Got my pink 3 lumen one just now. Very nice, but I’ll definitely be giving it away (haven’t opened the box, though I might put some lube on it and stick in an Energizer AAA before I part with it).
Like I said before, for $5, who’s complaining - it’s a great deal.
Noticed my blue Ti had what looked to be a brass trim ring on the head below the knurling of the head. Looking closer, the pic above must be with no battery with the head fully seated.
With a Duraloop in my sample the head will not seat all the way down even when turned on bright (without potentially crushing the battery and possibly breaking something). Hopefully the o-ring is far and tight enough inside the tube to seal.
PS - the blue color is pretty much right on when I put it next to the picture and hit it with light. I suspect my grand-daughter is going to want this one for her purse.
My “pink” Ti has brass showing in the gap between the head and body about 1/16 - not ano. like in the pictures. It makes a nice accent but seems a little unfinished. I wonder how long that piece of sponge rubber that it uses for a spring lasts? It looks hard to replace.
There’s no problem with o-ring seal. It’s deep. You’ll only get rid of the brass ring reveal if you remove the battery. It ain’t broke so don’t worry about fixin’ it.
I had thought about the sponge material myself. If it flattens with wear, surely there must be a replacement. Dunno.
Maybe ask em.
ETA: Above said, I actually made one for the P0 with flex tubing. Then 4 sevens came out with a redesign of a resilient long lasting type of rubber one. So it’s doable even if Thrunite doesn’t offer a replacement.
Rather loose head. Changed the o-ring with a slightly thicker one to prevent accidental turn-on or that it looses its head while mingling with my keys.
The brass pill was pressed into the head at a slight angle so it didn’t go all the way in. It was sort of crooked/bent when you screwed the pill head assembly on the body. I was able to press it in fully via hammer and cutting board and it corrected itself.
Happy now with that.
PS - I’ve been wondering what those who have the firefly had it say on the box. Mine says firefly and then 3 lumens so it’s not really a firefly. On the T10’s true firefly I can look direct at the emitter and not squint . . can’t do that on the Ti 3 lumen version.
I sold mine already, as I was really only interested in the Firefly. I had actually intended to mod mine so that it was a single mode 0.04 lumen light, but it wasn’t in the cards.
Meh, I got the gold/orange 3 lumen version. I was order number 38 and at that time the deal looked like it was going to be a black firefly version. Kinda bummed about that.
