I just measured my Mini-01 and those manifont measurements are correct. If you ground off the key chain attachment, the light is about 59.5mm in length.
Got mine today and ran it on high with a run-of-the-mill unprotected LiCo 16340. It ran for about 9 minutes, reaching over 186 deg F before I stopped it. The temperature had nearly topped out because it was rising about 0.1 deg every 15-20s at that point. Not sure if it ran out of battery, or had reached thermal equilibrium. My guess is the former. There was a distinct burning electronics smell but otherwise no adverse affects.
Nice natural/cool white. Considerably warmer than the typical “cool” china lights.
Inside: Driver is glued to small aluminum “pill” carrier with the star glued with (assumed) heatsink epoxy to the other side. The solid cast aluminum reflector screws onto that, and that’s pretty much all the heat sink there is. I would suggest removal of the pill/reflector assembly (unscrew with needle-nose) and put Ceramique or Arctic Silver on the threads between reflector slug and pill carrier, as well as between pill and stainless steel body.
Low has a low refresh rate but flicker is only really noticeable when you wave the light around quickly. Strobe is not so fast as to think you’re at a rave, but fast enough to draw attention if you were using it as a safety beacon.
$13.55 + .85 shipping. Just ordered mine because, well… I just couldn’t help it. Anyone try 18350s in one of these yet? I already have a pair of TF Flame 16340s. Just figured a longer run-time might be nice, unless the little beast ends up having dangerous heat issues.
I was in the same boat as you. I just had to buy this little guy as well. Regarding the heat buildup, a good quality thermal paste along with thermal rings on the outside. Perhaps using two or three perfectly fit washers (nothing too big) wrapped around the top part where the pill is and set permanently might do the trick. Just a thought for now.
If a battery is shipped without proper packaging, meaning the positive and negative are not fully protected, customs can send the package back to it’s sender.
Mine came in a clam shell plastic blister pack, with the battery separate from the light, so not much chance of a short, but then again, not exactly “properly” packed in the eyes of officious customs people.
