I’ve just received this (the cool white version), and am extremely disappointed by the output.
I also have a Nitecore TM11 (cool white), and my TM11 is BRIGHTER than this Apex 5T6 … no doubt about it. Tested with the same four 3100 mah fully charged batteries, doing celling bounce tests. Not only is the TM11 is brighter, but it has a wider spill beam.
Build quality and finish is _excellent _though, and its one good looking torch.
Don’t know if I received a dodgy sample, but I’m e-mailing RIC about this and hoping he comes up with a good solution.
Cheers
d337944
Update: RIC suggested I measure the current to the led - I’ve done so and am getting only about 1.1 - 1.2 A per lead, meaning much less than “3000 lumen” in total! I’m assuming its just mine that’s dodgy … but also note from others’ measurements the Apex 5T6 is not as bright as claimed.
Hey there JustFit … true, my Apex may produce around the 2200 lumen mark - though _still dimmer _than my Nitecore TM11 - but what I was disappointed about was that I paid money for a “3000 lumen” flashlight and it certainly wasn’t anywhere near it.
If you don’t have anything around the 2000 lumen mark, the Apex will blow you away and you’ll love it! As mentioned the build quality, design and finish is really top notch. However if you want a 3000 lumen product, look elsewhere.
YMMV … other samples may be brighter than mine - I think mine is just a bit “dodgier” than normal …
For the money its still a good product, and RIC looked after me well.
Yeah most definitely this is not a 3000 Lumen light. I think its only around 2000-2250 OTF. Ceiling bouncing it against my TR-J12 the two are about the same, If anything the Apex is maybe a little less. But it could also be the warmer color tint of the Apex playing tricks on my eyes.
Numbers don’t lie!!! Look at the graph and plots. The skyray king has a very stable ceiling bounce output, with relatively little thermal dimming, Despite its LEDs being driven harder than the Apex. IMHO they made a big mistake on the Apex not copying the thermal design of the SR king. The king has its LED heatsink thermal pasted directly onto the aluminum plane that spans the inside diameter of the heatsink bezel. Screws sandwich the LED heatsink between the Aluminum plane and reflector array assembly. The Apex is a completely hollow tube, where the LED heatsink only contacts the bezel around the perimeter. It also looks like they could have used more thermal paste, and a better conducting one like AS-5.
I took the fam out to see a local firework show and had the Apex on HI for a good 30 minutes straight during the night-walk home. With the cool night air circulating it got warm but was no where near hot enough to cause concern. So I think its definitely a GREAT constant-on kind of task-flood light and most importantly for me NO DISCO!!! (that element alone keeps the SR king off my list).
I’d take mine apart if I could, but mine is SOLIDLY built. Seriously I pulled a ligament/muscle in my left wrist wearing rubber gloves trying to unscrew the Bezel on my light. I would add a copper plate and some AS-5 under the LED heatsink. It looks like theres plenty of room in there to play around. I would be a little hesitant to mess with the current sense resistors though, without having a backup source for the OEM driver.
EDIT I just looked at the graph more carefully, focusing more on the Apex VS J12 and my two lights seem to exactly match the data presented in the plots. At no point in my ceiling bounce comparisons does my Apex appear brighter than the J12. The J12 also gets warmer to the touch, and seems to thermally dim at a faster rate than the Apex.
I just killed 1 driver and I have 1 waiting for me . I’ll bench test the new driver with a test load and should be able to
reset and keep it alive. Hopefully output should be set according to spec but i can say that none of the Apex drivers i tested were close…
I would also add the possibility of employing U2 emitters. That alone would up the ante.
As Chicago X implies, it also seems that it is underdriven. How much could it cost to change that?
About the Center Emitter - I’m not convinced it needs it but I woudln’t be against it - and it would probably be difficult for the manufacturer to add (not to mention the lack of heat sink in the middle).
The solid copper heatsink would certainly be a plus:
It would more easily allow the addition of a 6th emitter.
It would allow the existing emitters to be more highly driven - either by a higher output driver - or by 2 drivers.
By the way, I would be interested in this wide-beam light if it had NW emitters as an option.
And last, but not least, I really like the look and the handle!
