NEW TrustFire TR-DF003 2x26650 3xCREE XM-L Diving Light
Thanks Kramer.
Hopefully 2.54/LED
I was thinking that myself, but these XML diving lights tend to be very floody. Perhaps the very recessed bezel could be a low cost attempt or solution to maintain more of a spot beam then all out flood?
Looking at the measurements, this thing is as long as a 3 “D” size flashlight. I’ll have to check on my funds and perhaps pull the trigger on this one.
Yeah thats more in-line with their 3000 Lumen claim.
One strike against it though is that UI. Disco flashey mode flipping is terrible with twisty witches, and with 4x gaskets thats not going to be much fun… IMHO.
Wow, I love the look! It would be great to have a real waterproof flashlight in my stable, as even water resistant ones like the TM11 are too expensive to risk. I won’t even dunk my S18. I had a need to put the head of a light into water over the weekend as we were trying to find something dropped in the water around 1200mm deep (was a walkie talkie, but that’s a whole other story….) and while the above 2 lights lit up the bottom brillantly, the glare on the water made it hard to see through. It would have helped massively to put the head into the water to stop the reflection, but do you want to chance it with lights well over $150? So having a light like this where you have no concerns would be great.
Agree about the attack bezel though- I can see that eating up some output……
But I’ll be watching this one and seeing what the inital impressions are.
There are many cheaper dive lights if you are just doing 2-3m depths.
This is really impressive. 683 grams! That is the weight of the TK70.
I’d love for someone to do a crush test. Probably the same level as a Fenix TK10.
Also its probably some 1400L - 1700 lumens OTF for these triple XM-Ls.
Yes, I just saw THIS on Manafont’s website this morning. I just love the rugged good looks. Too bad I’ve got 2 flashlights on order right now. (If only I had more money……) :stuck_out_tongue:
Hi guys:)
I am new to that forum. Glad I found it!!
I am a torch freak as well :OO
I’ve lately seen this light in several stores and I really want to buy it but i have some questions to you :slight_smile:
I need it for diving, about 20-25 meters depth.
as I see this torch is not a great thrower right :\
right now I have palight t6 (800lm) that throws not too far but ok for my needs - but the light is too weak…
now if I buy this new light…
1. is there any way to make it a better thrower? ucl lens or maybe other reflector? or maybe this optics?
http://www.led-tech.de/en/High-Power-Supply/LEDIL-Optics/CREE-CUTE-3-XM-optic-19°-LT-1751_106_146.html?cross=1751
2. does it have a good driver, or it can be replaced for something better? what do you think?
3. what would be its’ runtime on max with 2*26650 ?
thanks for you help :wink:
$108 @ MF.
The $85 price tag at CNQ is looking like a bargain!
Would be nice if it included 2 x 26650 cells. At that price, I may pull the trigger.
Maybe or maybe not. Once CNQ adds just the minimal shipping Registered Airmail Post, it brings the price right up another $28.96. I think DHL is about $32.00. So it’ll cost at least $113.96.
Hi HitIt, welcome to the forum.
This light is new to the market, so I don’t think anyone knows exactly what driver it has or how easily it can be upgraded. Considering it has 3 x XML’s and driven to 4.5a, I’d say as a diving light it should really put out a good amount of light. As for making it throw better, I doubt you could given the design of the reflectors. But someone would have to get there hands on one to determine if a higher power driver can be installed, not to mention if it would be capable of shedding extra heat. I’m sure I’ll be purchasing one soon myself.
Welcome to the family, HiTiT!
Probably the only thing you could do to make it throw better is to replace the driver. I wouldn’t worry about heat on a diving light. It’s like having water cooling and that’s tough to beat for shedding the heat. :wink:
Welcome to the club, HiTiT!
There is even more aluminum in this light than the Thrunite Catapult series.
Yes but 100 meters water proof !
thanks for all :laughing:)
I thought of, maybe changing the leds into U2 and putting a better driver.
Lets say, will that be possible to put an sst-50 driver (5a) or an sst-90 driver (9a).
is that possible to put such drivers for these kind of applications (3* t6) ??
:laughing:)
another 2 things in the original application, what would be the run time you think?
and about the ucl lens, will it stand the underwater pressure as the original lens?
about the heating issues, as was already told above. I not worried about that at all… the max temperature of the water is 28celcius at july-august… so even that temperature will cool the most hot torch in the world.
b.t.w - i am diving with a beast torch - 35w HID. which is getting very (very very very!!!) hot outside the water. but you dont feel it in the water. (the problem is its’ huge body, and low runtime…)
IPX-7 is defined as “continous immersion up to 1 m for 30 minutes”. Not to mention that it is a “static” rating in that the light is not moved or switched on/off during the test. At least it’s a set standard.
IPX-8 is defined as “equal to and greater than IPX-7 in some way”, ” continous immersion beyond 1 m” AND under conditions which are identified by the manufacturer The specs vary from manufacturer to manufacturer. Almost meaningless. An IPX-8 light could be any light capable of submersion to 1 m for 31 minutes. Also a “static” rating.
I like specs and ratings but sometimes they can be misleading.
umm… yes.
but they stated at their documentation this:
and on their officail alibaba store: http://trustfire.en.alibaba.com/product/580714703-213350150/2012_TrustFire_New_style_diving_flashlight_TR_DF003_3_CREE_XM_L_T6_LED_5_mode_3000LM_high_light_led_torch_flashlight_2_26650\_.html
BTW!!!
if well make a group to buy this torch. the minimum for getting directly through the factory in 10 pcs…
and payment can be made via paypal… maybe they can give us a better price??
I’m not doubting what they say (well, a little) but I am curious about how they tested it. Apparently there is no real standard beyond IPX-7 and we must rely on the maker’s method of testing. If they don’t tell us how they tested it then the numbers don’t mean a lot. Was it done in a pressure tank with no movement and no turning it on/off (static)? Was it done while being used the way a live diver would use it by moving it around and turning it on/off? There is a big difference between the two. There is a difference in viscosity of the water types as well. Salt vs fresh. Did they test for both? It’s the unknown stuff that I question.
It’s obviously built to be heavy duty and I like the double diameter threading and the quad seals/o-rings on each end of the light. I have not seen how the lens is mounted yet. All in all it looks to be a winner. For under $100, you should go for it.
Howly $hit :open_mouth: It’s the first time I see dual stage threading (or whatever) :open_mouth: Built like a tank! :open_mouth: For 85 it’s a good light, IMO.
