Urban EDC has created an exclusive edition of the Reylight Titanium Pineapple Mini flashlight by milling a seigaiha wave pattern into the body tube. It’s available in a bead-blasted titanium or a stonewashed finish like I have here. Thanks to Urban EDC for sending this to me to review and show everyone. Links to their website are below in the description.
Watch this review on YouTube:
Follow me on Instagram: Jon (@liquidretro) • Instagram photos and videos
Join the Facebook Page: Liquidretro Gear & Reviews
Follow me on TikTok: liquidretro1 (@liquidretro1) | TikTok
Enjoy this review? Buy me a Coffee/Beer: https://www.buymeacoffee.com/Liquidretro
Find all my social media at liquidretro | Twitter, Instagram, Facebook, TikTok | Linktree
See my Amazon Store with my gear recommendations Liquidretro Reviews's Amazon Page
Buy the Reylight Pineapple Mini Seigaiha Edition at https://bit.ly/UrbanEDCLR (Affiliate Link I think?)
If UrbanEDC is sold out I am told they will be restocking in a couple of weeks so make sure to check back!
A history lesson on Seigaiha
A little history lesson here first, The Seigaiha pattern first appeared sometime in 6th century Japan. It symbolizes waves, power, and resistance, which are key elements of Japanese culture. It’s also come to symbolize “surges of good luck”. In recent years, the pattern has increasingly become popular in the EDC community. I think it’s classic and elegant. Something that could be used daily, or on special occasions while at the same time adding a very functional grip to the flashlight, pen, or knife.
This also ties in nicely with Urban EDC’s recent brand identity updates to its compass logo that now incorporates the seigaiha waves too.
Brief Bit on the light design and function
As far as the light itself this is mostly a standard Reylight Pineapple Mini I have reviewed before, with a few updates. I like the Pineapple Mini and own several in different colors, materials, etc, and carry one often, due to its slim size, lightweight, and appealing tint.
For those unfamiliar with the Pineapple mini, let’s look at a few of the high points. Starting at the tail there is a 1.5 x 6mm tritium slot in the tail button. Underneath is a reverse clicky switch. The clip sits below that, held in place by the tail cap. That space is required, if you prefer to go clipless Rey sells a spacer or there are ones you can 3D print too. The clip itself is deep carry and has a reasonably large hoop at the top to easily accommodate jeans. The clip is not reversible.
The body tube is the start here on this Seigaiha model, it adds texture that in the hand feels good, not too aggressive on the skin but is more aggressive on your pocket than the standard pineapples. So not only does it look good but it’s functional too. Threads are fine and standard. Mine could have used a bit more grease but that’s an easy fix with some superlube grease. The head is largely plain with minor styling. Up front there is no crenulation, the AR glass is inset slightly, surrounded by an orange peel reflector. The stonewashed titanium model here weighs 1.37oz with the battery and clip.
LED & Beam Shots
Urban EDC lists the light as having a Nichia 219b LED, but based on the many Reylight Mini’s I have, the 519a Mod’s I have done, and after talking to Rey I am pretty certain these have Nichia 519a LED’s. Reylights 219b’s tended to be around 4500k, and this 519a is closer to 4000k. In my shot below the grey titanium on the left is the 519a, and the brass 219b is on the right. This updated LED is a good thing in my opinion as the 519a has more output than the 219b, still high CRI, and has a nice rosy tint which I prefer myself. It’s the most popular LED at the moment due to it’s great characteristics.
On my Opple Light Master Pro I measured the light on High with a liion and got 3896k, at 97Ra (CRI). DUV was slightly orange, with no green in the beam which I like. On High there is PWM but it’s very fast. The beam profile with the 519a LED is a larger hotspot, this is partly due to a slightly revised reflector I think too. It’s a nice beam pattern for a non TIR EDC light in my opinion.
Outputs
While the light will a AAA alkaline or NiMH battery all my testing was done with the 10440 Liion it ships with. For me this is the only way I run any of my Reylight lights, performance is quite a bit more, but you do trade runtime. In general
With a 10440 battery, I got the following outputs in the default mode.
- High - 280 Lumens
- Medium - 65 Lumens
- Low - 16 Lumens
- Moon - 1-2 lumens I would guess, my lumen tube isn’t very accurate this low.
With a AAA Alkaline or NiMH I got the following
- High - 85 Lumens
- Medium - 45 Lumens
Heat and Runtimes
I had a little trouble with my runtime data here, I will insert graphs of what things look like and let them speak for themselves. No issues to report. I will say that on High when running a NiMH is short depending on the resistance of your battery. The 10440 is really the way to go here.
UI
The UI here is basic and pretty easy to use. The light does have a reverse clicky switch which means you must press the button all the way in to turn on. Once on you can half press to change the modes. By default, the light does not have memory mode but that can be turned on. The light is programmable into 4 preset modes that vary the output of the low, medium and high outputs. The 4th mode adds a strobe option too.
Reylight has some directions on their website, and I will try to link to some of them that I made when I gave some mini’s as gifts. This is an area for improvement, Reylight should include some directions inside the package. Make sure to charge that included 10440 battery before use too. Side note you will need to supply your own charger, my recommendations are the Vapcell S4 Plus and Xtar VC4 Plus (VC4SL) both of which I have done reviews on in the past.
Final Thoughts
I have 8 different Reylight Mini lights it’s no secret I am a fan of them. The titanium Seigaiha version from UrbanEDC is visually really nice I think. I find the Seigaiha pattern appealing, and I like the history behind it as well. As someone who works in technology, it looks like the wifi symbol too which is fun.
Functionally the new pattern is nice as well, you get a surprising amount of grip from it in the hand. While it does grip the pocket well, in my jeans, the new pattern does seem to almost grip too much, I would expect it to wear the inside of the pocket material more so than my other Reylight Mini Pineapples I have.
This isn’t the light that you are going to take camping or expect to put in heavy-duty during a natural disaster, but it functions really well as a small EDC light that you carry in a pocket to have with you for small daily duties. Finding the lock on a door, not tripping over something inside or outside the house at close range, finding the dog in the back yard briefly, extra light to find a lost item in your car or under the couch etc. I find myself carrying a mini quite often because I really like the slim size.
Remember these come with the Nichia 519a LED too, so it’s more output than older Pineapple Mini’s you might have, but still retaining a high CRI and pleasant tint. It’s a great way to try what’s arguably the LED of the year that enthusiasts are loving almost universally.
Buy the Reylight Pinapple Mini Seigaiha Edition at https://bit.ly/UrbanEDCLR (Affiliate Link I think?)
