Yes it is! George Harrison’s favourite lightbulb joke was: “How many Beatles does it take to change a lightbulb? Four.”
On the other hand there is this joke about Apple enthusiasts: “How many Apple enthusiasts does it take to change a lightbulb? They don’t change the lightbulb, they just buy a new house.”
Working together can be quite rewarding, but it looks you’re in the Apple team.
Maybe the tail cap is loose. It is usually glued and should not be loosened, but you may have loosened it (because there were not enough glue perhaps?).
– Loosen tailcap – Hold button – Tighten tailcap – Keep holding button for about 4s I've tried this probably 25+ times. When i first had issues, this seemed to work the first few times and the light would work as it is supposed to immediately after. Then i'd turn it off and when i'd come back to try it a few minutes later it was back to not working. I was able to get it working again about 3 or 4 times doing this, but it wouldn't stay working after i'd turn it off. Since those first 3 or 4 times, it no longer works. I hold the button, screw the light back together, just before its almost fully screwed in there is a brief flash from the main LED's then the green AUX LED's turn on and then nothing. No response of any type when i click it.
The light should flicker while getting brighter, then briefly burst to
full power. Hold until it reaches full power to do a reset, or let go
of the button early to abort.
On some lights, like products where the tailcap method is impossible,
use 13H from Off to do a factory reset.
12 clicks and hold the 13th I was not able to open tailcap, but was able to open from the top/middle part of the light. i've tried the 13H with no luck either.
From what i’ve read it sounds like you’ve been loosening and tightening the tailcap with the head in place.
Try loosening the head (or removing it), then tightening the tailcap fully, then replacing the head.
(And then if the button works you might still need to do the 13H reset that doesn’t involve loosening the tail cap.)
Sometimes on a light with a signal tube you can get a poor connection through the signal tube which can be sorted by tightening the tail before the head.
And for the TS10 Wurkkos specify: “Note: tail cap is glued,for better contact of the electronic tail press, please do not twist and disassemble the tail cap. Unscrew the entire head to replace the battery.”
From what i’ve read it sounds like you’ve been loosening and tightening the tailcap with the head in place. I may have stated incorrectly that I was removing the tailcap. I was not. I was removing/unscrewing the head. I can't budge the tailcap.
They have ben when I contacted them in the past. Maybe you could give it a couple of days after their holiday
You could try to PM “wurkkos” (user) to see if that might help.
Thanks. They actually did respond timely on their website, but I missed it not realizing there was an inbox on their site. I thought any response would have generated an email instead. I had also sent several emails that weren’t returned yet, but i’m not worried about that as they did respond. I’m going to send a video of the light not working and we will go from there.
Hey buddy, happy new year! I just ended my New Year holiday.
I guess the issue comes from its tail. It should be that the inner tube and tail are not fully contact due to errors assembly. Because our green aux version has been out of stock. How about let’s exchange another TS10 body?
will be waiting to hear when you get the new light, whether its tail works on the light you have now, that does not work… that will help determine if the issue is w the tail or the head of the light that is not working.
I’ll definitely do that once i receive it. So far the customer service has been great after the holiday. They did reply during the holiday on their website, but i missed it not knowing there was an inbox on the site. But after I realized that and responded, they’ve been very responsive and very helpful.
Hunting for a solution to this similar problem you’ve had. Did Wurkkos handle this for you? How did you describe your situation so that they didn’t think you weren’t simply anduril clueless or similar?
I’ve a dead TS10 and have been through all the resets, and suggestions in this post. Love this light so much. Hoping it’s a fixable issue. - Also, sorry if there is a direct message option here, first post on BLF and I couldn’t find dm. If you see this and respond, thank you much!
The TS10 is very finicky about being clean and tight. It’s not the only light that is that way, but it’s especially common on Anduril lights that have a tailswitch; the Emisar KR4 is the same way. I have five TS10’s (two green aux) and a KR4, and the first thing I always do when they misbehave is wipe the ends of the battery tube, then reassemble and crank them tight.
One TS10-specific quirk is that sometimes removing and replacing the head doesn’t result in a flash to let you know it’s connected or the aux lights coming on. Most times when that happens, it’ll still turn on, then will operate normally though; it’s just a little scary the first few times.
It’s always possible that there is an actual defect, of course, but considering that I’ve faces similar issues yet all five of my TS10’s that have done similar things are operating perfectly now with no need to contact our man Terry or the other folks at Wurkkos, I figured I’d chime in and say that it may be something minor/fixable. And if it’s not, there is a reason why Wurkkos is so respected in the community besides offering decent lights at a decent price; excellent customer service. If it turns out that they sent you a bad TS10, they will make it right.
