: Outstanding Tactical-on Side Switch Design
: Unique Switching System with Low-voltage Indicator Lamp
: Solid Structure, Reverse Battery Protection Circuit
: Detachable Lanyard Ring, UNC1/4'-20 Camera Threaded Hole
: Soft-contact Side Switch:
Three modes constant output, hidden Strobe and SOS
Three constant output modes: 190Lumens (1.5hrs) – 50Lumens (10hrs) – 3Lumens (50hrs)
As Sunwayman always rates the output for CR123A, this feller should be near 500Lumens using 16340
(caution to use turbo only in short bursts on 16340)
Strobe: 190Lumens
SOS
: Working voltage: 0.9~4.2V
: Dimensions: 82mm (length) x 25mm (head diameter)
: Weight: 63g (battery excluded)
: Accessories: Clip, O-ring, lanyard, holster, stainless steel lanyard ring
