I just noticed the updated JM07 with side switch as well, awesome!
Sorry for the misleading ,It’s a typo. This torch only has one side switch.
Ric
It comes with Side switch. It’s our typo. Only Upgrade JM07 has 2 switchs now.
UI is like this:
1. Press side button, turn on the light.
2. Hold the button till the light flicker once, the mode goes to Stepless brightness. Press and hold the button; Current will step down from 3000mA to 50mAh.
When it goes to low brightness, Hold the button till the light flicker once,Press and hold the button; Current and brightness will rise up from 50mA to 3000mAh.
3. Click the button twice when the torch is on, UI goes to 3-mode(hidden). Strobe>Alarming flash>SOS
User interface is quite interesting.
Ric
Powered by 1× King Kong 26650 4000mAh, it lasts 108 minutes on max brightness; 2xKing kong 26650, Runtime is 208 minutes; Full current regulation
Powered by 1x sanyo 2800mAh unprotected 18650, it lasts 75 minutes; Powered by 2×18650, Runtime is 150 minutes.
Full current Regulation.
Ric
I will not buy anymore flashlights, I wil not buy anymore flashlights, I will not buy anymore flashlights……….
This one is not helping tbh, if it could run on c cells as ol postulates, it’d make a great gift for a none li-ion user.
Wow, side switch and powered by 1x26650 or 2x26650. This is going to be my next purchase for sure.
Wow! Very nice! What kind of beam pattern are we expecting? Flooder? thrower? Good mix? Little pricey, but seems worth it if it's as good as it looks!
-Garry
What really sucks about this light is the NW option. It basically means that I’m going to have to purchase one.
I mean really, it’s not very fair to make a light that is as appealing as this one. I could probably have resisted if it was CW only.
In the bottom picture where it shows the extender the tan one has a flat bezel… is that an option as well?
Good question. I’d prefer the non-crenelated bezel too.
Hi Cainn, I’m sure it must be an option. IOS is selling them too and actually shows the bezel as an option. I think I’d opt for the non-crenelated bezel myself.
If it was slightly cheaper, it would be a killer bargain.
I already messaged Ric: He said they stock the assault bezel, but you can request the other.
Hope this helps.
Ric responded quickly.
Hi Ric,
Does It has memory mode?
I mean when I set brightness to 50% and then take out battery, That brightness will be 50% or anything?
I don’t like Ultrafie UF-T50, It has no memory mode. When I take out battery . It will start at High mode.
Thanks.
Yes, it do has memory. If the brightness is 10, it will memory 10 brightness.
BTW, The CW emitter is U2 1A, we have corrected the typo.
My stuff thought by mistake it was T6 1A, wrong title here.
Beam of this torch is so perfect. Will upload some beamshot tonight.
Ric
Wow I missed this thread. Love this light… maybe someday when I get 26650 batteries….
Although I’m impressed by this torch, I’ve held off on ordering due to a nagging concern. I’ve really come to rely on being able to quickly switch between programmed output levels. I don’t want to have to ramp all the time to get an output level suitable for any given situation. What would make this torch perfect is the ability to program at least 2 (preferably 3) output levels and switch between them. This doesn’t make the ramping feature redundant of course since it would still be useful for fine tuning when the need and/or desire arises.
Or am I missing something?
You don’t need 26650s, as it comes with a 18650 to 26650 battery converter sleeve.
cainn24:
Yeah, I had a ramping light before (nitecore) and it can be a PITA to go up and down depending on the application. But inasmuch as I use my lights exclusively for fun/recreational use, I usually like to show-off and have my lights at full brightness to start anyway. But if one uses it for work or other serious matters I can see how ramping could be a cumbersome, even dangerous delay.
That said, if this thing is near as bright as claimed (1k lumens?) I’m definitely going to get one. Of course, it’ll probably only be half as bright - darn Chinese lumens!
How quickly does this ramp? In other words, roughly how many seconds does it take to ramp all the way from high to low, or vice versa?
