There doesn’t appear to be much heat dissipation with this light, when you get it i am curious to see if they came up with something that we aren’t seeing
Bad news guys, I went to HD and they were all out of them. I found the spot for it though. :P Hopefully someone else will be able to get their hands on one of these.
Killer deal if XML, but 350 lumens (vs 2000 “lumens” of stanley one) suggests otherwise. Not too bad even if xp-g, though, since the other giant head competitor is twice the price. Still throws just as well even if hotspot is smaller.
I'm awaiting someone to get their hands on this and open 'er up and tell us what it's like. Sorry kramer5150, I don't remember the size of the reflector/lens and don't know when I'll get back there again. I would say that overall the light appeared to be around the same size of the 2000 Lumen Stanley (judging from memory here, so take that with a grain of salt).
Looks to be an XM-L, but the question will be, is it a T2, T3, T4, T5 or T6?
I’m betting not a T6 and I don’t know if there really is a way to find out, other than brightness.
I have it on the charger now and I will do beam shots at home.
Also of note to me was a Q-Beam 3 XP-G spotlight. It was $49.00, but if it could be redone with 3 XM-L leds, it might be a good mod. It looked like it had 3 P-60 sized reflectors with the 3 XP-G emitters. I don’t remember lumen output. The HD code is 547-651 and the Model is 800-2801-S. I believe the same Chinese outfit is making the Q-beam as well as these Defiant.
Maglite has a 3D and 2AA LED set going for $27 too, at HD. I really wanted those LED Maglites, but I bit the bullet and bought the Defiant. I hope someone else wants it after I hack it!
Thanks for the update O-L! Is the battery sealed in the light? Or accessible through a battery door? What size is the battery? - Equivalent to anything common?
It is sealed. I can not take this apart at work, so I can’t answer untill late tonight or in the AM. It is Very Light. I would think it’s probably 3AA batteries inside it, even though it says 4000ma. I know from the weight, it can’t be like 3 C batteries in it. Or it may be a special made alkaline. I just don’t know till I open it up, when I get home.
