【TS10V2 Al available】Wurkkos "slender waist" TS10v2 aluminum version available with black,green,orange
The two TS10 of mine with original FW version do not reset Lockout to off with 3C, and it doesn’t matter whether “Simple” or “Advanced” mode. However the two with the updated firmware function as published for 3C in lockout, and indeed set the light back to OFF.
Thanks for the replies. I just figured out my TS10 has old FW :person_facepalming: . The Wurkkos support confirmed before I ordered that they were shipping fixed FW and when I checked myself, I guess the orange LEDs were too dim that I missed it.
Advanced mode. All those I checked were the latest FW version. I do have one from the original batch and after the other replies I checked it and it does not work on that one
Do you use aux at high setting? I mean, it depletes battery in 3 days(from what I learned). Isn’t that too short, or do you charge your battery every two days?
yes and no. I modded my light to reduce the aux brighness a bit and significantly increase the battery life.
So, I’ve been waiting for those Cu and Ti versions… How are those coming ?
Frankly, the high aux LED setting is just a novelty. I don’t really see a practical use for it. It’s WAY too bright to use as a flashlight locator. Momentarily as a moonlight mode is too bright. Frankly, I wish Wurkkos reduced the high mode by 50%. The low? It’s nicely dim, enough to be useful as a locator but not a really significant drain.
My TS10 aux LED usage: Low aux is the setting for lockout. At night, I lock out the TS10, so aux LEDs are on in low. To use as a “bathroom assist,” just momentary holding of the switch delivers moonlight. Works great. In the morning? Take the TS10 out of lockout, with no aux LEDs on.
Yes Wurkkos, when is copper ts10 coming?
Still talking with the factory, they are not quite willing do cause this material not easy to operate on machine :person_facepalming:
If the factory doesn’t do copper regularly it might be difficult. Slightly different processes and tooling and contamination of the leftovers (not sure if it’s easy to sell aluminum mixed with copper).
Any more brass TS10 coming in future?
How about titanium?
Yes, Brass in processing
Green body with green aux available now, 15% code on page valid
https://wurkkos.com/products/wurkkos-ts10-new-with-anduril-20-3-90-cri-csp-leds-and-3-single-color-aux-leds-14500-mini-edc-flashlight?VariantsId=10482
Nice, but the aux lights are way too bright for bedside usage even on low :weary:
Red aux are quite dim on low.
2023.3.11 get the first copper prototype today, what aux color you will like in this copper version?
green!
I’ll take one. Aux color is unimportant. Where can I order one?
no yet production, it is a prototype
