Just ordered one from easylightbuy too. Looking forward to seeing it in a month or so
Last order took 11 days with CN post, previous order placed May 20 arrived 9days later. That one used HK post. Quick deliveries to Sweden I think
ANyone tried to Mod this light with a 17mm NANJNG driver?
Thanks
EDIT:
Just realized that twisty lights use different type of driver, Now I have two of this that I can’t mod, Love the size and form. It would have been great if this have a lower low.
Got mine today and It’s a beauty,can’t wait to get home to see how mighty it is
I will get back with lux readings
interesting this would have to be smallest and brightest lilttle thing ? when its 10$ i get some
Just got a lux meter, and I think I can get pretty close on lumens/lux judging by known sources like my Zebralights. I am getting approximately 550 lumens on high and 80 lumens on low with this light. Around 2000 lux on high as well.
Edit: 533 lumens on high, 69 lumens on low.
Good to know Techmo!
I will order one soon, are you dajabec on CPF by any chance?
Yep that’s me. I’m usually use dajabec on forums but I tried Tecmo on a whim and when it was open (shocker) I stuck with it.
My Mini-01 arrived the other day. I ordered one after reading about them here
They are a great little light.
I’m using LifeP04’s in mine.
I noticed the maximum rated voltage is 3.6volts. Is it safe to run 3.7v(4.2v) 16340’s or IMR’s in this light?
Cheers
Matt
Welcome to the forum, MattSPL!
Thanks
Hi Matt
you should be OK with those batteries the voltage will drop under load
welcome to BLF
Barrie
10$ group buy or something ? who wants to approach Chinese distributor ?
count me in for 3 at $10
Barrie
If there’s going to be a group buy, count me in also. :bigsmile:
I am in too!
Thanks Barrie
I’ve just ordered a couple of Yezl 16340’s to try. They are rated at 3.2A max discharge, so should do the trick.
Cheers
Matt
enough people say i am in say 50 people i’ll approach a distributor on alibaba
I’d love one or two
Hmm… I think those batts are high end? Any budget options? UF protected? (grey ones)?
I like Trustfire flames but I think its too big for this baby. Thx
