Sorry for my English.
Some thoughts about the driver of the “”Kaidomain”:http://kaidomain.com/product/details.S020417”.
The most important thing is to protect against overheating above 50-55C
I tried to connect a 12V car battery. Currents immediately begin to fall, after 4 min current is 1.2 A (14.4 W to the driver). Dipped into the water head torch, the current up to 2A (24W to the driver).
Wow! thanks for sharing those thermal images lishat, and welcome to BLF! Can you please share information about your thermal imaging setup?
Welcome to BLF
Please tell us for thermal camera setup and about measurement. What I can see you noticed high temps around 62. It is at 100% power from driver or lesser?
WOW thats some impressive analysis… 19C increase at the 6:00 mark.
x2… was that done using the 100% setting? I would expect higher than 50C with a ~55-60 Watt driver.
cant wait to see lumen measurements with the new driver installed.
also that thermal imaging is awesome!
Is 60°C worth worrying about, considering max. operating temp for XM-L’s is 150°C?
Looks like 2:00 runs are pretty good with this new driver. Something like the DRY.
It's good to have you here, Ilshat!
can we just like stick whole bunch of copper wires in the springs and stick bunch of solder in there almost making it solid ? lol
Flashlight working at maximum capacity, here are the LEDs on the thermogram of the time.
Installation on the thermal camera was by default, “factor of the black body ɛ = 0,97” “70% humidity.” I do not know what “factor of the black body” at the LEDs, torch, probably between 0.8 and 0.95. The following thermograms at different «ɛ».
I measured the currents in dependence on the heating flashlight. Household devices are not calibrated, but quite accurate.
After heating the flashlight I dropped it in cool water.
Diagram of currents from the car battery 12.5 V.
I do not know what it means 7A (7A * 12.5 V = 87.5 W) O_o
So at the ~1 minute mark, power draw drops to 31.5 Watts, and for most of the run its drawing less than 25W.
Is that the drivers thermal regulation kicking in?
X100 doing 38W, with 2S! And its a 7 x XM-L so that’s even more efficiency. Calculated from ergotelis measurements then it could be 3800 lumens OTF in real life.
Not sure if i can stick the J12 tube into the X100 head. It looks like it though……
Looks like the X100 has something like the 7 LED driver version.
so the j12 and x100 only differs the head cause of 7 vs 5 leds ? but the x100 loooks alot brighter isnt it mayb because of the wide head or better drivers ?
5 LEDs -> 7 LEDs has a bit of advantage due to efficiency. Eff slowly goes down as you approach 3A, esp so from 2A to 3A range. (check out the graph). It is not a lot, but every bit counts for us flashaholics.
Wider head maintains the reflector size (more or less) so that the hotspot size is the same but now you have 7 instead of 5…something like that.
More powerful driver - yes. Say, you have 1.7A to 7 XM-Ls now, instead of 1.6A to 5 XM-Ls.
Everything adds up. It seems that the X100 pumps out even more power with 2-cells/2S compared to 3-cells/3S. 3S gives you about 3300 lumens OTF with 33W at the tail. 2S measures 38W but no OTF measurements.
Check the Monster light X100 thread, dong changed that to the KD 7-LED driver! (41-42W)
comparison pics of modded & unmodded j12? Underwater lithium flashlight, now that’s scary!
I got my http://kaidomain.com/product/details.S020417 driver for a TR-J12, put it in………
and it is not working as advertised………. on HIGH it’s only pulling 0.4A!!!
Batteries is 3 x Trustfire 3000Mah………
Tried with 4 x Trustfire 3000Mah…… and HIGH went to 2A
Don’t know if I got a ‘dummy’………
and ideas??
Regards
Hugo
I’d suggest that your batteries are not up to the task if the driver mod has been done correctly.
try with 3 26650 King Kong batteries… you will see the result much differently
