1. more warm. less blue.
2. less tactical. more practical.
3. more body colors. less black.
I want cheaper LEPs.
- BLF UIs on Convoy lights.
- More USB charging that’s built in the threads, instead of behind a flap
- More 519A, and good ways to drive 6A to them. Buck, or boost if multi-emitter.
- Better side switches that don’t activate accidentally
- manufacturers respecting standby drain more
My perfect light for 2023 would be a ZL SC64 with 519A, 6A buck driver, and anduril. I know ZL won’t do it, so I challenge someone else to get close on the form factor.
Larger switch buttons ala TS11, light that comes on with a shake, or a wiggle.
More lights running on AA batteries - especially coming from Olight, lol.
Also less cold white emitters. Neutral white should be the standard option.
For me, same as ever:
- Smaller
- Brighter
- MUCH better CRI (PLEASE!!)
- Regulated Runtime, it’s not just for breakfast anymore.
- NO BLINKIES!! (not asking. stop that.)
- TIRs, not Parabolas, please (being nice again).
And Muggle-compatible battery options, because I give away a lot of my experiments.
Better UIs and customizable UIs.
And lower prices
I’d like to see lower power and plastic. Seriously.
Part of increasing lumens/watt numbers in emitters is that workable high levels can now be achieved with less heat.
Fiber-reinforced polymer is an incredibly light and durable material, just lacking in positive thermal properties.
Pelican/streamlight have made durable polymer lights for a while, especially in the specialty industrial lines. Give me an honest glass-reinforced nylon convoy s2 / s12 size light with emitter options and 500 lumens. And a corresponding lightweight headlamp.
Efficient drivers
No blinkies
Less Androol
More mechanical switch lights, side or tail.
One of my most favorite lights ever is a Convoy BD06 that was given to me as a gift. It wasn’t perfect but I eventually got it that way. Stock it wasn’t that great but, with a bit of work it’s now bullet proof. Make a light like that. Make it right the first time and never leave anything on the table.
- Availability of custom/DIY drivers as pre-populated boards for those of us who don’t own reflow capabilities.
- Manufacturers producing more efficient drivers as standard
- Warm white lanterns, to get some sofirn competition going
- More lower cost AA/AAA lights, the category has been stagnant for a while
- More lights with fun/unusual LEDs: Phosphor converted colours, UVC,
- “Super LEDs* (SFT, osram nm1, SBT90 etc) in warm CCT options
Better QA/QC.
Not shipping lights until they’ve completed development, nor expecting paying customers to find bugs for you.
More and better throwy floody combo lights,.
I love how contradictory the “wants” are in this thread
A minimum standard for quality control.
Getting a quad with one LED defective should not be acceptable.
A manufacturer offering you a discount or swap on BLF for publicity should not be considered compensation for bad quality control.
Really guys, let’s make it clear that we are willing to pay extra to get something that works.
More colours from Maglite or even from Streamlight too.
+1
I’d like to see that…but corners must be cut when building a product to a price point. Budget lights have gotten a lot better, but a budget light is budget for a reason.
- Anduril - or something like it - with out of band configuration via a config file. Could be USB, serial of some flavour - even if it uses a USB adapter - clever “use the LED as a photodiode” programming, I shudder to say … bluetooth, whatever.
- 1xAA angle lights have seemingly shrank from the market at a time when I’d like some - and ideally in dual fuel
- 4680 lights - kinda dumb but I’d like to see what the market can do with that kind of energy and power density
- More reflector lights optimized for flood/hybrid beam. The concept of reflectors maximizing intensity has its roots in the origins of the flashlight - literally a turn-of-the-20th-century dim incandescent bulb powered by feeble carbon-zinc cells that could only flash the bulb for seconds at a time; concentrating that small amount of light was the only way to make it useful and was a formula that prevailed until LEDs starting getting capable ~20 years ago. Nowadays we have more lumens from a small LED than the average mains-powered incandescent bulb puts out and most of us need light for our immediate area, not lighting up a fence/treeline, sweeping fields, etc. Living in the city on ~⅛ acre and generally needing a flashlight to perform household tasks, walk dogs in the neighborhood, etc I only need to light up things more than 3m from me ~90% of the time, perhaps 10m away another ~10% of the time, and <1% of the time as war away as 30m.
2 switch like sofirn - forward clicky tail switch with momentary on.
No charge port / power bank or on board charging (more simple and more reliable)
Use of generic batteries
Efficient boost/buck drivers with a proper moonlight! I keep coming back to the blf a6 driver just because it has good max output and a very low moonlight. Even lots of linear drivers from convoy etc still have a lowest mode of several lumens. I built an s21a with a kaidomain p4000 buck driver and a 519a and it works well, but the lowest mode is slightly too high and it has some questionable mode memory.
