Talk about an epic light. I reckon E has just started a frenzy (again). Any chance of some beam shots when you have it back in your hands? Thanks for sharing.
You can tell you friend that he could by these lights and mod them to these specs, then sell them. I for one would be in! A sucker for a power house SST-90!
SR90 is 100mm head diameter.
X6 is 80mm. This modded X6 probably is driven slightly more. The lens probably cuts some 5-7% more light.
No way the X6 can outthrow the SR90. Maybe just slightly under the TK70 or at best same league?
TK70 would be able to maintain the lumens better, i mean this forum is extremely familar with how triple XM-L works. The SR90 already sags even with that huge body. Check out the reviews.
My TrustFire X6
SST-90 de-domed
2A at tailcap 3x18650 (stock driver)
4 meters = 4850 lux
XM-L U2
1320 mA at tailcap 3x18650
4 meters = 5400 lux
Both are hard to set better spot.
And modded some aspherics lenses…… more to come
VPT and similar hotrods use copper direct bonding to extract performance in the 14-15A range, but seriously tapering off already. (think stock VPT would be 13A thereabouts)
These buggers run pretty hot compared to XM-Ls.
Tailcap current draw its not an additive measurement. So 2 cells in series drawing 5.6A at the tailap is going to be exactly that, a 5.6A draw. Its incorrect to multiply the measurement by the cell count. Sames goes for 3S cells drawing 3.8A at the tailcap.
With series battery configurations the voltage of each cell is added together, not the current.
Not to dampen your excitement though. The SST90 is an impressive LED when its driven to capacity. I have been wanting to try this mod on a TR-J10. Sounds like a great DIY!!
So why, on a light that can take one or two 18650, would it pull say 3A on a single cell and 1.5A with 2S configuration? Every light I’ve heard of that can take multiple cells is like that. As another example, a light that takes 2 or 3 cells depending on tubes used pulls 1.5A at the tail with 2 cells or 1A at the tail with 3 cells. They always add up.
In that case it would be based on the constant wattage pull of that driver circuit design. So the single cell that pulls 3A is doing 10.8W (3A x 3.6V), assuming Vbatt =3.6V from sag.
When you add a second cell in series that driver is still going to pull its ~10.8W. But you are doubling Vbatt, so the driver is going to pull less current to maintain ~10.8W.
So in that case 10.8W = XA x 7.2V
Solve for X = 1.5A
When you add the 3rd cell in series:
10.8W = xA x 10.8V
Solve for X = 1A
Its not an exact science as this, but this is a way to “ballpark” look at it. The reality is that driver efficiency varies slightly with Vbatt, so to assume its a constant 10.8W pull across its entire Vbatt range is not entirely correct.
EDIT
Oh wait a minute… Chris is talking about EMITTER current, not JUST tailcap current. Thats a different ballgame entirely. I’ll leave my commentary as is for now though, as it pertains to tailcap power consumption only.
