Those are all the HD2010. Its just www retailers copy-pasting whatever description they can find. I think its somewhere in the 750-900 lumen range. Its slightly brighter than the stanley fatmax on a ceiling bounce and a member on the other forum measured his stanley around 750 Lumens in his sphere.
I just wanted to add an update from a PM I received from Sherry Ye at Tmart. She offered me an $8 credit. I graciously accepted.
/whineFoy
I’m not sure I get the significance of an o-ring around the pill. What is that for? Thanks. Nice review by the way!
Actually, now that I think about it, I'm not sure why either but it did come with an o-ring around the pill so, had to report it. It was very thin so I replaced it.
Why would they put an o-ring there? Seems like that would hamper heat trasfer a bit, if anything.
hmmmFoy
Good question, mine had that too. I dont think it serves any purpose… “maybe” its a way to help snug everything up if a run of lights has a bad tolerance stackup that doesn’t add up?
Has anyone measured lux numbers of this powerhorse?
It’s now $33.52, with US based shipping. I’m just saying…
http://www.tmart.com/UItraFire-CREE-XMLT6-8W-1300-Lumen-5-Mode-LED-Flashlight-Gray_p135765.html
http://www.tmart.com/UItraFire-CREE-XMLT6-8W-1300-Lumen-5-Mode-LED-Flashlight-Black_p135768.html
In B L A C K, less than 3 weeks ago --- Black was PREMIUM Priced >$40, (I think)
is the tmart hd 2010 just as bright as the manafont one? or are they all the same?
im looking to buy one.
The only reason I would want a driver swap on this guy is to get rid of the flashies. It already pulls up to 5 amps.
Foy
I have been wondering the same thing. Do all HD2010's from everywhere have the same driver?
goodquestionFoy
TangsFire from DD, for <$34. Someone said that, but, if I remember well, drivers were absolutely identical Quite strange.
Does someone have 15% off for TMart?
Yes they are all the same component wise same driver emitter etc… The Internationale Outdoor one had a darker grey color that I liked better than the light gray Tmart one but the Black one looks best in my opinion.
Mine pulls 2.25A, but that is on an 18650 battery…I have no 26650’s yet.
Hey, troop, thanks for the info Which one do you have? (from TM, DD, other? Ultrafire? TangsFire?)
It’s the T-Mart one. I just popped a fresh Rev Jim’s 18650 into it and got 3.25A with no compression and 3.8A when I pushed it down and compressed the spring.
Go figure.
It’s the T-Mart one. I just popped a fresh Rev Jim’s 18650 into it and got 3.25A with no compression and 3.8A when I pushed it down and compressed the spring. Go figure.
I tested mine again in stock configuration last night and came up with pretty much the same results. Before from memory it would only pull 2.7 amps. This was from a Tangsfire version. At 2.8 amps this thing still rocks.
I ordered these from MF hoping for a nicer action switch and to my surprise the switch on the board is identical to the standard switch. The only difference is the board is a slightly bigger diameter which can be filed down no problem and the spring is slightly different which should also not cause any problems.
Link, please
Link, please
Stupid me. Link added.
