Triple led wiring
25 posts / 0 new
zeremefico
zeremefico's picture
Last seen: 14 hours 43 min ago
Triple led wiring
Hi, I received yesterday the triple xp-g XPG Indus Star and the well known 8×7135 driver at 2,8 amps, powered by a 18650 cell. Regarding the wiring, can you tell me, which options I have, paraller or in series? I am confused?
Parallel:
Also Parallel:
In Series:
₪₪₪₪ ΟΥΔΕΝ ΚΡΥΠΤΟΝ ΥΠΟ ΤΟΝ ΗΛΙΟ ₪₪₪₪
My YouTube channel
Flashlights & edc gear
K40M F16
Edited by: zeremefico on 06/30/2012 - 05:48
NightCrawl
Last seen: 6 years 10 months ago
Parallel. Each LED will get about 0.9A then.
zeremefico
Parallel is number 2 image, right?
Also, in number 1 connection, If the +,- circuit close with a fourth wire to each pole, will cause any difference?
My YouTube channel
K40M F16
YoSeKi
Last seen: 10 years 6 months ago
First, you have to remove the jumpers. Since you need to wire the emitters in parallel, you need all the +- connections to be open before you attach any wires. Once the jumpers are removed, you can wire it like image 1 or 2 and it will be wired in parallel.
NightCrawl
It's both parallel, but image one might be easier to do.
zeremefico
jumpers=0 resistors?
My YouTube channel
K40M F16
zeremefico
NightCrawl wrote:
It’s both parallel, but image one might be easier to do.
Can you show the in line connection?
My YouTube channel
K40M F16
NightCrawl
Yes, those 0 ohm resistors just connect +-, so if you had a 3S driver, you would only have to solder to the empty pads. But as you have to connect them in parallel, you have to remove those jumpers.
I'm sorry, but what do you want me to show you?
http://budgetlightforum.com/node/1373
6th picture shows a wired star.
zeremefico
I would like to make an in series connection image, to add in the first post.
Can you describe the wire placement for that?
My YouTube channel
K40M F16
NightCrawl
Oh, Ok. Smile
In series, you connect the + and - tabs next to each other. That's what those jumpers are doing. Then you connect the wires from the driver with the empty solder pads. But those drivers are rare in "low" current applications such as 3 XPGs.
zeremefico
NightCrawl wrote:
Oh, Ok. Smile
In series, you connect the + and – tabs next to each other. That’s what those jumpers are doing. Then you connect the wires from the driver with the empty solder pads. But those drivers are rare in “low” current applications such as 3 XPGs.
It this in series connection?
My YouTube channel
K40M F16
YoSeKi
No. Click this link to see what a triple wired in series looks like. (Link takes you to mtbr forums)
zeremefico
After your help, I updated the first post, hope this will help other people except me.
My YouTube channel
K40M F16
DarkSide
DarkSide's picture
Last seen: 5 years 4 months ago
Your timing is uncanny …Thanks a lot for posting this! I just received parts for LED supply and shiningBeam
Both great to deal with.
Thank You
Chicago X
Chicago X's picture
Last seen: 9 years 7 months ago
I like to use #2, after removal of the ZeroRes jumpers.
http://wardogsmakingithome.org/index.html
War Dogs, Making it Home - Rescue Dogs for Returning Vets
ruffles
ruffles's picture
Last seen: 1 week 5 days ago
Bit of an old thread, but I’m about to wire up a parallel star and I’m nervous because I’m not exactly a soldering hero…
I have silicone jacketed 20awg wire that I’ll use to connect to power, but can I cheat a little and use smaller wire for the in-between connections? (I’ve got cheap-jacket 24awg and silicone jacket 28awg available right now.)
[edit] I should have said 3A drive current on high. [/edit]
Thanks!
MRsDNF
MRsDNF's picture
Last seen: 3 days 12 min ago
What would happen if the LED was wired up in series with the same 7135 2.8 amp driver?
zeremefico
3.7/3 volts and 2.8A to each led?
Non working situation I think.
My YouTube channel
K40M F16
scaru
scaru's picture
Last seen: 6 years 1 month ago
I don't think it would turn on. Not enough voltage.
MRsDNF
MRsDNF's picture
So you would need 10 volts and it would put out 2.8 amps per LED if you wanted to run it in series?
scaru
scaru's picture
At 10 volts the driver would die. Wink But yes, if you found a driver for 3 LEDs in series (like the DRY driver) then yes it would work.
Rufusbduck
Rufusbduck's picture
Last seen: 8 months 3 weeks ago
If you look at chassis wiring in this graph, you can see that awg24 (or awg20)is okay for the main current feed and awg 28 for the parallel feeds but I would use silicon or Teflon cased wire for both due to the heat present from the LEDs. Cheap jackets shrink back and could expose the wires to the mcpcb or each other. The silicon jacketed wire you have should be okay.
Scott
ruffles
ruffles's picture
Thanks! That’s exactly the info I was searching for and failing to find.
hank
hank's picture
Last seen: 1 month 5 days ago
This thread looks short enough and helpful enough to revive, I hope.
So, there’s this triple Nichia:
(click to embiggen)
It’s identified on the board as “Parallel”
It has one big LED- and one big LED+ solder pad
Is it safe to assume the connections to the emitters are made on the board under the black paint layer?
I don’t see a way to do the fancy wiring discussed above earlier in this topic.
kyfishguy
kyfishguy's picture
Last seen: 9 months 3 days ago
I've used a number of these in the recent past.  All the connections you need are already there under the black layer.  Just connect your driver wires to the supplied pads and enjoy the light.  Just be careful what you order as Kaidomain also sells a serial version.
Brian
