Here’s a couple of outdoor beamshots. They aren’t great, and only close range, but you can get the idea of the flood by comparing the light on the fence panels in each shot.
I’d also be interested in trying to modify one of these, but wouldn’t know where to start.
I’d like to put a U2 XM-L into one, and get rid of the strobe if possible.
I purchased again from a differnt seller. This time its $15.50 coming from china instead of hongkong.
What are the exact measurements? The manifont pictures show 63.8mmx17.36mm. All the ebay listings say slightly bigger. Is it bigger or smaller than an ipt eos a1?
I just measured my Mini-01 and those manifont measurements are correct. If you ground off the key chain attachment, the light is about 59.5mm in length.
Got mine today and ran it on high with a run-of-the-mill unprotected LiCo 16340. It ran for about 9 minutes, reaching over 186 deg F before I stopped it. The temperature had nearly topped out because it was rising about 0.1 deg every 15-20s at that point. Not sure if it ran out of battery, or had reached thermal equilibrium. My guess is the former. There was a distinct burning electronics smell but otherwise no adverse affects.
Nice natural/cool white. Considerably warmer than the typical “cool” china lights.
Inside: Driver is glued to small aluminum “pill” carrier with the star glued with (assumed) heatsink epoxy to the other side. The solid cast aluminum reflector screws onto that, and that’s pretty much all the heat sink there is. I would suggest removal of the pill/reflector assembly (unscrew with needle-nose) and put Ceramique or Arctic Silver on the threads between reflector slug and pill carrier, as well as between pill and stainless steel body.
Low has a low refresh rate but flicker is only really noticeable when you wave the light around quickly. Strobe is not so fast as to think you’re at a rave, but fast enough to draw attention if you were using it as a safety beacon.
