Same crap just happend to me too. This guy is a joke. I swear he looked around at the other listings and realized how much cheaper he was selling it for and decided to cancel all the orders.
I bought 2 Yezl protected 16340’s to use in the Mini-01. They are about 3-4mm longer than a primary or LifeP04, so its a bit harder to screw the light back together because of the tension on the spring, but they fit. Width isn’t a problem. The Yezl cells are a little wider than a primary/LifeP04, but still fit fine.
I can post an ebay link if that’s ok on this forum?
Here’s a couple of outdoor beamshots. They aren’t great, and only close range, but you can get the idea of the flood by comparing the light on the fence panels in each shot.
I’d also be interested in trying to modify one of these, but wouldn’t know where to start.
I’d like to put a U2 XM-L into one, and get rid of the strobe if possible.
I purchased again from a differnt seller. This time its $15.50 coming from china instead of hongkong.
What are the exact measurements? The manifont pictures show 63.8mmx17.36mm. All the ebay listings say slightly bigger. Is it bigger or smaller than an ipt eos a1?
