I don’t know enough about flashlights and batteries to give a definite answer, but this is what i think: I bought the Yezl 16340 because it has the highest tested capacity ive seen, and it is rated to handle upto 3.2A discharge, which, from what i can tell, is very good for a 16340 cell.
The AW IMR 16340 is capable of 4.4A max discharge, but will also have a much lower internal resistance due to design and lack of any protection circuit. This means it will perform better in a light that needs high current delivery, especially a direct drive light like the Mini-01 seems to be.
So in theory, the AW IMR 16340 should make the Mini-01 even brighter. You would just have to take care not to let the IMR discharge below 2.5v(as it has no protection circuit), or it will shorten cell life.
I haven’t really done run time testing because it gets too hot on high after a minute. After several bursts in high, it gets easier to leave on for a bit longer as the cell runs out because the light doesn’t get as hot.
I’ve also only ran the yezl down to 3.6v.
Using a primary or LifeP04, the light doesn’t get nearly as hot so can be left on for 5 minutes, maybe more, and I got at least 20 minutes run time, but haven’t tested properly.
EDIT: you will have to be careful if using any unprotected cells as the light can drain them quickly and may over discharge. I accidentally ran a LifeP04 down to 0.8v while testing the Mini-01. It seemed ok though and charged back up again.
I didn’t really get to look at the output because of the way i had the head setup(face down) measuring the current. There was serious heat in the head after the little time i spent testing though, and i lifted the edge of the head up slightly to see the output and it was really bright :bigsmile:
I wonder would an IMR 16340 be as bright?
I suppose looking at it realistically, making the Mini-01 any brighter than the Yezl already does will make it too hot to handle in less than a minute or so.
