NEW Super Nice Flashlight release:
F22—Desert Yellow ; HaIII Black
http://www.cnqualitygoods.com/goods.php?id=1695
Price : 49usd not including shipping
SPECIFICATION:
Model: F22
LED: *CREE XM-L U2 1A/3C
*Material:6061-T6 Aluminum
Reflector:Aluminum Alloy Mill reflector
Battery:1×26650/18650 battery (not include)
Switch: Press switch one the side
Mode: Stepless brightness from 10lumen to 1000luems; double click press switch in Hidden Strobe-flash-SOS when the flashlight is lighting.
Current: 50mA~3000mA
Output:1000 Lumens
Driver:LD-33
Waterproof:IPX8
Anodise:Black HAIII / desert yellow HII
Weight:150g
Size:159mm(Length)*49mm(Head diameter)*32.7mm(Body diameter)
Runtime at 3000mAh mode:
Powered by 1×4000mAh King Kong 26650, it last 108 minutes on max brightness; 2xKing kong 26650, Runtime is 208 minutes; Full current regulation
Powered by 1x sanyo 2800mAh unprotected 18650, it lasts 75 minutes; Powered by 2×18650, Runtime is 150 minutes.
Full current Regulation.
*User Interface:
1. Press side button, turn on the light.
2. Hold the button till the light flicker once, the mode goes to Stepless brightness. Press and hold the button; Current will step down from 3000mA to 50mAh.
When it goes to low brightness, Hold the button till the light flicker once,Press and hold the button; Current and brightness will rise up from 50mA to 3000mAh.
3. Click the button twice when the torch is on, UI goes to 3-mode(hidden). Strobe>Alarming flash>SOS
User interface is quite interesting.
Beamshot will get ready soon.
It’s a really nice compact 26650 flashlight, we highly recommend it.
Thanks
RIC
