http://www.meritline.com/1000-lumen-cree-xm-l-t6-led-flashlight-torch---p-82258.aspx
All Cities (I think?)
I fixed original post - added url and additional saving coupon for those that are interested.
Enjoy - Triple A
Enjoy - Triple A
My Ultrafire C8 just lost the driver or LED. For $9 I might as well just buy this and have a new light. I can keep the old C8 for spare parts assuming everything will swap out like tail cap and lens etc.
I just signed up and created an account to buy one and they are out of stock now!
Speedsix,
I think that coupon code gives 30% off any T6 flashlight at Meritline. I bought two flashlights this morning @ 30% off each.
……From Meritline’s daily deals:
Cree Flashlights 30% Off
Price Start From: $8.39
After Coupon
Coupon Code: MLC810WN
Linky link: http://www.meritline.com/newsearch.aspx?SearchTerm=cree+t6+flashlight
I bought these two:
http://www.meritline.com/compact-aluminum-cree-q5-led-flashlight-hand-torch-black-color—-p-69325.aspx
http://www.meritline.com/cree-zoom-xm-l-t6-led-flashlight-torch-light-lamp—-p-82259.aspx
Cheers!
M—
Trigger almost pulled :bigsmile:
Anyone had problems with them? First time buyer.
UPDATE: nah, wanted one, bought one :cash: Any problems —> PP claim :bigsmile: Thanks for the coupon!!!
BTW, it’s a special promo coupon. Had to agreed that I will receive email promotions, deals, etc.
Thats a good price! I could not resist and ordered one.
And theirs has mode memory, it says!
Rusty, all specs are almost the same, so I wouldn’t trust what they say
I bought that “HD2010” because of the pics :bigsmile: For that price - I’ll take the risk (but… keep my fingers crossed just in case :bigsmile: )
coupon MLC810WN doesnt work any longer? ;)
Those who ordered from them before, please, can you tell me if they update item status online or not? Ordered 5 days ago and still nothing (Step 2 of 4: Pending Payment - We have not yet received fund to release your order for shipment.)
Yes, they do. I got an email, that my flashlight is sent out and this is also online available.
:bigsmile:
Wanting the new XP-G2 for SolarForce 2Lm.
Where to purchase?
Thanks.
a few months back asked what would be new in
2 years and Wow It looks like something is here
already, the XP-G2.
Also received an email today informing me that it is out of stock and will be delivered most probably on 08.17 when they will restock. My order was placed on 08.10 and I manged to use the coupon.
I ordered on 8/10/12 also and mine is showing pending payment in the order status
Welcome aboard, Aldrevopa!
Is this flashlight really 1000 lumen?
@f42: It pretty much depends how well it is driven. If it is somewhere near 3A, 1000 lumen are possible (at least OTF), but probably it is more like 600 lumen.
I ordered it on the 12th of August, and so far I didn’t recieve any notification.
Take a look at your spam. My email notification ends there.
Okay I got mine today. THANKS to BLF, I always check mine over especially to make sure everything is okay, and in this case, it was NOT okay. The star foolishly is held in place by pressure from the reflector. The pill cannot be screwed down all the way or the reflector does not press the star against the pill. I know it sounds weird but you’ll see what I mean when you get yours. My pill was screwed in all the way, so the reflector was NOT pushing the star down so it was floating without touching the pill. So if you turned this on without fixing the floating star, I would imagine (as I have done in the past) you would see some smoke and by the time you figured out what it was, the emitter would toast.
Fix is pretty easy. Just pull the pill. They used like a 1mm drop of thermal grease (NOT thermal adhesive/plaster) so the star pulls away from the pill spontaneously without the needed reflector pressure . Wipe the grease off. (This is what I did anyway. Maybe someone else has a better idea.) Added a small glop of fujik. (Probably have to pop the driver to get the pill out enough to really do a good job with the plaster.)
Put the pill back in, but don’t screw it down all the way. Maybe two turns up on mine. Put delrin spacer on top of star. Reinstall the reflector so that it pushes down on the star and holds it in place. I assume I can screw the pill all the way in once the fujik dries? Will it hold a balky star by itself? I’m afraid that the reflector might melt or deform from the star heat.
Mine’s all fixed now. Takes a while to get warm, but it does eventually. Looks pretty bright but I need to wait until dark. Sorta like a C8?
Anyway, don’t turn the light on before you fix that loose star, or I would think the emitter will toast and you’ll have a nifty host instead of a flashlight.
Hope this helps.
As I said, I may have done something wrong here. This is just the way I fixed it. There may be better ways. I’m only a few months new to all this flashlight stuff.
