P60 Copper Wrapping Measurements
40 posts / 0 new
Lothar
Lothar's picture
Greetings all.
After reading a lot of threads about wrapping P60 drop-ins with aluminum/copper foil, copper tape, soda can strips or copper sheet strips, I decided to purchase a sheet of 3mil copper sheet from Ebay and do some wrapping of my own. I also decided to measure the difference in temperatures to see what all the hype is about.
The ingredients:
- Solarforce L2P
- XM-L T6 drop-in with 3.5A (10x7135) 105c Nanjg driver
- 2 x fully charged Trustfire Flames 2400mah
- Pure copper sheet 3mil thick
- Digital thermometer
Unwrapped Measurements:
- Solarforce L2P with normal unwrapped drop-in
- Trustfire Flame battery measuring 4.16v
The resting temperature of the light was 24.9'C:
I left the light running on High (3.5A) for 20 minutes and took measurements every minute for the first 10 minutes, and then at 12, 15 and 20 minutes.
After the 20 minutes the battery measured 3.88v
Wrapped Measurements:
I took the whole light apart and left it for an hour to cool down to 24.9'C again while I wrapped the drop-in with the copper sheet.
I used a fresh Trustfire Flame which measured 4.15v
About 6" of copper sheet and the drop-in fits really snug in the L2P host:
Breaking the 50'C barrier Surprised
After 20 minutes the light was so warm, I had to go get oven gloves to pick it up and take it apart so that it could cool down. The battery measured 3.92v
Results:
And here are the results:
I think it is fair to say that the copper sheet acts as a very good heat transfer medium from the LED to the P60 Host. Laughing
Thanx for watching. Any inputs/comments welcome! Cool
EDIT: Fixed Pictures. See the following threads for good results too: http://budgetlightforum.com/node/27340 and http://budgetlightforum.com/node/27567
Current Collection:
BLF: BLF-GT90, BLF-GT70 (CW Sliced), BLF GTmini, BLF-LT1;
BTU: Shocker (3 x SST-40 @ 8A)
Solarforce: L2P (XM-L2 U3 @ 4A), MPP-1 (XP-L HI @ 6A), MPP-3 (3 x XM-L2 U2 @ 12A), M6 (Nichia 319A @ 6A), M8 (XHP-50.2 @ 9A), 9x (9 x XM-L2 U2 @ 2A)
Coming Soon: Lumintop: BLF-GT4;
Edited by: Lothar on 01/27/2014 - 04:34
BetweenRides
BetweenRides's picture
Last seen: 3 years 11 months ago
Very nice! First time I have seen it documented like that. I have the exact same light (had it a week) and my unscientific method mirrors yours, sans the actual temperature measurements. I did 10-12 minutes instead of 20. Noticeable difference in holding comfort between wrapped/unwrapped. I also noticed my Black L2P gets much, much hotter than the identically wrapped grey L2.
gearjunkie
Last seen: 4 years 2 months ago
Looking at the graphs, the temperatures are still rising after 20 mins on both.  I wonder at what temperature will each flashlight finally stabilize.
xed888
Last seen: 1 year 4 months ago
Question is: is a 4C difference a lot? Sorry for sounding ignorant but unless it results in a massive drop of lumens, is there a point in doing this?
FlashPilot
FlashPilot's picture
Last seen: 10 min 59 sec ago
Ive noted the temperature differences by touch after copper-wrapping my P60's. Its nice to see some empirical data to back it up. Good job Lothar!
Chicago X
Chicago X's picture
Last seen: 9 years 1 week ago
The only temps that have a direct effect on lumen output are those at the junction, and those of the cell.
Temp increase at the junction will cause lumen drop, temp increase of the cell will increase cell efficiency a bit, until permanent damage occurs.
With the ano working as a thermal barrier, numbers would be different on a bare host.
Great test, thanks for sharing.
http://wardogsmakingithome.org/index.html
War Dogs, Making it Home - Rescue Dogs for Returning Vets
PCC
Last seen: 7 years 11 months ago
The idea is to draw the heat away from the drop-in.  By drawing the heat out and into the host you are assisting with keeping the light running cooler.  In this test the light was placed on a table, probably without any air circulation to assist with cooling. In real world use the light would be in the user's hand and the hand would work as part of the cooling system once the outside temperature of the light exceeds the person's core body temperature.  In this case, the better thermal path would allow more heat to be drawn out from the system into the holder's hand and into theatmosphere and the light, as a whole, would run better because of it.
Lothar
Lothar's picture
In short I don't think it's going to make a huge difference, but it is going to make some difference. It's exactly like adding an aftermarket air filter to a car, swopping your flashlight's lens out for a UCL lens, redoing solder points, and all the other things we do in this hobby. If a flashlight is just a light to you/a person, then wrapping the drop-in is going to be pointless, because an XML T6 is already more than what you need, but if you/a person are a flashlight enthusiast seeking to optimize and get the most efficiency out of the LED and battery, then it makes sense to copper wrapping the drop-in.
A more thorough test would have been to measure the drop-in and LED temperature directly. But any extra heat that the copper wrapping can draw away from LED will mean more lumens, even if its only 10 more Laughing
And another point, the wrapped host only used 0.23v (4.15 - 3.92) in 20mins, whereas the unwrapped host used 0.28v (4.16 - 3.88), which means that because the wrapped host dissipates heat better, the LED can operate more efficiently. Again, it is a small difference, but it's 17.8% ((0.28 - 0.23)/0.28*100) more efficient.
Current Collection:
Vectrex
Vectrex's picture
Last seen: 3 months 6 days ago
Yes it is, just compare the die area / dropin surface with the surface of the host. 4C difference at the host can translate to multiple times that at the dropin/die.
MagPap
Last seen: 2 years 10 months ago
The copper sheet you used had any adhesive?
Could you give a link, please?
Lothar
Lothar's picture
There is no adhesive.
Here is the link: http://www.ebay.com/itm/COPPER-Sheet-Metal-Tooling-Foil-6-x9-x-003-40gau...
You start by cutting a 0.5-0.75" x 6" strip. Then you just start wrapping the copper sheet tight around the drop-in. When you're finished, keep it in place with one hand, and try to force it into the P60 host while turning the drop-in in the opposite direction as which you wrapped the strip. If it doesn't want to go in, trim 0.1-0.25" from the 6", and again try to force it in the P60 host. Repeat until it fits Laughing
Current Collection:
janko.hrasko
janko.hrasko's picture
you should do a test with a luxmeter and white room (bathroom test) to see how much light will you lose with can stripes versus copper sheets
MagPap
Many thanks.
They only ship to USA. Time to look a little bit more in ebay!!
BetweenRides
Thanks, Lothar - puts it in perspective. I was confused a week or so ago with a thread saying that wrapping doesn't make much difference, and now I see why it does, particularly if you use the light for extended periods, which I do. When I owned my Mustang LX 5.0 Pocket Rocket, I would do lots of little things to boost HP or handling, often by 1-5%. They do add up.
Funny, the ebay link to the copper foil is the same stuff they sell at Hobby Lobby for $9.99 a roll, but the roll is 12" x 30". Probably a lifetime supply for me.
bose301s
bose301s's picture
Last seen: 1 year 1 month ago
Bringing this back from the dead, how for down the spring or up the reflector did the foil go? Any pictures to it wrapped before you put it into the light. Just got my first P60 and drop in and like it but want to make it even better.
killmenow
Last seen: 7 years 7 months ago
Based on the other posts, the foil likely starts at the end of the taper, and goes down roughly .5 – .75” from that point.
NightCrawl
Last seen: 6 years 3 months ago
You might want to take a look at the video in this post:
http://www.taschenlampen-forum.de/modding/14006-drop-modd-video.html
BetweenRides
bose, I hope this picture helps to illustrate:
This is my L2 with an unknown drop-in gifted to me by mitro. The 40 guage copper strip is 18-20mm wide, cut from a roll I got from Hobby Lobby. As you can see from the photo, this width covers from just over the reflector curve down to slightly over the spring. The actual flat spot on the drop-in is about 16mm. Doesn't really matter because the actual contact area (the dark strip in the center on the drop-in) with the host is about 12mm. After much trial and error, I settled on the 18-20mm width as narrower widths tend to slip when pushing the drop-in into the host. I used the Ceramique as a kind of glue to hold everything in place. It's very thick and sticky, so only a small dab is required, plus it is after all thermal paste, so it should help or at least not hurt heat conduction of the copper.
Start with a few small dabs to hold the strip in place on the drop-in, then start tightly wrapping it around. I put another dab of ceramique in there about every two wraps. With 40 guage, 6-7 full wraps will be adequate, but the exact cut out is different for every light and takes some trial an error to get right. After finish the wrapping, I'll continue to twist it in the direction of the wrap until it is completely flat and very tight. Then peal back the last 1" or so, spread a thin layer of ceramique on it to hold it in place. Then twist again until it stays flat and in place. Be careful not to get the paste near the edges, as it will spread out and get everywhere.
When you push it down into the host it should be a verrry tight fit to assure contact and thermal conduction. Use a screwing motion, going in the direction of the wrap so it stays tight and in place. The wrapping above is nice and snug. The wrapping on my L2P is so perfect it takes all my strength to remove it from the host.
Hope this helps. Expect to have to wrap/re-wrap and cut the strip until you get the best fit.
E1320
E1320's picture
Awesome work thanks for sharing.
I am already visualizing the duct tape over your mouth.
bose301s
bose301s's picture
I am looking to wrap your drop in so that I can get the best heat transfer and use it on Turbo for extended periods, lol.
sixfink
Last seen: 3 years 2 months ago
The P60 drop-in is faulty by design, as far as heat transferral is concerned. Crikey, all those bloody drop-ins are designed very poorly!
Have you ever taken apart one of those? No offense, as I do know a lot of you probably have. That brass pill which screws into the aluminium reflector, well, to be honest – I couldn’t think of a design more flimsily. Subsequently, I’d add as much copper to the pill as only possible; press-fit, then add a thin line of solder, just to make sure.
Next comes the design itself: Heat, for that matter, is mostly drawn off by the wrapped aluminium reflector to the head of the torch. Which, in turn, is not the part where the heat actually builds up – that would be the junction point between the emitter star and the pill, or more comprehensively, the pill by itself.
Now, you’d still have to overcome that terribly bad barrier of threads between the pill and the reflector, to effectively draw off the excess heat.
Think about that, sometime. Standard LED P60s are awful to heatsink properly.
Oh, just to add one more thought – a thought, really, an idea, nothing proven by myself, so don’t club me to death if I should be wrong:
Copper is only as good as the alloy it will come as. Meaning: Pure (chemically pure!) copper = excellent, use it if you can get your hands on it!; industrial-grade-copper (a.k.a. “what-the-machine-shops-with-all-their-fancy-CNC-lathes-usually-have-piled-as-bar-stock”) = save your effort and take your commercially available aluminium bar stock, as it can be machined much more easily, and transfers heat at the same rate as a generic copper alloy.
please take this into consideration as well.
Oh, on a side note: Of course!!! I do use copper with a pill rather than aluminium – just for the sole factor that soldering copper to brass is SOO incredibly easy, compared to soldering aluminium to brass.
FWIW,
Simon
p.s.:
your best bet would be a conically shaped liner bushing, and both the pill and reflector re-worked on a lathe to match that conical shape of the bushing, then hand-lap, then press-fit everything together. Sounds like a lot of work? It surely is, at least for me. Angles of any kind I have always found terrible, be it on 3ds max, AutoCAD, Nemetschek Allplan CAD and even by hand.
scaru
scaru's picture
Last seen: 5 years 6 months ago
As I understand it if you specify c101 when ordering a part at a machine shop then it will be made of 99.9% pure copper.
sixfink
scaru, I’m looking for a source myself. Things aren’t as easy in continental Europe as they are in the US, or in the UK.
May not even legally hunt down mice on my attic or in the garden with an air rifle over here.
scaru
scaru's picture
I'm pretty sure this company ships to europe.
sixfink
oh my, intl’ shipping – I’d be horray about it, if the suspension parts for my 1967 Mercury hadn’t cost so much already!
ta, bookmarked for next month! Smile
edc
edc's picture
Last seen: 6 years 8 months ago
I wonder what is the point in wrapping the reflector with foil. I tend to wrap the bottom 5 mm of the reflector and the base of the pill but the spring gets in the way. Sometimes I remove the spring as it doesn’t serve any purpose as far as I can tell.
http://i1193.photobucket.com/albums
Lothar
Lothar's picture
Yeah, thanx for sharing BetweenRides!
Current Collection:
attitude
attitude's picture
Last seen: 4 years 10 months ago
the larger spring tightens the reflector to the pill i am pretty sure if u take it out and play with it Smile
weird i just get addicted to flashlight like in a blink of an eye.
budynabuick
budynabuick's picture
Last seen: 9 years 9 months ago
I also got 50c with aluminum foil. I got about 43c with no Aluminum foil showing the foil does indeed help a good bit. Don’t see any benefit using copper. Also, I didn’t see your temp with no foil?
Keith
lensmanmark
budynabuick wrote:
I also got 50c with aluminum foil. I got about 43c with no Aluminum foil showing the foil does indeed help a good bit. Don't see any benefit using copper. Also, I didn't see your temp with no foil? Keith
Ha! Great idea! How many wrappings did you have to do with aluminum? Wikipedia says that standard aluminum foil is 0.6 mils thick and heavy-duty is 0.9 mils thick so you'd have to wrap 3x-6x times the 3 mil thick copper. Also, the aluminum might be too thin and rip as you tried to force it into the body. Did you have this problem?
BTW, the OP lists the full temperature rise of both unjacketed and copper-jacketed versions in the graph. It looks like 44C 46C to me.
texas shooter
Last seen: 57 min 1 sec ago
I’ve been using 24 ounce Monster cans as they are about twice as thick, often needing only 3 layers or less to get a tight fit. Also being stiffer due to thickness the pills outer spring dosen’t get in the way and can be left on.
