Umm . . . should I say "You're Welcome" or "I'm sorry", or "Welcome to BLF"??? Now I'm confused!
Anyway, welcome to BLF! You'll enjoy it here, and yes it is addicting! Keep your wallet locked up! Set a budget for lights and accessories and stick to it! Better yet, run away while you can! (Just don't run in the dark, because then you'd need a flashlight to see where you're going and that would bring you back to BLF to research the best light, which would then again lead you to spend too much money . . .)
There is ... NO RECOVERY .... ONLY , more Lumens and better Tailcap readings.
Your absolutely correct, there are SEVERAL Talented individuals (that are willing to share) and they produce some awesome reviews, comments and Terrific photos.
From your sig-line ---- What part of Illinois are you from?
Illinois has MORE Governors in JAIL than in retirement homes.
Welcome to BLF, Brasco. You didn’t say, “Thanks for the laughs”, so I’ll assume you are here just for the technical aspects of the forum and not the sophomoric comedy. Too bad, really, because I’m only marginally proficient at one (and most would argue that is an overreach).
On the other hand, your “location” seems to suggest that you do, indeed, have a sense of humor.
Either way, I’m sure we all look forward to interacting with you.
