than the domed 219b? Or why does it have a tint shift at all? TIA
That's an excellent question! Most LEDs, including the 519A, have a very uniform light-emitting surface: the intensity, CCT, and tint is consistent across the whole die. With these LEDs, dedoming reduces angular tint shift considerably, virtually eliminating it when paired with a good TIR optic.
The problem with E21A is that the light-emitting surface is not uniform. The intensity, CCT, and tint varies across different parts of the emitter, so the tint shift is going to be bad whether the emitter is domed or not. The only way to eliminate tint shift in this case is to run it as a mule, or to use heavily frosted optics to blend the beam as much as possible.
So this beast is here. It is unfortunately out of stock on Wurkkos web site now but apparently should be back later this month.
Although it is a Nichia I think I will post my impression on it on a separate thread as it is a completely different form and style of light. I have some lumen monsters/super throwers with new Chinese LED on order (Haikelite HK05, JKK76), maybe I will compare them together, not just output but the crucial beam color and tint.
What’s special about the light is it’s a result of Terry @ Wurkkos working with Budgetlightforum HERE, so yes this is a “local” product. There is a TRULY fantastic review of it on 1lumen if you want to read about it HERE .
You’re very sharp :+1: . But first the pug: a co-worker has one so I see pics and videos all the time. Extremely cute dog; I would love to have one but not the time yet.
I have 2 Nichia 519a 4500k lights that both measure under specs wrt CCT: Convoy S21D (TIR) that measures ~3900-4100k and a Skilhunt H04R RC (reflector) that measures ~4200k (using two Opple’s that measure nearly all other LED’s close to specs). The beam color is on the warm side so I’ve been meaning to try the next step up such as 519a 5000k, so this Wurkkos is actually absolutely perfect for me.
Partial crop from the excellent 1lumen review below. The road is over-exposed but color rendering of bark and leaves of pine tree is excellent, so fingers crossed until I get to play with it.
OT - sorry: Excellent sale on TS32 with 519a on Amazon - bringing the cost down to $99.99, about Wurkkos’s regular price level, which is currently out of stock. And of course if you want a Christmas self gift this will make it in time.
I haven’t tested the light yet (it really is a xmas gift and I took it out for picture only) but I didn’t buy it without reading every word of a trusted review. This is the only super light (10,000 plus lumen) with Nichia LED on the market that I know off. For full review, pluses and minuses: Wurkkos TS32 review | high power flashlight with 13,000 lumens | 1Lumen.com
CCT 5217
Ra 97.9
12,000 plus “Nichia” lumens
I hope to start a thread about this light versus some Chines LED super-lights (Haikelite HK05 and JKK76) but I think I already know no one is going to beat it on beam tint and color rendering.
THX, I Ordered one. I was curious about whether it came with the handle. It seems to be optional on the Wurkkos site. It looks like the Amazon one does come with it. Correct?
BTW, you must have gotten your really fast. With “Prime” shipping mine show next Thursday for delivery.
Yes mine comes with handle and I think this is true for TS32 on Amazon.
It seems like with the double discount, the price even matches the 25% sale price of the light on Wurkkos China site (which is not in stock)! Once you add the handle and the battery. Such a sweet deal for a light you could get from Amazon, the only place I see TS32 available now.
I got nervous recommending a light without using or testing, so I broke down and started some preliminary test on the light instead of waiting until Christmas day . I absolutely love what I see so far - probably THE most fun light in my collection. Yes more than TS30S, even though TS30S still the throw king at ~1km throw. I hope to write some prelim report in case anyone wants to buy this light while it’s still on sale.
Glad you are liking it. All of the reviews I found were pretty positive. Now I just have to be patient until mine shows up. Too bad patience is not one of my virtues…
