Review: Trustfire Mini-01
Will do :slight_smile: . Unfortunately it’s only just gone 5pm here, so it wont be dark enough until about 11pm .
Edit: Oops, i thought you were referring to taking a beamshot. I’ll have to read more carefully next time.
Here’s the link to the Yezl 16340’s http://www.ebay.co.uk/itm/290739416253?ssPageName=STRK:MEWNX:IT&\_trksid=p3984.m1439.l2649#ht_3397wt_1154
np :slight_smile: Thanks for the link
Here’s a couple of outdoor beamshots. They aren’t great, and only close range, but you can get the idea of the flood by comparing the light on the fence panels in each shot.
Mini-01 on high with Yezl 16340
P60 - 2.8A triple XP-E on high
Nice beamshots MattSPL. This is going to be my new EDC when it arrives.
Thanks :slight_smile:
Yep, very handy little pocket rocket.
I thought I had bought one too.
Seller is just messing with us.Give him a bad feedback?
Lennart
Hi, I bought one and it is a tiny monster!
If a driver repacement is needed, which do you suggest?
Very impressive, thanks! :slight_smile:
No problem :slight_smile:
I’d also be interested in trying to modify one of these, but wouldn’t know where to start.
I’d like to put a U2 XM-L into one, and get rid of the strobe if possible.
I purchased again from a differnt seller. This time its $15.50 coming from china instead of hongkong.
What are the exact measurements? The manifont pictures show 63.8mmx17.36mm. All the ebay listings say slightly bigger. Is it bigger or smaller than an ipt eos a1?
Guess I am in a bad mood.Thanks for the update.Will try again tomorrow.
Lennart
I just measured my Mini-01 and those manifont measurements are correct. If you ground off the key chain attachment, the light is about 59.5mm in length.
How about that diameter of 17.36? My eos a1 measures 20.4 and a primary rayovac is 16.54mm. It would seem 17.36 would make it imposibly thin.
Sorry, i forgot about the width. The head seems to be the widest point at 19.5mm.
Got mine today and ran it on high with a run-of-the-mill unprotected LiCo 16340. It ran for about 9 minutes, reaching over 186 deg F before I stopped it. The temperature had nearly topped out because it was rising about 0.1 deg every 15-20s at that point. Not sure if it ran out of battery, or had reached thermal equilibrium. My guess is the former. There was a distinct burning electronics smell but otherwise no adverse affects.
Nice natural/cool white. Considerably warmer than the typical “cool” china lights.
Inside: Driver is glued to small aluminum “pill” carrier with the star glued with (assumed) heatsink epoxy to the other side. The solid cast aluminum reflector screws onto that, and that’s pretty much all the heat sink there is. I would suggest removal of the pill/reflector assembly (unscrew with needle-nose) and put Ceramique or Arctic Silver on the threads between reflector slug and pill carrier, as well as between pill and stainless steel body.
Thumbnail (Large Picture )
Low has a low refresh rate but flicker is only really noticeable when you wave the light around quickly. Strobe is not so fast as to think you’re at a rave, but fast enough to draw attention if you were using it as a safety beacon.
Nice little light.
Wow.
That’s a bit toasty.
Can you use a 3.7v battery for this light?
I ordered one but I do have the grey protected Ultrafire 16340’s…
High temps are typical for SS lights. The material cools poorly.
I’m using 3.7v protected cells. The light is much brighter, and gets hot faster though.
