Fulton Angle-Head Military Flashlight mods?
Beamshots plz :D?
I will take some later when I get home. 2nd shifter here so it will be after midnight when I post them.
I will say that the deep reflector makes this light a thrower of sorts, but it does have some side spill.
Lately I have thought about building a triple anglehead with some glow around the optics. 8)
Any light as a comparison to it you would like to see? If I have it that is. :slight_smile:
Distance measurement will be fine, but if you have something with similar led inside and around the same power draw, then it would be very interesting to compare :)!
Good product…but maybe aluminum version will be better?
It would be an expensive flashlight to machine, but I would love to see it made out of metal.
I will work on some beamshots tonight as it was raining very hard last night.
Wow! I have not taken any photos since I sold my Nikon D70s. So I used my son’s crappy Samsung camera, so please excuse the lame beamshots.
I will be buying a new camera soon.
The other light that I compared the anglehead to is a SS XR-E r2. The anglehead is an XP-G r5.
XR-E
XP-G anglehead
Both lights were place on the black car on the right.
Wow, that is a tight beam!
That looks pretty nice. Good job.
It is very tight. Like I said, it’s the best reflector I have seen for an XP-G if you want throw. It transforms the Fulton from below average to awesome!
I have added a custom glow o-ring made with IV line a v10 glow powder.
Here was a safety orange anglehead that I modded and sold. This one had the copper HS. I wish Fulton had of made these in Safety orange, unfortunately this was a chinese knockoff and the quality of the switch and belt clip show as it used screws vs. rivets.
Thanks!
I just started reading this thread, and am fascinated. I like my Fulton angle-head light, which I have put some sort of PR based LED in (I think, a Terralux 1 watt, but not sure.) It is some brighter than the original bulb, and the battery life is counted in months, but my AA MiniMag with Terralux LED out throws it, and is brighter! That’s just wrong! :wink:
Anyhow, I would like to make my Fulton better, and reading the posts about mods, I ran into a problem; I follow directions extremely well, but when it gets beyond “Glue this to that,and add this, like so, then, do that”… I tend to get lost. Reading through the instructions, I found the reflector/heat sink on DX, but Kai has sold out of the 1AA bost current PCB, and I am not sure what to replace it with, or where to get one. Any suggestions?
What does that thing do, anyhow?
Please school me: Would I run into any problems replacing the MC-E emitter the reflector is designed for with, say a Nichia 219?
Which Cree emitter would I need to provide a close to daylight color balance? I notice Nichias are rated at 4500 K, so I think about 4500-5500K would give good color differentiation and tint.
One last thing: I noticed one poster used Devcon 5 minute Epoxy to fasten the reflector to the assembly. I like the epoxy idea, but but iirc, heat will debond epoxy, and a necessary part of an assembly like that is heat transfer from the LED to the metal parts of the assembly, which I am not sure if regular Epoxy provides. Is there a better solution?
Dumb questions, I know, but any help will be appreciated. :slight_smile: Moderator; If this is not in the right place, please move it. Thanx.
You could spend a bit of money and get one of these.
http://www.king-cart.com/cgi-bin/cart.cgi?store=elektrolumens&product=Anglelux
I wasn’t sure about starting a new thread. I came across these ‘genuine GI issue’ from a UK based shop. I don’t know if they are Fulton or not though.
I modded this light in 2010 and it still works today and the epoxy has never separated from the heat sink.
I would use an XPG2 from Illumination supply in 5000k which is a nice tint.
Need any other help with this you can ask me here or PM me. Good Luck!
Here is a part list to get you started. The glass lens is a couple of MM small, but the o-ring can be used to center it.
Glass lens
Reflector for XPG
Good driver for single mode with 2 batteries
Multimode driver for 2 D setup
You can build your own light for less than that and it will be much better! Heck, I could build out someones anglehead for less than that.
It looks to be genuine.
Things to look for would be rivets on the switch and clip, vs screws on a knockoff. The name fulton industries MX-991u is usually in a raised letters in the circle on the top head of the angle.
Thanks for this
No problem! Post your progress.
