its twisty one…like the original…
Got mine today. Gorgeous light and Damb good clone. Top quality brass pill and on high gets warm at about 10 minutes. I ran on high for 2 hours and got pretty warm, but the led held. Gorgeous low artifact huge flood, beam is perfect square at 150 yards. It is a thrower !
Quality is awesome and greased orings. Worth every cent. Took almost 2 weeks from Manafont.
Thanks for the info!
Have you complete dissasembled the light? any photos of the internal parts?
TX!
or glass???
has it any packing? or just white box as even?
Came wrapped in red bubble pack and white box in a large bubble pack envelope. Lens is plastic, but perfect no artifacts it looks like glass, It’s a nice light for the $$$ … No pics yet …. Well made light, the pill that screws into the body is brass and Damb well built compared to my other Uniquefire lights……
I am begging you Manny - post some pictures!
I dont care if they are shaken or taken by cell phone or whatever. I am SOOO curious about this light!
Here ya go, Manny:
Thanks man !!! Not easy from the evo…. And learning !!!
No problem!
WOW!.
I never had seen a star with that “shape”
….and am only getting 1 amp on high from a fresh Callie’s 3100mah. I was thinking of a driver swap. Raccoon, did you measure your current and how did you get the frickin’ thing apart?
Actually those are Manny's pictures. He was having trouble posting with an evo, which is some sort of smartphone. I just made it so his pictures would show up nice on BLF.
Manny how did you get the head off? I ask here instead of a PM for anyone else who is struggling with it.
On the front face around the reflector you see a small thin bezel with (4) creased spots where I stuck a small screw driver ” as per Dr’s order ” and simply forced counter clockwise with pressure until release. It has a big fat rubber gasket which creates great resistance behind the reflector for water tightness, torch is well made and on square tight beam bright, I wish it had more modes…… Hi… Lo… and Strobe Is available.
Anyone want to provide beam shots, most importantly focused for throw? 8)
Thanks Manny!
Beam pattern looks pretty clean at 100 feet.
I just might pick one of these up regardless of whether I replace the driver or not.
I just sent mine to E1320 to have 5 modes gettin rid of strobe adding 1lumen hi mid low and turbo at 3.5 amps ….It’s a nice torch ….
