Thank you Matt for the readings… it seems that I have a faulty one.
hmmm…
Anyone else has a mini-01 that draws only 1 Amps in High mode on 16340 ?
hmmm…
Is it possible that the Trustfire flame isn’t capable of delivering any more current, rather than the light being faulty, because your readings are very similar to mine, except for the Yezl cell?
JustFit: MattSPL:Here’s my current draw results for the Mini-01
Trustfire primary - Low 0.08A, High 0.8A
Surefire primary - Low 0.06A, High 0.75A
Ultracell 3.2v LifeP04 - Low 0.1A, High 1A
AW 3.2v LifeP04 - Low 0.13A, High 1.09A
Yezl 3.7v 16340 - Low 0.25A, High 2.4A
This explains the brightness and hand burning heat when using the Yezl cell :bigsmile:
hmmm…Anyone else has a mini-01 that draws only 1 Amps in High mode on 16340 ?
yeah, but don’t forget that trustfire flame is 4.2 fully charged , and I’ve also tested the mini-01 with Hi-Max 18650 cells which deliver a good 5 Amps on my Trustfire TR-J12 …
Yeah not sure to be honest. Have you any other cells to try?
I get
.08 and .85 on the original Trustfire CR123A
.11 and .98 on SOshine RCR-123 protected.
But my cheap DMM leads read low compared with better wire…
I need to make up some better leads.
I get
.11 and .98 on SOshine RCR-123 protected.But my cheap DMM leads read low compared with better wire…
Thanks for testing your Mini-01.
Hopefully some other people can test theirs too.
Nice! Any way of posting some beam shots or perhaps a video?
Thanks man. Unfortunately the only camera I got is the one on my phone… tried last night but it came out too crappy
Nice… got to get me some of that hand burning goodness for these winter nights
Glad I picked up the Yetzl cells…
Now i just need to get hold of an AW IMR 16340. That should be really fun :bigsmile:
Good one. Should be interesting J)
alex21: MattSPL:Here’s my current draw results for the Mini-01
Is the AW IMR better than the Yetzl? By how much?
MattSPL: alex21: MattSPL:Here’s my current draw results for the Mini-01
I don’t know enough about flashlights and batteries to give a definite answer, but this is what i think: I bought the Yezl 16340 because it has the highest tested capacity ive seen, and it is rated to handle upto 3.2A discharge, which, from what i can tell, is very good for a 16340 cell.
The AW IMR 16340 is capable of 4.4A max discharge, but will also have a much lower internal resistance due to design and lack of any protection circuit. This means it will perform better in a light that needs high current delivery, especially a direct drive light like the Mini-01 seems to be.
So in theory, the AW IMR 16340 should make the Mini-01 even brighter. You would just have to take care not to let the IMR discharge below 2.5v(as it has no protection circuit), or it will shorten cell life.
Cheers
Matt
mags: MattSPL: alex21: MattSPL:Here’s my current draw results for the Mini-01
So in theory, the AW IMR 16340 should make the Mini-01 even brighter. You would just have to take care not to let the IMR discharge below 2.5v(as it has no protection circuit), or it will shorten cell life.Cheers
Matt
Thanks Matt
http://www.oveready.com/batteries-chargers/aw-imr-16340-rechargeable-battery/prod_113.html
As soon as mine arrives I will post figures using my TF flames as well as OTF lumens in my IS.
Flames work fine in mine. They’re from DX.
Thanks
Yes, the Trustfire flames 880mAh seem to be a good 16340 also. Torchythebatteryboy tested them as having 658mAh capacity at 1A discharge.
So I heard it last 6-8 minutes on high. How much do i get with these AW & Yezl cells?
I haven’t really done run time testing because it gets too hot on high after a minute. After several bursts in high, it gets easier to leave on for a bit longer as the cell runs out because the light doesn’t get as hot.
I’ve also only ran the yezl down to 3.6v.
Using a primary or LifeP04, the light doesn’t get nearly as hot so can be left on for 5 minutes, maybe more, and I got at least 20 minutes run time, but haven’t tested properly.
EDIT: you will have to be careful if using any unprotected cells as the light can drain them quickly and may over discharge. I accidentally ran a LifeP04 down to 0.8v while testing the Mini-01. It seemed ok though and charged back up again.
