7135 drivers with higher voltages revisited
116 posts / 0 new
Rufusbduck
Rufusbduck's picture
Last seen: 9 months 6 days ago
I’m digging this up again as a possibly ill suited and certainly more difficult alternative to the Zener mod. Actually, Drjones suggested using either a Zener and resistor or a voltage regulator in Post 14 and of course I had to choose the more difficult of the two. I got it working up to 3s LEDs-3s cells but never used it because of the loss of low voltage protection. That deficiency has hopefully now been addressed with an additional 28.7k resistor in series with the 19.1k R1.
There’s not much point in reading this entire thread unless you’re a glutton for punishment and I’m only bringing it back for a sense of completion. I’ll be adding final info and pics at the end of the thread and linking them in the op to make them easier to locate later.
*Updates located at last post *
I’ve been toying with various combinations of 7135 based drivers for use with multiple led lights. There are a number of creative ways to accomplish this out there and I think I may have another possibility that takes advantage of the fact that these drivers are basically two circuit paths on the same board.
The enabling circuit path flows from the battery to the positive terminal on the driver and through the processor (if there is one) and on to the Vdd pin on the 7135 chip and through the chip to ground. The part of the circuit from the input terminal to the ground ring carries very little current but must handle the full battery voltage. The drive circuit path also flows from the battery to the positive terminal but then leaves the board and flows through the Led then back to the board and through the 7135 chips to ground. If you hold the chip with the long terminal at the top, Vdd will be at the right on the bottom edge and the pin on the left end is connected to Led -. The middle pin is another ground and often not soldered to the board. For me, the downsides of running Leds in parallel with stacked boards are: 1) Higher currents than the wiring for my bike lights can handle(6 A for a quad xpg). 2) Multiple driver boards and/or extra wires in small spaces. 3) Limitations on battery pack configurations. 4) Leds in parallel are susceptible to thermal runaway. These boards are being used by many of us without problems. This post is just to try to expand the range of possibilities. None of the above shortcomings are insurmountable. My thought was to expand on the separation of the circuits using some of the notions put forward by others as well as my own. To begin with, run battery + to the leds and wire them in series and then to the led – terminal on the board(4 × 7135 for xpg, 8 × 7135 for xml) and use one liion or 3 nimh in series for each led. In this current path the 7135 chips have only to burn off the excess Vbatt above Vf. For 4 xml with a Vf of ~ 3.3V each and 4 Li-ion that would be 4 × 4.2V = 16.8V with fresh batteries – 4 × 3.3V = 13.2 V = 3.4V excess. Others have used leds in series with the driver input to lower the voltage to the enabling circuit path. I propose instead to replace the reverse polarity diode with a resistor that drops the input voltage from Vbatt down to ~ 5V. The current in this part of the board is so low that a 1/10W surface mount resistor would both fit in the same space and be easily able to handle the excess voltage. The switch is wired into this part of the circuit and need only handle a few mA. Unless I have missed something (entirely likely), this should work and provide another option for these nifty little boards. Where I would appreciate some input is in obtaining accurate current measurements for the enabling circuit. This is necessary in order to guage the correct size for the resistor. I would guess that since the 7135 chips are in parallel then the current through processor is dependent on the number of chips in use. Since the current in the circuit determines the voltage drop across the resistor, this becomes need to know. I made up a test bed to collect this reading but either my meter was not up to the task or I was doing something else wrong.
Here is a description of my test bed.
1- 26650
1- xml stuck to a copper cap with fujick
1- 4 × 7135 single mode board
1- 4 × 7135 multi-mode board
1- switch
1- meter
Battery + goes to both led + and switch
Battery – goes to ground of both boards
Led – goes to led – of single mode board
Switch goes to meter
Meter goes to multi-mode board
Switch off – meter reads 0 on all scales
Switch on – meter reads 15 microA but no light
Meter removed – switch behaves normally with access to all modes
For the test I used two boards to emphasize the separate circuits but only one should be needed . I might try again with the meter between the two boards. It’s possible that a clamp meter might help for this measurement.
The idea is to be able to use a single board to drive multiple leds in series with minimal extra wiring and low current through the switch.
What do you think?
While I am waiting on some parts, I thought I would do some prep work on the board. It is a Dx sku 7612 16-mode board. The current plan is to relocate the 7135 chips(there will be 4 as this will be an 1.5A xpg driver) to a dedicated heat sink/ground and replace the chip closest to the led+ pad with an L78L05 voltage regulator. I will need to cut the traces leading to the input pins(other than gnd) of this chip and jumper it to Vbatt and Vin for the processor. Tonight I will be prepping the board and heat sink.
Scott
Edited by: Rufusbduck on 06/04/2014 - 12:29
WalterK
Last seen: 2 years 9 months ago
Interesting, as I am looking into this also for a project with 8×14500Li-ion and one XM-L.
I find this part confusing. Be aware that you can use as many 3,4-3,7V cells as you like, but all in parallel. Then its a very efficient set-up.
@Rufus; Did you mention all components on the boards? For multiple modes I excpected more then just AMC7135’s. Maybe quote the SKU#.
What you are trying is using drivers in parallel, quite common practice on the forums, once you know the trick. (I don’t.)
For single mode in the end you only switch the low current needed for the Vdd to activate the AMC7135. From what I’ve read this is done before.
Haven’t tried this yet but plan to use this with a small reed switch. I have bought loose AMC7135,s from Ebay.
What I wonder, will any component labeled AMC7135 act in the same manner, have the same characteristics for our use?
There are different numbers on it sometimes, different manufacturers, and sometimes the Vdd pin is called Vin.
Whenever the AMC7135 is mentioned, are we talking about the same thing?
My mods in my flickr sets
Pavithra_uk
Pavithra_uk's picture
Last seen: 2 weeks 4 days ago
think
Input Voltage – Output voltage (LED Forward voltage) x Current = Watts Waste as heat
Its better to keep voltage difference less than 1V withing 7135. otherwise power waste & will not survive 7135
Chicago X
Chicago X's picture
Last seen: 8 years 7 months ago
For reference, courtesy of CPF member Download:
http://wardogsmakingithome.org/index.html
War Dogs, Making it Home - Rescue Dogs for Returning Vets
Rufusbduck
The board I used is Dx sku 7612 and though from the description it sounds like it is in parallel with the single mode board. It is, but only in the sense that the processor circuit on each multi-mode board is in parallel with the drive circuit connected to the amc 7135 chips and yes, it does work. That part is straight from the Oldlumens/Techjunkie and will work with any 7135 board, single, multi, whatever. Just run two leads from Vbatt+; one to led+, and one through the reed switch to the board. Power is always on to the led but current only flows when the Vdd pins on whatever board you are using are switched on. This part is tested by many others and verified most recently by me just yesterday. Afaik, all 7135 chips are have the same outward topography, that is, they all look the same aside from printing, and the pins are all in the same relative position. Apply more than 2.7V to Vdd, and 350 mA can flow through the chip from led- to ground. This is the trick. If you’resoldering skill is up to it, you could concievably make an 8-chip sandwitch with no board at all. I say the 7135 chips on the processor board are not in use because they aren’t. In my circuit, there is no lead from led- to the chips on the processor board, only to those on the slave board. My circuit is only using the throughput of the slave board, 1.5A.
Scott
Rufusbduck
!http://i10.photobucket.com/albums/a102/udownload/3xP7DriverSetupb.jpg!
Yes, this is the method I referenced for using the leds to lower the voltage to the board and got me to wondering about other possibilities. Someone had mentioned combining this idea with The Oldlumens/Techjunkie master/slave mod but I could find no other reference to such a combination. Like I said, since the high current of the leds does not flow through the multi-mode processor, why not just put all the leds in series and use a much smaller resistor to lower the input voltage to the multi-mode processor?
Scott
Rufusbduck
Pavithra_uk wrote:
think
Okay, I have read in Download’s thread mentioned above that his idea would work with lower Vf xml and xpg chips only if a high wattage resistor were used to step the initial fresh battery voltage down to ~ 3.6V per cell. Maybe an inline .33 ohm 5W resistor connected to an on-on switch. This would have the benefit of reducing the resistance needed for the onboard resistor for the multi-mode processor. A fuel guage would help note the correct time to switch out the large resistor.
Scott
Rufusbduck
The questions being raised are to the point and are welcome as they will lead to solutions. Does anyone have any ideas about measuring the current in the control/enabling part of the circuit. Has anyone put a clamp meter around the switch wire leading to the master board in an Oldlumens/Techjunkie setup?
Scott
Rufusbduck
Looking at the Add tek data sheet for the amc 7135 sot-89 it says that the current consumed at the Vdd pin is 200 micro amps or .2 mA. This is for each chip on the board, so a 1.4 A 4- chip board would need .8 mA (.0008A)and an 8× 7135 board would need 1.6 mA shared between all of the Vdd pins on the board. It also says that the sot-89 package, which is the one commonly seen on drivers, can handle ~ 700 mW or ~ 2V excess at 350mA output. This equates to a max of about 5.3 V at the output for a single led with a Vf of 3.3V. This is all speculation on my part so far but for a board to drive 4 xpg from a 4-cell Li-ion:
4 × 4.2 = 16.8 V
4 × 3.3 = 13.2 V or 3.6 V excess. To get the excess within spec of the chips, I would need to lower the hot battery voltage by 1.6 V. 1.6 V / 1.4 A = ~1.1 ohms and 1.6 × 1.4 = 2.24W equals the power consumed in the resistor. Note, this is power that would otherwise have to be burned off by the 7135 chips, so it is no more wasted than it would be otherwise.
On the processor side of the circuit, the input voltage would need to be lowered from 16.8 down under 6V or a total of 10.8 V. So 10.8V / .0008A = 13.5 k ohms and the wattage would be 10.8V x .0008A = 9mW, not a problem for a 1/10 W surface mount resistor. So what happens when the battery level drops to ~ 3.7V per cell or 14.8V? 14.8V – 13.2V = 1.6V and we no longer need the 1.1 ohm resistor. A fuel guage on the battery would be helpfull in determining when to switch out the resistor. For the processor, 14.8V – 10.8 V = 4V and the driver is still within spec. At about 13.5 Vm, the voltage to the processor would drop to 2.7V and possibly shut off. In reality, under load, Vbatt would drop immediatly and such a high value resistor might not be necessary. If under load Vbatt was only 4V per cell or 16V total, then the resistor would be: 10V / .0008A or 12.5 kohms and the input voltage to the processor would drop to 2.7V when cell voltage was at 12.7V or ~3.2V per cell. At this point the leds are already begining to be underdriven. This happens whether cells are in series or parallel. The ideal would be to have the leds begin to dim and have the resistance set to kill the lights nearer to the low voltage cutoff of the cells ~3V. The push behind this idea is that for bike lights, which often have the lamp in one location, the switch by your thumb, and the cells in a third location, having wires with several amps running though them(as is needed for parallel circuits) is not the best solution. Having your light all in one body would solve this at the expense of having to take one hand off the bars to switch modes; not for me on rocky singletrack.
Scott
NightCrawl
Last seen: 5 years 10 months ago
I really like your ideas tho I dont quite understand half of it.. but if you use 4 cells and 4 leds, why not just go direct drive or..
If it really is possible to use the AMC chips in series like shown in the picture above, why still use a driver board rather than just wiring up the AMCs without processor and stuff?
Rufusbduck
If you are referring to Downloads diagram(by the way, thank you ChicagoX for posting that image) what it shows is the need for reducing Vbatt(the voltage from the battery, to the processor not the 7135 chips. The diagram in the method used by Oldlumens/Techjunkie shows that the processor can be powered separately from the LEDs using a low current through the processor on a master board to control the led current on the slave boards.
In a nut shell, modes and runtime. I don’t need high output grinding slowly up hill but coming down I need to see every root, rock, and rut, and I need to have hours of run time without extra batteries. DD would work but have no modes and lousy run time. Actually, while I was searching info on these chips I ran across some Soeul stars with two 7135 chips and a diode. The first piece of info in the data sheet for the Amc 7135 reads “no external components needed”. Another tidbit was that the T0-252 package for this chip is rated at 1000 mW which would take care of the higher voltage drop I need without using a 1.1 ohm resistor or extra switch.
Scott
Rufusbduck
Actually, 700mW is the max without additional heatsinking. So with a good enough path to ambient(I’m talking ground tab soldered directly to solid copper, not the measly foil on these board, and definitely separate from the led heat sink, even the smaller sot-89 might handle the load. Before I do that I want to verify the input resistor value for the processor. Anyone ever heard of a 10k-15k ohm linear pot? If I start at 15k and reduce the resistance until the processor goes poof I’ll know the minimum value needed.
Scott
Rufusbduck
Actually, a reverse audio taper would give me more accuracy at the high resistance end of travel. I checked and these are not cheap. Better would be a 10k-12k ohm resistor in series with a 5k or 3k linear pot.
Scott
ma_sha1
ma_sha1's picture
Last seen: 1 year 4 months ago
Indeed, a resistor is needed if using Download idea to drive 3-4 XMLs in series,
otherwise, too much heat may be shed onto the 8×7135 driver board & may burn it out.
I had a build a while back, tried out different resistors. Different battery & XML vfs may need fine tone the resistors
Example here:
http://www.candlepowerforums.com/vb/showthread.php?310854-Triple-XML-Yard-Sweeper-Mag-2C-3-mode-with-3x-IMR-22430
DrJones
DrJones's picture
Last seen: 5 years 8 months ago
I advise against using a resistor for the logic supply voltage (MCU and AMC7135s). The current of these can vary quite a lot (e.g. with PWM), which would result in a wildly hopping supply voltage.
Alternatives: Voltage regulator like 7805, available in various form factors, including TO-92 and SMD. Or resistor and zener diode.
Rufusbduck
The data sheet for 7805 indicates other components unnecessary but schematic shows capacitors on input and output. Are they needed with a battery power supply?
Scott
PilotPTK
Last seen: 7 years 12 months ago
Very much agreed. When the logic is idle, it could be drawing half or less of the rated current – this would cause it to see a much higher voltage. Resistor and zener is the way to go. Choose a 5V zener and a, oh, I dunno, 1k ish resistor… That will allow the logic to pull a couple of milliamps when/if it needs to..
PPtk
I am currently extremely busy with work. Please do not expect a response from me quickly. I will be dropping in as time permits, but the amount of time I can dedicate to responding to topics and PMs is very limited.
Rufusbduck
Ok, it makes sense that the input voltage would fluctuate to the attiny pwm chip if I just use a resistor. What makes the resistor + Zener preferable to the “black box” approach of the 7805? Is it more efficient, cleaner, or what? Thanks for this input. I enjoy going outside the box but I fully realize this makes me vulnerable to mistakes. I’ll throw my pride under the bus for knowledge anytime.
Scott
Rufusbduck
So I found a half dozen 78L05 in a SOT-89 package(same as 7135). Operating voltage 6.75V-26V. Output current is 100mA. Atmel chip draws .24 mA and four 7135’s draw .8mA so there should be plenty. I thought I would desolder the 7135 closest to the Atmel chip,“stack” in on on of the others, and put the 78L05 in its place. It would not be soldered to the pin pads other than ground, I would have to jumper across/in place of, the reverse polarity diode from the 78L05 in/out pins. Again, the data sheet says no additional components needed, but could signal bounce from the pwm chip cause problems in the 78L05? Should there be a .1 microfarad cap from the output of the 7805 to ground?
Scott
PilotPTK
The 78L05 is a good choice. The resistor and zener isn’t better – its just cheaper Smile
I wouldn’t worry too much about cross-talk and radiation from the PWM into the regulator. Yes, you should try to cobble a .1uF cap on the output though. If there’s room, a .1uF and a .01uF, in fact.
Rufusbduck
I only paid $.50 each for 6. Where would the .01 cap go? Also across the output? Or one on the input, one on the output? Saw a diagram with .33 microf on the input and .1 on the output. How critical are the values(other than voltage capacity)?
Scott
PilotPTK
Values aren’t super critical for an application like this. You don’t really need cap on the input, but the .1 and .01 on the output (in parallel) is a good idea. If you don’t have any .01s, just the .1 will probably be fine.
Rufusbduck
I’ll be waiting awhile for the 78L05 chips to arrive but in the meantime I’m working on a drawing that shows how this works. I’ve studied close ups of a few different boards and I like what I see. In each one that I examined, it appears that the 7135 chip closest to the processor and led+ pad could be replaced with a 7805 SOT-89 voltage regulator. I would need to cut the traces leading to the other 7135 chips and jumper the led+ pad to the input pin on the 7805 and the output pin to other side of the reverse polarity diode. An smd cap across the output pin to the ground pin and done I’ll try an make the next post with fewer words and more pictures. Check back in a week or two. This could be a way to use these boards with more options on battery voltage.
Scott
Rufusbduck
Still waiting on the 5V regulator chips but I’ve made up a dedicated board for the 4 7135 chips which is just a copper sink with a crenelated cylinder for the chips. I want to see how much excess voltage they can handle when they are mounted this way. They are rated to 700mW per chip in free air but the specs don’t give an absolute limit on wattage, just temp at 150C. As the chips are in parallel, each has to drop all of the excess voltage. One of the graphs in the spec sheets plots dropout voltage(voltage burned by the chip) vs output current and tops out at ~4V! At 350mA that’s 1.4 watts per chip folks! The heat sink capacity reccommended for them is WAY more than can be supplied by the boards we typically use and I suspect that even when stuck to a large heat sink the traces constitute a bottleneck in the flow of heat. Stay tuned. Here are some pics:
The first is a virginal Dx 7612 1A 16-mode board
The second is another 7612 with the input diode and the three 7135 chips removed and the traces cut to the Vdd and output pins of the Q3 pads
And the third shows the heat sink with one of the chips placed
I have several battery voltages that I can test and I want to find out how well this heat sink works. The sink will get some clean up work and pretinning done to it before assembly.
Scott
Rufusbduck
Pavithra_uk wrote:
think
Running the LEDs in series is no more or less efficient than in parallel. Power loss = voltage drop across the 7135 chips x the current through each of them.
4 xpg in parallel from 4 Li-ion and 4 boards(1master, 3slaves) at 1.4-1.5A =
(4.2Vb – 3.3Vf) x 16(350mA) = 5.4W
4 xpg in series from 4 Li-ion and 1 board =
(4 × 4.2Vb) – (4 × 3.3Vf) x 4(350mA) = 5.4W
The difference between the two is the battery current (6A vs 1.5A) and the heat being dissipated across 16 chips vs 4. The input voltage to either the Attiny 13A(multi mode) or 7135 Vdd pin(single mode) is a separate issue with a separate solution. I believe it is the boards as currently used that limit the range of use more than the chips. While I don’t expect to be able drop almost 4V into each chip, I suspect we can do much better than 1V. If not, I’ll be sure to post the sauce I use on my crow dinner.
Scott
Rufusbduck
The voltage regulator chips should be in tomorrow. I reflowed the 7135’s to the sink last night so I might have some test results by the weekend.
Scott
sixty545
Last seen: 3 months 5 days ago
Sorry, I have not read the whole thread carefully but the way I understand this, in a PWM situation the voltage across the 7135’s can switch between 0V and 16.8V. Have you considered that the 7135 are only specified to 7V max ?
Well, this could easily be remedied by a zeener diode across the 7135’s (z6.3V or like) to limit the voltage so I think that your circuit is sound enough.
Rufusbduck
Cpf Download shows in the thread kindly referenced by ChicagoX above how LEDs can be used to lower the voltage drop across the 7135 chips. The dropout voltage of the chips is the limiting factor here, not the total voltage of the system. I first read that thread before I even joined BLF and have reread it several times since then. Also, OldLumens thread, “the much sought after master/slave mod”, in which he collaborated with Cpf Techjunkie, has been a great resource. The ground work for this idea was laid in those two threads. The voltage drop in a system is equal to the sum of all of the voltage drops in that system. 7135 chips were designed as led drivers. It is assumed that at least some of the 6V max will be dropped across the “assumed” led. From the spec sheets, the actual max Vdrop is 4V and that only with very good heat sinking. As in Downloads version, I am using a series of LEDs to provide some of the voltage drop in the system. I am also using the Techjunkie method of splitting the Led circuit and the driver circuit and using a link wire to control the 7135’s as slaves. What I am adding is a separate method of lowering the voltage in the driver circuit.
Scott
sixty545
When PWM switches the current off, the voltage drop across the LED’s will go towards zero at a speed determined by the capacitances in the system. Hence the voltage across the 7135 will rise towards the battery voltage.
But good luck with your project!
Rufusbduck
sixty545 wrote:
When PWM switches the current off, the voltage drop across the LED’s will go towards zero at a speed determined by the capacitances in the system. Hence the voltage across the 7135 will rise towards the battery voltage. But good luck with your project!
I had wondered about that(not really. I’m obviously not an engineer) but postulated, perhaps incorrectly, that the same situation occurs in Downloads method without negative effects and that maybe the location of the LEDs in the circuit was relavent only to the input voltage of the Attiny chip and the Vdd pin on the 7135’s. I’m just using a different method to lower ther processor input voltage than him.
Scott
WalterK
While we are waiting for DX,… could you post a pic of the sink with AMC’s?
Did you reflow as you would reflow a led on the star, or did you first reflow the sink with tin and then soldered the AMC’s to it?
