Review: Magnetic control diving light (Cree XM-L T6 | 1 x 18650)
49 posts / 0 new
_the_
_the_'s picture
Last seen: 3 weeks 2 days ago
Reviewer's Overall Rating: ★★★
Summary:
Battery: 1 x 18650
Switch: Magnetic side switch (Slider)
Modes: 7: From off to high with slider (7 levels)
LED Type: Cree XM-L T6
Lens: Glass
Tailstands: Yes
Price Payed: $25 + shipping
Date Ordered: June 2012
Pros:
  • Seems to be water tight (didn't test in deep water though)
  • Reasonably driven for longer runtimes
  • Bright, tight hotspot (Think of C8)
  • XM-L provides also some spill
  • Good UI (just slide to desired level)
  • Magnetic side switch (with seven brightness levels)
  • High PWM frequency (No visible PWM)
  • Emitter perfectly centered
  • Tailcap with square threads
  • Double O-rings at tailcap, single but beefy ones elsewhere.
  • Tailstands
Cons:
  • Switch movement is short -> requires practice not to jump some modes (small amount of oil helps)
  • Could be driven harder (but then again, runtime wouldn't be as good)
  • Only one hole for lanyard
Summary:
Battery: 1 x 18650
Lens: Glass
Tailstands: Yes
Pros:
  • Tailstands
Cons:
Features / Value: ★★★★
The light comes bubble wrap without any accessories.
Main features are: Waterproof (for diving, 100m by manufacturer specs) & magnetic control.
UI is pretty good: Seven modes with a magnetic slider (no blinky modes). Slide forward to turn on / higher modes, back for lower modes / off. It's very easy to turn fully on / off, but requires practice to find all middle modes. I got a piece of advice from : use a drop of oil in the slider and it helps a bit.
Here's a photo of the slider in off-position (in disassembled light).
The light has some parasitic drain, so it is a good idea to lock out the light by unscrewing the tailcap for about half a turn.
Value for money: Good.
Design / Build Quality: ★★★
Design is pretty "normal". Looks like a functional flashlight. Head crenelations work as anti-roll.
The anodization is good overall and the glass lens looks ok.
Here's the thick glass lens wit a beefy O-ring:
Let's see some more details..
Tail part of the body tube with square threadas and double O-rings (sorry about the hairs, they stick nicely on the well lubed threads):
Clean threads between the body tube and head. Note also the O-ring and separate metallic ring that makes sure that the O-ring is pressed tightly against / inside the head.
Perfectly centered emitter in a flawless aluminum reflector:
A flashlight requires some kind of lanyard for diving use, however I'm not sure how to attach it, since there is only one quite small hole for the lanyard in the tail cap => At least it doesn't tail stand so well with lanyard attached.
Inside of the tailcap: Thick tail spring, smooth surface for the double O-rings, and good threads.
The body tube is thick and looks durable:
Here's the magnet side of the slider:
Business end of the head. Looks perfectly serviceable:
Knurling of the mid section. Looks good!
And I have to say the same for the tail cap. Looks good, indeed.
A photo of the light disassembled:
Some measurements:
Length: 153mm
Head diameter: 43.5mm
Body diameter: 26.8mm
Tail diameter: 30.1mm
Weight: 245g with cell (= ready to use), 199g without
And the bottom line in the quality: Not much to complain. Double O-rings between the head and body would be nice though.
Battery Life: ★★★★
Good! (And bad)
I measured the current at the tailcap and got results of 1.50A on high to 0.25A on low. And 0.07A parasitic drain when off => TC lock out highly recommended.
This would give almost 2h runtime on high and over 10h on lowest setting! On the other hand, just a couple of days on the shelf without lockout equals a dead battery. Sad
Light Output: ★★★
This light is not driven hard, most probably because it's optimized for longer runtimes, which is surely needed when diving. The hotspot size equals to well known C8s and there is some spill provided by the XM-L emitter.
I estimate (ceiling bounce + "known" references) the light output to:
- about 500 lumens on high
- about 80 on lowest setting
White wall beamshots (WB: Daylight)
Lowest setting:
Highest setting:
Beam pattern (low)
Beam pattern (high)
Couldn't take outdoor beamshots due the lack of darkness. Sorry about that.
Summary: ★★★★
Looks & feels like a good flashlight for diving. Good build quality and no moving parts to leak water in. Magnetic control with so many levels is nice also for other uses.
Verdict: Recommended!
The End (pun intended):
Thanks for reading & watching. Hope you enjoyed the review!
=the=
Edited by: sb56637 on 09/02/2017 - 12:34
BetweenRides
BetweenRides's picture
Last seen: 3 years 1 month ago
Nice review, _the_, thanks for posting. Looks like a nice light but I have a question on the UI: How easy is it to use the switch using diving gloves?
My other observation: Is the knurling on the body aggressive enough for holding underwater?
Richie086
Richie086's picture
Last seen: 7 sec ago
Great review! The light obviously isn’t driven hard, but do you feel the thermal path on this light could handle a more powerful driver if someone wanted to upgrade one? Thanks.
Richie
_the_
_the_'s picture
The switch is very easy to operate also with gloves if you need full on / full off. Anything in between requires small moves, which might be a bit difficult depending on the glove type. On the other hand, the switch glides well if lubed, making it easier to fine tune the output.
You are right that the knurling is not very aggressive. It feels secure in hand also when wet, but I haven't gone diving with the light yet, so I can't give you a definite answer..
I'll check the thermal path later today.
=the=
Sharpthangs
Sharpthangs's picture
Last seen: 8 years 4 months ago
Great review. Thanks as always.
Looks like great value for the money.
Keep us posted.
Ledsmoke
Ledsmoke's picture
Thank you for the review the. Good and thorough as always.
It certainly the cheapest diving flashlight with anything xml, modes and easy UI I’ve ever seen. Thank you for sharing this.
~ Ledsmoke ~
Dutch humor:
[quote=djozz]
 I do not think that the BLF-community ben
taz
taz's picture
Last seen: 1 year 8 months ago
Finally, a diving light which is not overpriced!!!
gcbryan
Last seen: 7 months 3 days ago
Nice review. Let us know that it’s like on a night dive it you do one.
It looks like you could use either cave line or 1/8” bungee to tie on a bolt snap to clip on to your chest D ring.
_the_
_the_'s picture
I checked the thermal path. Looks good.
The pill is hollow, but quite heavy (= middle section is thick enough):
It sits tight and nice in a slot (it's a bit up because wire pushes it, levels down when tightened).
Pill is tightened down with a large enough retaining ring:
Secondary thermal path is via aluminum reflector, which sits on top of the star. The reflector has wide flat surface, which is in contact with the head walls:
Reflector upside down in the head. Note the tight fit and flat bottom surface (to be in contact with the star):
All in all, I think this design is good, and would be suitable also for higher currents. Of course some Fujik (or similar) can be added to make sure that surfaces are in perfect contact.
Hope this clarifies the thermal path. Just ask if you have any additional questions.
=the=
Richie086
Richie086's picture
The pill is hollow, but quite heavy (= middle section is thick enough.
Hey The,
Thank you for going the extra mile as you have to show us how it handles heat. That was a lot of work. The reason I was curious is because I tend to use my diving lights more out of the water than in. So knowing some thought went into this light by the manufacturer to assemble a quality product is important. I just had some major upgrade/maintenance performed on my boat, so it’ll be back in the water on Monday. My friends and I are planning some diving next weekend so I’m going to place an order for this one, but I doubt it’ll arrive in time for this dive, but I’ll surely have it for the next one. Thanks again.
Richie
_the_
_the_'s picture
First of all: Sorry about the quality. Exposure was adjusted for King / APEX, so this might be a bit dimmer than what it was in real life.
2.0s, f/5.0, ISO80, WB Daylight
Control
Magnetic control diving light (highest setting)
Magnetic control diving light (lowest setting)
Compared to XinTD C8 v3 NW (mouse over for XinTD)
=the=
jacktheclipper
jacktheclipper's picture
Last seen: 5 hours 6 min ago
Cool
What I do
_the_
_the_'s picture
Bonus shot: Beam pattern in water
=the=
sb56637
sb56637's picture
Last seen: 5 hours 22 min ago
Very nice! Thanks so much for the review. Frontpage’d and Sticky’d.
Ecig
Last seen: 8 years 10 months ago
And what about underwater abilities of this light???
stevetexas
Last seen: 8 years 2 weeks ago
I have one of these that I got from Ebay dealer tomtop….
http://www.ebay.com/itm/290718077151?ssPageName=STRK:MEWNX:IT&_trksid=p3...
the has covered everything very well. Mine draws 1.5 Amp on high.
The reflector is about the same diameter as a C8 but is a few milimeters longer. The beam pattern is similar to a C10 or Keygos KE-5. That is, the hotspot is a little tighter.
The O rings at the tailcap are air-tight, when I pull it off, it makes a “plop” sound.
The slider switch on mine is nice and smooth and will not move due to shock, however, the switch sticks up quite high and is easy to change modes if your hand touches it accidentally. Also the modes are quite close together in distance. I have to be carefull when trying to select a mode other than high.
The light tailstands well and the low mode was used as room lighting by me recently when a thunderstorm caused a power outage for 3 days.
As the has said, the Off position on the slider has parasitic drain so it is important to loosen the tailcap before putting the flashlight away. On mine, it only takes a slight twist to open the circuit, much less than a quarter turn.
I don’t know anything about drivers for use with a magnetic switch like this. It would be nice if it was possible to install a driver with a 3A or more setting.
Ecig
Yeah everything is here except most important – how this light acts underwater :0
stevetexas
I am not a diver myself, but maybe someone who is will tie a rope to it and lower it into the water for a while.
Then we can see how well it works as a lithium powered depth charge. Steve
Ecig
I thought to buy this light (i think it can be bought, same light, from ebay, and from dinodirect too) and give it to diver friend for testing purposes.
But somehow Im hesitant, didnt yet pulled the trigger, I’m ordering to many samples in last days. If I do it Ill post results here. First light I have him for testing, Keygos S2 (currently available from manafont, 8mm glass on the front, without keygos label), it leaked in second dive, he thinks through the glass….
Maybe, just maybe leaking can be solved but I dont know yet (buy adding some aditional orings under the glass and by tightening screws holding it….
If anyone wants to test it, before each “dive”, friend says, even professional diving lights need to be lubed (thats supposedly even stated in their’s instructions). So, dont forget to do it.
ALso, one question, this light from the review is clone of that XTAR diving light?
And this would be 2-cell version of same light http://www.manafont.com/product_info.php/stepless-brightness-control-xml... ?
ISnt this exactly the same light?? http://www.dinodirect.com/outdoor-flashlights-magnetic-control-cree-t6-8...
Ecig
Anyybody has some more info about this light in diving conditions? (sorry if Im annoying, but I plan to buy some light really for diving, and Im searching for reviews and experiences. This one looks nice and price is great but I dont know anything about its diving capabilities)
Foy
Foy's picture
Last seen: 6 years 5 months ago
I have a new (supposedly) dive light that I'm reluctant to review because I don't dive, nor know anyone willing to take my light down to depth.  I'm pretty sure I cannot confidently claim it won't flood, following a dunking in the Foytub. (phantoms 18-inches)
Still, dive lights, or those claiming to be dive lights facinate me.  To me, recommending something whose failure could potentially have catastrophic consequences is a serious thing.  I'm also curious if something so inexpensive could be trusted in a mission critical environment. (for lack of a better term)
divelightdummyFoy
No referral links and nothing embedded . . . ever.
                      &nbsp
stevetexas
The only things that make a dive light different from any other flashlight are the seals at the switch, the tailcap and anywhere else it screws together and the thickness of the body (prevents crushing). Right?
This light has a thick heavy body and a magnetic switch that does not permit leakage at the switch or pressure damage. Ordinary switches will not work because high water pressure will press the switch down and hold it.
The glass is thick and strong.
If you wanted, you could use epoxy to glue together all parts except the tail cap.
The tailcap is air tight and has 2 heavy O rings.
If you use heavy and sticky grease on it, I bet it works.
You choose.
gcbryan
Just about any flashlight is fine as far as the walls. The o-ring issue isn’t about just thicker ones or adding more. It’s about a proper design for where the o-ring sits.
Switches for the most part need to be either magnetic (nothing to leak) or twist. Water pressure activates (and leaks) with most other type of switch.
Glass thickness is important as it relates to depth and to how robust the light will be (can you bang it around without causing a leak).
In a light designed to be a dive light most leaks if they occur come from the front.
Ecig
Foy wrote:
I have a new (supposedly) dive light that I’m reluctant to review because I don’t dive, nor know anyone willing to take my light down to depth.  I’m pretty sure I cannot confidently claim it won’t flood, following a dunking in the Foytub. (phantoms 18-inches)
Still, dive lights, or those claiming to be dive lights facinate me.  To me, recommending something whose failure could potentially have catastrophic consequences is a serious thing.  I’m also curious if something so inexpensive could be trusted in a mission critical environment. (for lack of a better term)
divelightdummyFoy
As I understand diving lights are not always so critical for safety., YOu not always need dving flashlight in conditions wich are so dark or something that this would compromise your safety.
Thats one thing – and other thing – I just cant believe that it is oh so difficult, if you have resources, to design really waterprooof diving flashlight. I just cant imagine (and I have storng imagination Smile ) that this is so hard.
I think thats more question of hastiness, that Chinese make all these things to hasty, to fast, and design them to hasty, and diving light s are the stone on wich they stumbled, because they are tricky by themselves (they mustnt leak Smile )
gcbryan
I dive at night (often) and deep and I don’t consider a dive light “life support” equipment. I also always have a backup light so that concern is overrated IMO.
It’s not hard to design a dive light. The main problem with the Chinese lights is that those designing the lights aren’t divers and divers as far as I can tell don’t test them.
They just use a pressure pot so that the light can experience the same pressure it will experience at depth.
It’s not hard to design a dive light but it is hard(er) to take a light that isn’t designed as a dive light and make it a dive light.
If it doesn’t have the proper o-ring cut out design behind the lens then you are left with marine grade silicone sealant or epoxy as the method of sealing.
If the switch is a “clicky” type it is going to leak and depending on type it is going to either always be “on” or always be “off”.
How much the light cost has nothing to do with how good a dive light it is however.
I replaced a $300-$400 HID dive light with a $100 Chinese LED dive light.
Maurice
Last seen: 5 years 7 months ago
Perhaps we should make a thread discussing what makes good diving flashlight design and let’s hope manufacturers/dealers take notice.
Some things I got from reading in this forum. One is that you can’t have mechanical clickies so magnetically/electronically controlled switches is the way to go. Two, can’t use the metal body of the light as part of the circuit. Three, it should accommodate at least two batteries for longer run times. And four, o-rings, o-rings, and o-rings.
What’s the weakest point in diving lights where water commonly seep in?
Foy
Foy's picture
Thank you guys.  Shows what I know about diving.  Seems my concerns were unwarranted.
learningFoy
                      &nbsp
gcbryan
It would be from the front of the light since in a well designed light there either wouldn’t be any other place for it to come in or if the light is made of several pieces (and could theoretically leak) it doesn’t with any kind of reasonable o-ring design.
So, it’s the switch (but this isn’t an issue with a well designed dive light due to the kind of switch chosen) or it’s front water pressure against the front lens letting water get behind the lens due to a bad o-ring design in the head.
Typically, a good design is a groove in the head on a ledge which you drop in an o-ring so as pressure (on the front glass increases) the o-ring has no where to go and compresses to counteract the forces pressing against it.
Therefore, the deeper you go the more pressure against the front lens the more the o-ring compresses and … no leaking.
Many backup dive lights are made of only two parts…a body and a screw-on head (and front lens of course). So there is no switch to leak.
You fully screw the head in to turn the light on and slightly unscrew it to break contact and turn the light off. In this design you have a long section of threads connecting the head to the body with thick o-rings (sometimes 2 although multiple o-rings isn’t necessarily better).
The best backup dive light I have is made of Delrin for the body and metal for the head. The lens is 6mm thick and the head diameter is only about 30mm.
This light is a tank in effect. It’s the Ultrafire W300 from DX and it’s $36 using 3 AA’s and a XP-E (XR-E?). It’s a nice, tightly focused light. Since it uses primary batteries you don’t have to remember to charge it so it’s alway ready (it’s a backup after all).
I clip it to my shoulder strap and have a small bungee around the head as well so I forget that I even have it on.
For a primary light I use rechargeable batteries (18650) and two are needed IMO since a typical dive is close to an hour and it’s not uncommon to do two dives back to back.
For a primary dive light I’d like for it to have a magnetic switch. The one thing to tells me that most Chinese lights aren’t really designed by a diver is that many of them still have crenelated bezels which are totally useless (and a hazard) on a dive light.
Sharp edged heat fins are a nuisance as well and aren’t needed since the light is being used in water. Frequently the front glass lens isn’t as thick as one would prefer for a dive light.
This is all basic stuff so for the manufacturer to not realize this means that no one has a clue about diving.
gcbryan
Since there seems to be some interest on this subject I’ll describe an experiment I once did.
I wanted to learn more about the failure modes of a light converted to a dive light. I used a cheap Rominsen RC-K4 (or something like that). It was a 3 AAA XR-E light with a reverse clickie.
The switch was removed which left a hole in the tail which I filled in with marine grade epoxy. This left the light as a “twisty” by screwing in and out the tail cap for on and off.
The front lens was very thin, maybe 1 or 1.5mm. The o-ring in the head was useless both because it was so thin and because of its location. It was around the lens in the head rather than behind the lens so it really did nothing to keep water out except for maybe light rain. It was more like a gasket than a compressible o-ring.
I removed the o-ring and used marine grade silicone sealant around the edges on both sides of the lens.
Then I tested this light on a night dive to 100 fsw (feet sea water). I expected it to fail but I wanted to note at what depth it failed and what exactly the failure modes were. I had another light with me of course (2 more actually).
Initially, I turned the light on before I entered the water to eliminate the act of twisting the light on as a failure point. I check the front lens every 30 feet or so on the descent to 100 fsw to look for leaks.
It never did leak! At 100 fsw I decided that I had learned all I needed to know and was therefore willing to twist the light off and then back on. It still didn’t leak. Twisting the light on and off at 100 fsw was the worse case scenario (for this test).
The lens was thin but the head diameter was only 30 mm or so and thickness is a function of surface area for these purposes so it worked but wasn’t ideal.
I didn’t bang the light around or bump the lens against anything underwater or it may well have failed.
That’s what’s not generally tested in a pressure pot…dynamic pressure rather than just static pressure.
Rarely is the issue (for leaking) with a light the body tube head or tail connection. Almost all lights have one or more o-rings there and long enough threads that there is an effective seal. Grease is helpful but that isn’t what seals at 100 fsw or at any real depth underwater.
Switches that are desirable in non-dive lights aren’t desirable in dive lights due to increasing water pressure which would activate the switch. With a reverse clicky water pressure would keep the switch from ever turning on.
Due to the way these switches are constructed water would almost always leak (flood) in at some depth and that would occur fairly quickly (at a fairly shallow depth). Spring pressure could offset that initially.
A thick front lens is desirable but it may not initially be the cause of a leak (may not break initially if not banged around).
Many dive lights are spec’d to 300 fsw so they can be used in reality down to 200 fsw or less.
I’m sure (pretty sure) that the Rominsen would have failed (lens broken) by 200 fsw. My regular main dive light has a lens that is only 3.5 mm and that’s with a diameter of close to 50mm. I wouldn’t be comfortable with it at 200 fsw.
People have had them down to 150 fsw or so. I’m had mine down to 130 fsw. The light I had before my current main dive light was taken down to 200 fsw several times and I had no problem doing that but it was thicker and all plastic (HID not LED however).
Your average flashlight may do OK in a swimming pool (or it may flood) Smile That’s an addition 1/2 atmosphere at most. Beyond that most lights would fail (and/or not work) just because of water pressure and the clicky switch.
I don’t know exactly how a Zebralight (for example) is constructed but conceivably it could work with the electronic switch (not sure about how the switch is sealed) however it would be continually changing modes due to water pressure but otherwise it might make it to 100 fsw. I’m not going to test this however! Smile
Ecig
Great info gcbryan, and interestng read Smile
Why dont you get some cheap diving lights for testing (there are several of them now wich look serious, in price range cca 20-30$ ) Big Smile (I think primarily on this one, and there is Yezl Q2 for example on cnqualitygoods…
Maybe manafacturers can send them to you for reviewing (hmmm, if they dont think that wouldnt be in their interest :o)
I just dont understand the issue about body of the flashlight being part of the electrical circuit.
Im aware that this is so in practically all “surface” flashlights I own.
But I dont understand what happens with diving flashlight in that regard:
DO all budget diving flashlight have that design flaw? (XTAR lights for example? D06? YOur MC-E flashlight, gcbryan?
And what happens, why is this a flaw? (I think there are two things: Ive read for example that dinged XTAR D06 will shine in salt water even in off position, and will shock you if you touch iit with bear hands – thats one thing. And new sturdy Trustfire diving light doesnt want to change modes in the water, thats the other thing I think is connected with that flaw…)
Where the current flaws in better diving flashlights? Not through the body? Or they have thicker annodization?? Many things I dont understand Smile
gcbryan
I’ll respond to your second question first. I don’t know anything about this issue or even if it’s a real issue. Without knowing the details I tend to think this isn’t really an issue.
I have metal dive lights as well as those with a hard plastic body. I’ve had no issues in that regard.
Regardlng testing dive lights…I’m not interested in most of the ones that I see. They’re either too small (don’t have enough burn time) or they’re too floody or (the big issue) they’re just too likely to flood since it’s just luck for a Chinese manufacturer to end up with a robust design since they don’t seem to actually know anything about the issues that relate to the diving environment.
I also don’t need any more dive lights at the moment. What I have do the job and even if more “modern” lights come out what I have do the job and don’t leak so what’s the point? Smile
The only light that would interest me would be one that 1) works and 2) doesn’t have all the crenelations and heat fins that my current one has while 3) still using two 18650’s.
However, money is tight and I’m really not interested is spending $100 right now even if such a light did come up.
The big advantage of the light I posted about (main dive light) is that hundreds of people bought that when it first came out (since there was nothing close to it in price at the time) and many of those people (myself included) were in contact with each other regarding reviews, failures and fixes.
So that light is fully vetted in a way that most of these others aren’t at the moment. On the other hand if someone is just looking for a small floody light for a shallow clear water night dive on a tropical vacation…most any dive light will do that.
