interesting this would have to be smallest and brightest lilttle thing ? when its 10$ i get some
Just got a lux meter, and I think I can get pretty close on lumens/lux judging by known sources like my Zebralights. I am getting approximately 550 lumens on high and 80 lumens on low with this light. Around 2000 lux on high as well.
Edit: 533 lumens on high, 69 lumens on low.
Good to know Techmo!
I will order one soon, are you dajabec on CPF by any chance?
Yep that’s me. I’m usually use dajabec on forums but I tried Tecmo on a whim and when it was open (shocker) I stuck with it.
My Mini-01 arrived the other day. I ordered one after reading about them here
They are a great little light.
I’m using LifeP04’s in mine.
I noticed the maximum rated voltage is 3.6volts. Is it safe to run 3.7v(4.2v) 16340’s or IMR’s in this light?
Cheers
Matt
Welcome to the forum, MattSPL!
Thanks
Hi Matt
you should be OK with those batteries the voltage will drop under load
welcome to BLF
Barrie
10$ group buy or something ? who wants to approach Chinese distributor ?
count me in for 3 at $10
Barrie
If there’s going to be a group buy, count me in also. :bigsmile:
I am in too!
Thanks Barrie
I’ve just ordered a couple of Yezl 16340’s to try. They are rated at 3.2A max discharge, so should do the trick.
Cheers
Matt
enough people say i am in say 50 people i’ll approach a distributor on alibaba
I’d love one or two
Hmm… I think those batts are high end? Any budget options? UF protected? (grey ones)?
I like Trustfire flames but I think its too big for this baby. Thx
I’m getting good results with Ultracell 16340 LifeP04’s off ebay. £1.56 for 1 including free postage.
The have an unrealistic 1200MAh printed on them, but i’m getting the same performance as AW’s 500mAh lifeP04’s.
Only thing is with them not being protected, there is the danger of running them too low in the little Mini-01.
Cheers
Matt
I’m in for one or maybe 2 at 10 $ per flashlight shipped…
Dunno what’s up, but someone said the magical words “TEN DOLLAR” so I’m in, too.
Same here! But make it 2…one for me and one for my son.
I’m in too! 8)
