Contribute Data : Discharge information most welcome ...
If you own a charger that can discharge cells and give the mAh discharged , then please feel free to add data [ new cells please ]
If you wish to cycle the cells , then please let us know which cycle you are sharing the results for ... IE / 3rd Cycle 2200mAh
Discharge rates : And charge rates
AAA Cells = Please charge / discharge / cycle @ 0.5A [ 500mAh ]
AA Cells = Please charge / discharge / cycle @ 1A [ 1000mAh ]
RCR123A = Please discharge / cycle @ 0.5A [ 500mAh ] Most chargers - WF-188 / 139 etc will charge at 500mAh or less , so not really an issue
14500 = Please discharge / cycle @ 0.5A [ 500mAh ]
18650 = Please discharge / cycle @ 1A [ 1000mAh ] or just let us know the dischargerate !
10440 = Please discharge / cycle @ 300mAh
17670 = Please discharge / cycle @ 1A
If you wrote a review - or tid bit on the cells , please let us know so we can link to your thoughts ..
Information = Charger used , cell dimensions [ use care not to short ] claimed capacity ... an example is bellow .
......................... | ......Battery....... | .Claimed.Capacity. | .Discharge.Results. | .Cell.Dimensions. | .Protected. | ........Charger........ | .....Cell.Type........ |
Solarforce RCR123A V2 | 880mAh | 721mAh @ 0.5A | L-36.2mm D-16.8mm |
Yes | Imax B6 | Button Top | |
Just testing ... But looks like this will work ...
Ok , so hopefully something like this , so battery is tested / reviewed ...
Results for capacity go here + other details , + in the description [ battery ] , if there is a review [ I will review any batteries I test ] , I will link to the review , as I have done on the test form . So I will keep this to play with [ learn ]
