Well, if that XM-L disc with 5 emitters is made of copper, then it could have turned things around. Someone needs to do a IR temp readout of that white aluminum emitter disc.
Its probably not so much of the surface area of the host touching that big disc. If you divide that area on the host by 5, it seems to be “ok”. I mean you have XM-L on MCPCBs as small as 10mm (and some are smaller even), 16mm is pretty common.
Issue is that heat HAS to travel to the edge to “bleed it off”. Conventional 16mm MCPCBs do it with 100% contact underneath.
Of coz i am not saying that this is a bad design, it probably is ok for 1.5A thereabouts…. it probably would hit the ceiling if it were 2.0A and not provide much additional output.
Well I’m not trying to be smart or a wise guy I’m just having an opinion like you are - you say I didn’t read the post above but did you? He also said it wasnt scientific and to take it with a grain of salt.
I didnt say the tm11 was as bright as king/dry/apex, but the tm11 has been measured in a sphere to be 2000 lumens OTF, so holding the apex and the tm11 together I see my apex as 50ish% brighter and after 8 min the tm steps down but apex is the same brightness and isn’t hot to touch like the tm. Darkside said basically the same thing above. So the king is brighter than the tm11 no doubt - they use the same 3 xml’s but king is driven harder but I see no differance in size of the body to the tm and as the tm is driven lower and still gets almost too hot to hold after 8 min surely you can’t tell me the king is doing fine other than for short bursts of a few minutes without doing some damage to it soon. (but I guess that’s whats good about budget lights)
The TM11 came out first and the king was a copy (because i said its a ripoff) you seem touchy about the king because you own one and I’m sorry I didn’t mean to offend (I don’t doubt that it may be brighter than the apex/dry as I have never had one) technology changes fast and brighter things will always come out as I have found in this apex.
I look like i am new to this forum, but I have been buying and selling lights for over 20 years (especially led lights in the last 8 years) costing anywhere up to $2000 each for custom lights - this isn’t to boast all I am saying is I’ve had tons of the brightest production and rare custom lights out there made so I can honestly say I know a little, I have just recently got back into the buget lights as I’m finding them more fun of late as they are cheap and the quality has become better and the suppliers are happier to push the boundaries for the sake of a sale, but in all honesty I would trust my life to a custom any day.
One thing I have noticed with the cheaper Chinese lights are they aren’t consistent in manufacturing and output - example: I have bought 3 exact same custom lights they are all the same in tint/output/finish and reliability because they hand made and the LEDs are hand picked, I have bought 10 of the same (what I thought was good value cheaper lights to help coworkers get a half descent light and they still complain is expensive for a light) and there are inconsistencies between almost every light in color/tint/output/bad threads/chips.
I’ve just received this (the cool white version), and am extremely disappointed by the output.
I also have a Nitecore TM11 (cool white), and my TM11 is BRIGHTER than this Apex 5T6 … no doubt about it. Tested with the same four 3100 mah fully charged batteries, doing celling bounce tests. Not only is the TM11 is brighter, but it has a wider spill beam.
Build quality and finish is _excellent _though, and its one good looking torch.
Don’t know if I received a dodgy sample, but I’m e-mailing RIC about this and hoping he comes up with a good solution.
Cheers
d337944
Update: RIC suggested I measure the current to the led - I’ve done so and am getting only about 1.1 - 1.2 A per lead, meaning much less than “3000 lumen” in total! I’m assuming its just mine that’s dodgy … but also note from others’ measurements the Apex 5T6 is not as bright as claimed.
Hey there JustFit … true, my Apex may produce around the 2200 lumen mark - though _still dimmer _than my Nitecore TM11 - but what I was disappointed about was that I paid money for a “3000 lumen” flashlight and it certainly wasn’t anywhere near it.
If you don’t have anything around the 2000 lumen mark, the Apex will blow you away and you’ll love it! As mentioned the build quality, design and finish is really top notch. However if you want a 3000 lumen product, look elsewhere.
YMMV … other samples may be brighter than mine - I think mine is just a bit “dodgier” than normal …
For the money its still a good product, and RIC looked after me well.
Yeah most definitely this is not a 3000 Lumen light. I think its only around 2000-2250 OTF. Ceiling bouncing it against my TR-J12 the two are about the same, If anything the Apex is maybe a little less. But it could also be the warmer color tint of the Apex playing tricks on my eyes.
Numbers don’t lie!!! Look at the graph and plots. The skyray king has a very stable ceiling bounce output, with relatively little thermal dimming, Despite its LEDs being driven harder than the Apex. IMHO they made a big mistake on the Apex not copying the thermal design of the SR king. The king has its LED heatsink thermal pasted directly onto the aluminum plane that spans the inside diameter of the heatsink bezel. Screws sandwich the LED heatsink between the Aluminum plane and reflector array assembly. The Apex is a completely hollow tube, where the LED heatsink only contacts the bezel around the perimeter. It also looks like they could have used more thermal paste, and a better conducting one like AS-5.
I took the fam out to see a local firework show and had the Apex on HI for a good 30 minutes straight during the night-walk home. With the cool night air circulating it got warm but was no where near hot enough to cause concern. So I think its definitely a GREAT constant-on kind of task-flood light and most importantly for me NO DISCO!!! (that element alone keeps the SR king off my list).
I’d take mine apart if I could, but mine is SOLIDLY built. Seriously I pulled a ligament/muscle in my left wrist wearing rubber gloves trying to unscrew the Bezel on my light. I would add a copper plate and some AS-5 under the LED heatsink. It looks like theres plenty of room in there to play around. I would be a little hesitant to mess with the current sense resistors though, without having a backup source for the OEM driver.
EDIT I just looked at the graph more carefully, focusing more on the Apex VS J12 and my two lights seem to exactly match the data presented in the plots. At no point in my ceiling bounce comparisons does my Apex appear brighter than the J12. The J12 also gets warmer to the touch, and seems to thermally dim at a faster rate than the Apex.
I just killed 1 driver and I have 1 waiting for me . I’ll bench test the new driver with a test load and should be able to
reset and keep it alive. Hopefully output should be set according to spec but i can say that none of the Apex drivers i tested were close…
