Test / Review: Solarforce 18650 V3
9 posts / 0 new
old4570
Last seen: 18 hours 10 min ago
I needed a pair of 18650 batteries , and noticed Solarforce had a new battery out ! So the money was pent : And there here .
18.3mm in Diameter at the widest point
67.8mm Long
http://www.solarforce.hk/index.php?controller=products&action=view&id=94 Link to product page .
http://www.solarforceflashlight-sales.com/product_detail.php?t=BC&s=23&i… $7.50 each + postage [ $2 usually ]
Discharge Test for AMP draw !
Test = Two P60 XM-L flashlights ( 1L and 2L ) measuring current draw to see how capable the batteries are of delivering power.
Solarforce V2 , 4.2A -1L , 4.1A -2L
Marsfire 18650 [ Sanyo ] , 4.3A -1L and 4.3A -2L
Generic Panasonic 3100 with protection , 3.8A -1L and 3.8A -2L
Solarforce V3 battery1 , 4.1A -1L , 4.26A -2L
Solarforce V3 battery2 , 4.7A -1L , 4.57A -2L
The new V3 can certainly deliver the power :
Ive done a 1A discharge , and it resulted in some 2473mAh to 2.7v [ 2.7v the over discharge protection kicked in ] +2nd Battery did 2460mAh + / Update ! Batt No2 - 2473mAh 1A
Batt No1 – 2460mAh @ 1A
I am currently charging the batteries but will add 2A and 3A discharge results .
2A Discharge …
Batt No2 did 2522mAh to 2.7v [ Protection kicks in at this point ]
OK 3A test ……. FAIL !
One battery did 774mAh 3A, and the other battery did 1086mAh 3A
I will run both again @ 2A and update ..
2nd time around @ 2A discharge
Battery2 2427mAh
Battery1 2334mAh
Both batteries failed badly at 3A discharge , so cant really give these the thumbs up for high power applications , nor for multi battery set ups .
Up to 2A , in a single light application , they may perform well , who knows .
Some times we get chocolate , some times we dont , this is one of those times , no chocolate !
What we have is a very average battery , I cant condemn it , but at the same time I cant really praise it either as there are better batteries out there for about the same money .
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
Edited by: sb56637 on 08/26/2014 - 17:45
NightCrawl
Last seen: 6 years 4 months ago
Thats a pretty huge difference.. are you planning on measuring the capacity of both cells?
old4570
Plan is to test both yes !
But it all takes time ! , discharge test is a little extreme but yes a fair difference .
sb56637
sb56637's picture
Last seen: 10 hours 28 min ago
Thanks so much for the test! Sticky’d.
cbr400rr
By the pictures you posted I am assuming they won’t work with flashlights use button style positive sides? Aka. Eagletac. I know the v2 had buttons. I was about to order some too..
old4570
Recessed head , not good for lights with a driver or contact board less spring [ Simple enough to solder on a blob of solder – driver – not battery ]
My brother just parted with his Himax 18650’s , as he does not like the maintenance [ watching voltage levels etc ] , so 6 Himax batteries to me . I got these for my TK35 clone , but put in a well matched pair of Himax . But one should expect some variance at max current levels [ or near max ] , obviously closer is better .. Excuse the speed I do this at , as I just picked up a horrendous flue , was in serious pain last night [ Sinus pain , which made my teeth ache something awful ] so not much sleep . Will do some more discharging today !
Noodles
Noodles's picture
Last seen: 3 years 10 months ago
Thanks for checking these out Smile
It is nice to see a protected cell 18.3mm in diameter instead of some of the Panasonics or others with pcb added making some of them come in @ 18.5-18.7mm in diameter. Some of them make for a tight fit in some tubes.
Edit: does the wrapping seem more durable than the older 2400s?
The Giggle Loop
old4570
Does appear to be ! yes ….
2nd battery discharged = 2460mAh @ 1A
The other battery is doing a 2A discharge ATM
old4570
Well , up to 2A both batteries were average [ not good not bad – middle of the road ]
Butt ! and its a huge Butt! , they failed on the 3A discharge , 774mAh and 1086mAh @ 3A is not impressive , not when discharged to 2.7volt , this is obviously a failure point . For high power applications or multi battery set ups , I would suggest looking else where for a 18650 , I cant condemn the V3 but I cant praise it either , a very average battery .
