The Trustfire 3000mAh and 2400mAh I just tested were almost identical apart from the pcb - the 2400 cut off at under 4A.
Hopefully they will be on the blog at the weekend.
PS: BTWm, if you wont best bang (mAh_) for a buck, Ultrafire protected 2400mAh are far superior to anything Thay have cca 2000mAh per 2,5-3 bucks from dinodirect (if they really send you these cells, I ordered a coupls so Ill see - I say to you, they are better than most TF flames 2400mAh out there, only PCB is little weaker, cant stand 3A)
@torchy, too many diagrams, I browsed through cca 20 of them and than I quit :o
Good quality Ultrafire are few and far between. You end up wasting a lot of money trying to find decent quality. I know, I’ve done it. That’s why I started the blog, to save others from wasting their money.
Yesterday I r/eceived 12 HiMax 2600mAh from pingyi ebay seller.
They look great and I was thrilled to have them.
But now I started discharge test and Im quite dissapointed.
I have iMax B6 hobby charger from Dinodirect. I put 1A discharge to 2,8V (from 4,15V).
In 20 seconds voltage droped to 3,62, and in 1 minute it dropped to 3,59. (same as trustfie flames, but some very bad ultrafire can have little better voltage sag).
Now 5 mins past and its 3,51 (6 mins and its still 3,51V; 11mins its 3,45V)
So results are totally inconsistent with diagram I found on this website.
FInished discharging - first cycle - 2293 up to 2,80V
Thanx HKJ (btw, can you out time on ghorizontal axis maybe?)
(Illpost comparison diagram later I dont have time now)
But thats precisely source of my doubting.
Himax cell Im testing right now gives resultrs as trustfire flames 2400mAh cell, not Himax - especially regarding voltage drop…
Maybe some other cell from the package will perform better, but if they are oscillating so much from cell to cell - thats not acceptable…
Im not prone to pay more just for the label or just few mAh higher capacity
I will post the full review later today, this includes also charts with a time axis and all HI-MAX curves in the same chart (Like all my other battery reviews).
On what voltage is undervoltage protection of these cells?
žI just continued discharge of this same cell, put end voltage at 2,50V, so Ill see, fif anything happens.
I still didnt had any cell, as far as I know, with working undervoltage protection - and im ordering good, high capacity Trustfire flames.
It delivered 99 more mAh to 2,50V. (from 2,80 to 2,50V)
Im not aware of undervoltage protection kicking in… (but I didnt watched the charger whole time - if that matters…)
Can somebody help me understand this - I asked this questiuon on several other topics, still struggling with answer.
The under voltage protection is somewhere between 2.0 and 3.0 volt, you order the protection chip for the specific voltage you need. That is the theory, but for the number of chips used here, the manufacturer only have a few fixed voltages to select between.
