Good question, mine had that too. I dont think it serves any purpose… “maybe” its a way to help snug everything up if a run of lights has a bad tolerance stackup that doesn’t add up?
Has anyone measured lux numbers of this powerhorse?
It’s now $33.52, with US based shipping. I’m just saying…
http://www.tmart.com/UItraFire-CREE-XMLT6-8W-1300-Lumen-5-Mode-LED-Flashlight-Gray_p135765.html
http://www.tmart.com/UItraFire-CREE-XMLT6-8W-1300-Lumen-5-Mode-LED-Flashlight-Black_p135768.html
In B L A C K, less than 3 weeks ago --- Black was PREMIUM Priced >$40, (I think)
is the tmart hd 2010 just as bright as the manafont one? or are they all the same?
im looking to buy one.
The only reason I would want a driver swap on this guy is to get rid of the flashies. It already pulls up to 5 amps.
Foy
I have been wondering the same thing. Do all HD2010's from everywhere have the same driver?
goodquestionFoy
TangsFire from DD, for <$34. Someone said that, but, if I remember well, drivers were absolutely identical Quite strange.
Does someone have 15% off for TMart?
Yes they are all the same component wise same driver emitter etc… The Internationale Outdoor one had a darker grey color that I liked better than the light gray Tmart one but the Black one looks best in my opinion.
Mine pulls 2.25A, but that is on an 18650 battery…I have no 26650’s yet.
Hey, troop, thanks for the info Which one do you have? (from TM, DD, other? Ultrafire? TangsFire?)
It’s the T-Mart one. I just popped a fresh Rev Jim’s 18650 into it and got 3.25A with no compression and 3.8A when I pushed it down and compressed the spring.
Go figure.
It’s the T-Mart one. I just popped a fresh Rev Jim’s 18650 into it and got 3.25A with no compression and 3.8A when I pushed it down and compressed the spring. Go figure.
I tested mine again in stock configuration last night and came up with pretty much the same results. Before from memory it would only pull 2.7 amps. This was from a Tangsfire version. At 2.8 amps this thing still rocks.
I ordered these from MF hoping for a nicer action switch and to my surprise the switch on the board is identical to the standard switch. The only difference is the board is a slightly bigger diameter which can be filed down no problem and the spring is slightly different which should also not cause any problems.
Link, please
Link, please
Stupid me. Link added.
Who do ALL of the descriptions EXCEPT on tmart’s website say: “Circuitry: Digital Regulated 2300mA Current Output”
For SURE these different websites MUST be using different drivers, or something!!!
I guess I’ll just order the black one from tmart to be sure http://www.tmart.com/UItraFire-CREE-XMLT6-8W-1300-Lumen-5-Mode-LED-Flashlight-Black_p135768.html
I sure hope she pulls 4amps at least!
-Jamie M.
Hi everyone:
Thanks for checking batts. It’s definitely a shutdown of some kind. Nothing’s loose. Either the light is doing it (suspected) or the battery (maybe). 18650 Xtars, some flamers, all unprotected (sanyo, sony, panasonic, moli) work just dandy, but some flamers just shut off after about 10 seconds. Not the end of the world. I also have a Trustfire 5 q5 1500L that is also very picky. It’ll cycle to blinky if it gets a batt it doesn’t like. As I said, I think it has something to do with slight overcharging. Batts at 4.16-4.20 volts or so seem to trigger the shut down, or maybe there’s just not enough power in the batteries in question. I agree with whoever suggested that the 26650 would solve the prob. They’re on the way. In the meantime, I have set aside some batts that aren’t 2010 compatible. They also seem to be the ones that the 1500l doesn’t like.
Unlike the 1500L, however, it doesn’t step to a lower power, she just shuts off. If I quickly switch to a lower power, everything is fine. Looks like the flamers in question don’t have the power. Probably an AA eneloop packed in a fake trustfire flame masquerading as a real flamer…
Once again, thanks everyone. At least now I know I am the only one having this problem, which is pretty typical for me :–0
When the cell voltage is higher, that causes the LED to draw higher current, which trips the protection circuit. If your cells were more depleted, or had higher internal resistance (from being old or cold), the current would be lower and the protection would not need to kick in. It’s not your light, it’s your cells. If you really want to use those cells in that light, you might be able to if you just don’t put them in hot off the charger. Put them in when their open voltage is lower (“condition them” for use this light by taking down their charge a bit in another light) and I’ll bet you find the protection doesn’t kick in and kill the circuit. You could also try adding some resistance to the circuit (oxidize the tailspring and or the threads a bit for example).
-Jamie M.
I just got the gray HD2010 from T-Mart, it pulls 4.20A on a TF 3000 flame. I tried a old blue TF 2500 and only got 2.8A —- brightness seems pretty good on either. I still need some 26650 batts, I’ll probably get the flames from M/F. The T/M 2010 is quite a thrower and T-Mart got it to NW Wa. fast.
Sweet!
My flashlight builder buddie says it’s current regulated in every mode except high, where it’s direct drive So WOOT!
I’ll order some up for the times my friends need a thrower!
For the other times, it’s the Poppas W-878 26650 zoomie
For my EDC… oh boy, just you wait!!! It’s a surprise
-Jamie M.
