H1 to H3 is the same model as before, all with Q5 led. H5 is the only one that looks out place spotting a T shape. They miss out H4 though in their front page lineup of the H series but it’s still in their product list somewhere.BTW, I have still waiting for a review of UF-H6….
What the ? I ordered the 18th and got it today. 6 days. Amazing.
This is a great light and an improvement over the H3
Has an easy removable clip.
Not as floody as I expected.
No magnet in the tail cap (possible con)
It gets hot quickly. Less than a minute. Too hot to use on high for extended periods.
edc, how would you describe the beam? Is the hotspot small or large, and does it transition smoothly to the spill or is there a sharp cutoff?
Subjectively, how low is the lowest mode?
If you leave it on the highest mode, it steps down after a minute, correct? Is there a big difference in output between the highest mode and the 2nd-highest?
If you leave it on continuously on the 2nd-highest mode, is that when it gets hot? Too hot to touch (bad for a headlamp)?
Does it use PWM on the lower modes, and if so, could you guess at the frequency?
The tail cap is not legoable but you could add a magnet
It does step down after a minute.
It has a hotspot and its bright.
Low is nice
Second click is bright. Third click is slightly brighter
Not a huge difference between 4th click and 3rd click but you can see it. Not so hot on 3rd click level. I can’t hold it on high.(4th click) Pwm is minimal to me- I can’t really see it .
Anodising is very good. Threads look good. Its a nice light.
A tight fit when using the head strap. It really needs second dedicated groove for the rubber rings.
The click button could be slightly longer.
Doesn’t like long batteries. You would think they would make them a little longer. similar problem to the original H3. Would work with unprotected flat tops.
I just stuck a 3mm thick magnet in mine. It will now work with longer batteries if you screw it really tight. It really should have a magnet in it. The H3 magnet fits.
Not likely to do a Foy style review. Don’t have a decent camera and never really tried. I found the double click strobe by accident and still can’t see properly. lol
Only if you remove the tail spring and pack it with something about 3mm thick, Magnet would work. Its easy to do. Or put a blob of solder on the outside ring of the switch. The body can’t make contact with the outside ring as the longer battery stops it touching.
