New XM-L Light,, 26650/18650/4xAAA Good Price and 57mm head ......... NOTE: The star is solid aluminium !!! :bigsmile:
268 posts / 0 new
Tecmo
Tecmo's picture
Last seen: 1 year 9 months ago
Expect ringy Smile
I received no AAA holder! That’s half the reason I bought it. Sad Sad message to seller….
alfreddajero
alfreddajero's picture
Last seen: 2 years 2 months ago
Might do better with an OP reflector i am guessing…….time to put some clear coat on the reflector and see if that helps the beam profile.
With Darkness, there will always be Light.
apt323
apt323's picture
Last seen: 4 months 1 week ago
pill pics
Tecmo
Tecmo's picture
Nah rings or no rings a light this big needs all throw it can get.
alfreddajero
Yes of course your right…..should not bother me a bit since darkness is thy enemy, lol.
kramer5150
kramer5150's picture
Last seen: 9 months 4 days ago
Wow thats a nie looking light.
How is the driver board held in place? is it just a press-in component? Doesn’t look like its soldered to brass.
apt323
apt323's picture
looks like a press in and theres a ring around it holding in
apt323
apt323's picture
I let the light run for around 5 minutes and it started getting a little warm. I figured it would be warmer by that time. I dediced that I would start taking stuff apart. Pulled the pill section out of it and just as I thought (didnt want it to be) that star was only sitting on the small outside edges of the pill section Sad ….
Pok
Pok's picture
Last seen: 3 years 4 months ago
That why I want to see the pill.
gords1001
gords1001's picture
Last seen: 4 years 5 months ago
There’s plenty of room there to make a copper slug to sit the star on though, even an ally slug would help, like you would make for a mag build. :bigsmile:
As I said above, I’m seeing it as a functional host when it arrives, from what I can see, it has potential.
Slewflash
Slewflash's picture
Last seen: 1 year 4 months ago
beamshots, beamshots, beamshots!
Slewflash
Tecmo
Tecmo's picture
I’m reading 608 lumens on high. Medium and low are 315 and 166 lumens. 27300 lux. Strobe is fast but not psycho. SOS really is repeated S O S.
No update on my AAA battery holder.
I should have never bought this, the form factor makes me want an HD2010.
Tecmo
Tecmo's picture
Ok I don’t know how to measure pwm and I never really cared because it never bothered me before but….. The low on this bothers me. I was trying to sleep but the kids are gone and left their tv on, so I used this light to go upstairs. I noticed my feet when walking looked like a strobe light was on. I could almost see the still beam pulsing like my Predator does when I try to get the strobe up to 50000.
Medium doesn’t bug me much. If someone can measure the pwm of the low I will know my limit…
apt323
apt323's picture
I definately agree with you on wanting the HD2010. I am usually late to the game but this time I was to early……….. patience
rdrfronty
Just got one of these in for my brother for his truck. First impression were that it looked good and felt nice to hold. From there it went all down hill. First issue I don’t think anybody has mentioned yet – my 26650 will not fit. It’s a 4sevens model. Too fat. So I tried a ET 18650 in the supplied tube. That at least fit fine. Tightened everything up, clicked it on and – nothing…. So started pulling it pack out and the the light comes on? Turns out the positive is a really weak skinny spring that bent out of the way when everything tightens up. Besides being a crappy spring, it is held on with one little tack weld, which also contributes to the spring bending and missing the battery contact. So I bent the spring good enough it finally made decent contact.
So the beam itself looks decent when I got it too work. I used my meter to do a ceiling bounce test and wasn’t too impressed. It tested just slightly higher than my Quark TurboX123 which is rated at 450L. My S12 killed it. Heck my Eagletac D25C clicky (on IMR’s) even killed it. So I figure this light is likely in the 450-500L range.
With that along with the crappy spring I told my brother NOT to bother keeping in his trucks glove box, which was the reason for this purchase. I wouldn’t won’t him to count on it working first time he needed it to change a tire or etc.
He also just got in a Suterfire C10 this week, figuring one of the two would be a good light. That light doen’t look near as nice, but had put out about another 200L and looks a lot better quality inside. So I guess that light gets the truck duty and the Ultraok light will likely get stuck in the garage for when I’m desperate for a light and don’t wont to use my good lights with my greasy hands.
Sorry guys, but this light, at least the one WE received is junk. Maybe a good drop in could save it. It’s a shame cause it does look good.
Rusty Joe
Rusty Joe's picture
Last seen: 10 hours 42 min ago
Got mine. I love it. Ringy beam, but I don’t mind. Seems well over 600 lumens on a cheapie UF battery even. Feels GREAT in the hand! Not the build quality of other lights we know and use, but I’m going to have fun with this thingy.
rdrfronty, did you try using AAAs? If it’s to be an emergency light, those should be okay.
_the_
_the_'s picture
Last seen: 5 months 4 days ago
Got mine today.
I have somewhat mixed feelings about this light. Not bad, but not good either (as stock). Fairly good for the price paid and good for modding.
Pros:
- Nice design, ergonomic & feels good in hand
- Quite throwy (about 28 kcd)
- Good for modding: Just make a good solid pill and add >3A driver
- Multiple battery choices: 26650, 18650 with tube, 4xAAA with included holder
- Initial brightness with 4xAAA almost equals the brightness with lion (didn't dare running real runtime tests with hollow pill, see cons)
- Aluminum reflector & glass lens (egde of lens was chipped)
- Well centered emitter (with centering ring, seems to be standard in budget lights nowadays)
- No memory (starts on high after being off more than 10s)
Cons:
- Driven a bit low  (not so bad)
    - Keygos 26650: 2.3A, 1.1A, 0.5A
    - TF Flame 18650: 2.5A, 1.2A, 0.6A
    - 4xAAA alkalines: 1.5A, 0.75A, 0.4A
- I would prefer lower low
- Very bad PWM on low, one of the worst I have ever seen (will measure this later)
- Hollow pill, star hanging on very narrow lip -> Nearly nonexistent thermal path
- Ringy beam
- Build quality is not top notch (but not very bad either, especially for the price paid)
    - Threads feel "cheap" and were dirty
    - Spring in driver is poorly soldered, "too" long, and moves sideways causing contact problems with 18650 (not with 26650 or 4xAAA though)
- Tight fit with my Keygos 26650 (some 26650 might not fit)
=the=
gords1001
gords1001's picture
Crying still not got mine.
Rusty Joe
Rusty Joe's picture
Right. The only one worse on PWM is the TB-D7 on low.
Still, though, it is a nice-to-hold, cheapie little performer. Can’t wait to get outdoors with it.
_the_
_the_'s picture
PWM is about 60Hz on low, 120Hz on Med
I'm usually not allergic to PWM, but this is bad: Like a fast strobe.
=the=
Tecmo
Tecmo's picture
I’m usually not allergic to PWM, but this is bad: Like a fast strobe.
Ah, thanks. Now I know how low pwm I can handle. I thought I was immune until I used this light on low.
VFMaddict
Last seen: 2 years 9 months ago
Still not got mine……….grrrr and I was first to order !!!
Can anyone confirm that the star is 20mm, it looks it. I want to start work on a copper slug for the pill.
"You are making progress if each mistake you make is a new one."
Remember - Most great discoveries start with maki
how2
The star is 25mm
alfreddajero
Finally got mine, puts out a lot of light just dont like the Strobe and SOS modes but i am happy that theres no mode memory. I had to resolder the spring because on mine it was leaning one way……….Overall i am happy with the light because of the price but the light does need some better fitting O-Rings and a heat sink for the led.
gords1001
gords1001's picture
Still not got mine, just checked my eBay, it could arrive between 13th and 30th of august, which is outside the 45 day PayPal dispute zone, if its not here by day 44 a dispute will be being opened regardless. |(
kramer5150
Thanks fellas for taking a shot at this one, and thanks for the detail-pics too. I’ll be passing on this one though, its just too similar to the HD2010.
I still don’t see how the driver board is being held in-place. I dont see any trace of solder, and it definitely does not have any kind of mechanical retention component. I think its just pressed into the pill. Which in itself isn’t so bad, until you want to replace the driver with something different/custom. That hollow pill is not going to be able to withstand a lot of heat though. ~2.2A I think would be about right for this design. I think anyone wanting to mod this light is going to have to undertake quite a bit of custom fabrication at both ends of the pill to get it right.
Sardion Master
Sardion Master's picture
Last seen: 10 years 3 months ago
Absolute 100 % agreement.
There’s no excuse for that…
Men occasionally stumble over the truth, but most of them pick themselves up and hurry off as if nothing had happened.
garrybunk
garrybunk's picture
Last seen: 1 month 4 weeks ago
So is the consensus that this light would be fine for a non-flashaholic that would only run it on 4AAA's?  (Assuming you'd get the AAA battery holder of course!)  I think this could be one of the best inexpensive "high-powered" lights running on AAA's or AA's to gift.  I wonder how it does on AAA alkalines - I'm sure it would fire up, but would runtime on high be ridiculously short?  The person I'd gift it to may not want to buy AAA NiMh's just for this.
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
, MTBR’s Lights & Night Riding Forum
NOTE: Now hosting my photos from my Google account. Post up if you can’t see them. Older photos hosted on Photobucket or Flickr may disappear (PM me if you want access to them).
gords1001
gords1001's picture
Quote:
Absolute 100 % agreement. There’s no excuse for that…
At the 13th, it’ll be 34 days, which would be slow but acceptable, at the 30th it’ll be 51 days, obviously, not acceptable. Thing is, ok I only paid a pound shipping, but I’ve had free shipping on cheaper lights that arrived in less than a week (i kind of hoped they would take 30 days, but toni was understanding…) I also have a keygos m10 charger and cells, ordered about the same time which still have not arrived. They were ordered from cybeeport888 so I’m kind of suprised they are not here yet as they are usually damm fast and charged $12.odd shipping (no tracking either, hmmm).
Anyway sorry for the thread hi-jack, just needed a moan. :bigsmile:
Tecmo
Tecmo's picture
They’re sending my AAA holder. Speaking of o rings mine didn’t even come with one on the tail.
