Hmm… I think those batts are high end? Any budget options? UF protected? (grey ones)?
I like Trustfire flames but I think its too big for this baby. Thx
I’m getting good results with Ultracell 16340 LifeP04’s off ebay. £1.56 for 1 including free postage.
The have an unrealistic 1200MAh printed on them, but i’m getting the same performance as AW’s 500mAh lifeP04’s.
Only thing is with them not being protected, there is the danger of running them too low in the little Mini-01.
Good stuff
What charger are you using?
I’m using an Xtar mp2 on the 3v setting. Seems to be a nice charger.
I had an Ultrafire WF138A, but it was faulty.
Alright guys since you guys asked for it. Update on the group buy situation!!!
i’ve talked to the supplier on ali express and strike a deal!!!’
*if you buy 2 pieces it’ll be 26$
Coupon code: 15noorder20120614 – coupon $5 for orders larger than $25 can be used on Aliexpress.com but only once per account.
If you found some other good deal post here or create new topic.
TOTAL = 21 $ for 2 did i get everyone a good deal as promised ? just sign up new account :)* :party:
vu Tran(2012-7-14 10:7:14)
even 12 i think u’ll get alot of buyers from the forum
Mandy Li(2012-07-13 17:38:20)
freee shpping for 10usd ?
Mandy Li(2012-07-13 17:38:25)
vu Tran(2012-7-14 10:10:22)
lol dunno whats best deal u can do ? min order 2 for 25$ alli express –5$ discount = 20$ everyone happy!
vu Tran(2012-7-14 10:11:7)
even if u sell 2 for 30$ u’ll get buyers i reckon lol
vu Tran(2012-7-14 10:11:41)
try it with 100 units if it sells fast u’ll be suprise mayb you’ll sell thousands
Mandy Li(2012-07-13 17:41:50)
1 minite let me see the bottom pric for you
Mandy Li(2012-07-13 17:41:58)
ok?
Mandy Li(2012-07-13 17:42:01)
ask boss
vu Tran(2012-7-14 10:12:8)
sure
vu Tran(2012-7-14 10:12:42)
you guys shoudl support the forum i think alot of business through there yes!
Mandy Li(2012-07-13 17:49:54)
for 100unies
Mandy Li(2012-07-13 17:50:01)
13USD /pc
Mandy Li(2012-07-13 17:50:09)
Including shipoping
Mandy Li(2012-07-13 17:50:12)
is our bottom price
Mandy Li(2012-07-13 17:56:24)
u there?
vu Tran(2012-7-14 10:30:4)
yes
vu Tran(2012-7-14 10:30:19)
when can you get it in stock by ? i’ll let everyone know
Mandy Li(2012-07-13 18:01:25)
in stock now
Mandy Li(2012-07-13 18:01:29)
vu Tran(2012-7-14 10:32:1)
thanks can u add item to your website i’ll get people to start buying thehe
Mandy Li(2012-07-13 18:02:10)
ok
Yeah looks like I might need a charger aswell… right now I use mostly 18650 batteries that I use in that cheap ‘mobile power box’ with the mini-usb slot to charge from mains. I also have the ML-102 from intl-outdoor which is nice but I think I forgot to buy the aluminium spacers for it to charge 14500 (for my sipik sk68 clone), 16340, etc. Will see if Hank can’t throw those in my next order.
Your charger looks good based on reviews. Might look into that.
That ML-102 looks good. I hadn’t seen those before. I have an Xtar mp1 for my 18650’s but it only charges at 500mA. Your ML-102 will charge at 1000mA from the mains. I could do with that for faster charging.
My Yezl 16340’s arrived today to try in the Mini-01
They are protected cells with 3.2A max discharge. They are 3-4mm longer than the LifeP04’s, so a tighter fit in the Mini-01, making operating it a little stiffer due to the pressure from the spring. A mod to the spring might help ease of use.
The result is seriously impressive. This little light is SO BRIGHT now, and becomes a hand warmer very quickly.
I don’t have any measuring equipment, but it seems as bright as a 600 lumen light i have :bigsmile:
