Ric - beautiful lights! Can you explain a little more how the two switches work?
Hi Ric,
Another really beautiful light!
One question, can you tell me if there will be any battery fitment issues, whether using 18650 or 26650 as there was with the Roche F12 and F8? If I purchased it, I’d likely be using a Trustfire TR 26650 5000 mAh or a Redilast 18650 3100 mAh. Thanks.
Shhhh. My wife might be looking….
sexy
The description says tail switch, but it sure looks like a side clicky.
Do you click the side switch once to turn it on and then press and hold to ramp the brightness up then down?
Hey, that last picture on the site (see link in the OP) looks like it has an extension tube for 2 x 26650 or maybe even 3 x “C” cell would fit? Does it come with the extra tube, Ric? Ahhhh, I just saw…$5 extra for the extension tube. I measured some batteries and I bet it would work with 3 x “C” cells.
I really need to stop visiting this damn site! I would be all over this, but I’d like to see the guts. I would love to mod this like I did the UF-T50.
EDIT: Duh, I should probably click the link and look at all of the pictures. This looks like a modder’s dream! Threaded in side switch and driver, I’m going to have to order this!
I just noticed the updated JM07 with side switch as well, awesome!
Sorry for the misleading ,It’s a typo. This torch only has one side switch.
Ric
It comes with Side switch. It’s our typo. Only Upgrade JM07 has 2 switchs now.
UI is like this:
1. Press side button, turn on the light.
2. Hold the button till the light flicker once, the mode goes to Stepless brightness. Press and hold the button; Current will step down from 3000mA to 50mAh.
When it goes to low brightness, Hold the button till the light flicker once,Press and hold the button; Current and brightness will rise up from 50mA to 3000mAh.
3. Click the button twice when the torch is on, UI goes to 3-mode(hidden). Strobe>Alarming flash>SOS
User interface is quite interesting.
Ric
Powered by 1× King Kong 26650 4000mAh, it lasts 108 minutes on max brightness; 2xKing kong 26650, Runtime is 208 minutes; Full current regulation
Powered by 1x sanyo 2800mAh unprotected 18650, it lasts 75 minutes; Powered by 2×18650, Runtime is 150 minutes.
Full current Regulation.
Ric
I will not buy anymore flashlights, I wil not buy anymore flashlights, I will not buy anymore flashlights……….
This one is not helping tbh, if it could run on c cells as ol postulates, it’d make a great gift for a none li-ion user.
Wow, side switch and powered by 1x26650 or 2x26650. This is going to be my next purchase for sure.
Wow! Very nice! What kind of beam pattern are we expecting? Flooder? thrower? Good mix? Little pricey, but seems worth it if it's as good as it looks!
-Garry
What really sucks about this light is the NW option. It basically means that I’m going to have to purchase one.
I mean really, it’s not very fair to make a light that is as appealing as this one. I could probably have resisted if it was CW only.
In the bottom picture where it shows the extender the tan one has a flat bezel… is that an option as well?
Good question. I’d prefer the non-crenelated bezel too.
Hi Cainn, I’m sure it must be an option. IOS is selling them too and actually shows the bezel as an option. I think I’d opt for the non-crenelated bezel myself.
If it was slightly cheaper, it would be a killer bargain.
I already messaged Ric: He said they stock the assault bezel, but you can request the other.
Hope this helps.
Ric responded quickly.
Hi Ric,
Does It has memory mode?
I mean when I set brightness to 50% and then take out battery, That brightness will be 50% or anything?
I don’t like Ultrafie UF-T50, It has no memory mode. When I take out battery . It will start at High mode.
Thanks.
