*NEW* - Sunwayman C10R - 190 / 500 Lumens Innovative Tactical-on Side Switch Flashlight
(no, the D4 is not included!)
: Outstanding Tactical-on Side Switch Design
: Unique Switching System with Low-voltage Indicator Lamp
: Solid Structure, Reverse Battery Protection Circuit
: Detachable Lanyard Ring, UNC1/4'-20 Camera Threaded Hole
: Soft-contact Side Switch:
Three modes constant output, hidden Strobe and SOS
Three constant output modes: 190Lumens (1.5hrs) – 50Lumens (10hrs) – 3Lumens (50hrs)
As Sunwayman always rates the output for CR123A, this feller should be near 500Lumens using 16340
(caution to use turbo only in short bursts on 16340)
Strobe: 190Lumens
SOS
: Working voltage: 0.9~4.2V
: Dimensions: 82mm (length) x 25mm (head diameter)
: Weight: 63g (battery excluded)
: Accessories: Clip, O-ring, lanyard, holster, stainless steel lanyard ring
Now available for pre-order!
http://swm.hidcanada.com
FREE WHITE GLOW-IN-THE-DARK PARACORD with EVERY PRE-ORDER.
IMPORTANT: Input your BLF NAME in the comment box on checkout to receive it
Here is a green version:
That looks pretty neat!
It looks like more lights are getting side switches!
It does look very nice on this one!
Sweet! It looks like a miniature black SR King! 8)
More photos: http://www.messerforum.net/fotoalbum/showgallery.php?cat=1817
You can’t appreciate the diminutive size and smoking hot looks until you see it held in a hand. Impressive looking little bugger!
Where is the low voltage indicator lamp? On the tail?
This little Sunwayman looks awesome!!!
#This is a small light.
The Jet beams looks cheap compared to sunwayman
We’ll be giving one away so if you’re a lurker and haven’t signed up yet, you probably want to do so before the cutoff date is announced :slight_smile:
On a side note, the boss is going to fire me for giving so many nice things away…
Where do you sign up at?
Thanks…
+1
Do what I do ...Don't tell her !
