It is described on DX as 5A SST50 driver. Only thing you have to do later is to cut circular isolator between driver and battery that only spring is out, not whole driver. It shines better with this driver, it was even better with 3xml kai driver, but it overheated quickly
The STL’s are more or less identical and they’re 50% brighter than the T13 (so 22% more throw). They also have the 3 or 5 mode selection and good (immediate) memory but the T13 is obviously a good value proposition at half the price.
But how did you did it.
I didnt manage to pull out the stock driver without damaging it.
Its larger than the “hole” on the back of the flashlight head…
Yeah I had one SR STL-V2 months ago, and driver stopped working. If I remember correctly I couldnt get to it from the reflector side (obviously threads were glued) And u cant pull the driver from the back of the head, from that side, because aperture is smaller. SO I had to break the driver, there was some retaining spring also, i remembe r correctly.
And now I have that good empty body and dont really know what to do with it. (Maybe, probably, its perfectly doable but just dont see how, to install some replacement driver. Didnt invest much thought into it yet :o )
Well I compared my FandyFire STL-V6 and Small Sun ZY-T13 Tuesday nite for throw. The FandyFire is definately the better thrower. The Small Sun ZY-T13 is definately the better value. Your talking about a light that is almost half of what the FandyFire STL-V6 is, and I will say that for less than $25 shipped, I know of no other XM-L flashlight that will beat it for the price in overall quality, throw, and has a side switch.
My SR-STLV2 in wich driver stopped working and had to be pulled out is really all glued (all head parts, except bezel). So it will be difficult to get it working again.
I can maybe put some smaller driver or board through the front side, but I dont know how Ill fix it??
Also, myfriend insisted that he willlater try (I left it at his place) unscrew it with a help pf the vice. I dont think is wise thing to do, I thing he’ll just damage it…
@keltex
Yes, driver in SkyRay STL-V2 (and FF version?) is wider. I’m not sure if it is 24mm or 26mm.
BTW, Im so frustrated with those drivers, I usually have what I consider almost perfect flashligt, but driver ruins it significantly.
I’ve moded my STL-V2 with dx ST-50 driver (I think I bought it from dx, months ago, and its old version of this driver, sandwich version.
And, whats the downside?? Well, memory is catching really slow, 8-10 sseconds. Really bad.
Old, stock driver memory would caught after 2,5 seconds, somethng like that. And this one 10 seconds :o eek
I have really bright thrower now, but this thing with driver is really annoying.
ALl that brought me to wonder: is it possible to mod it???
On some other topics, I thin about some zoomies, I’ve read how people messed up with some capacitors orsuch, to shorten or prolong time for memory to kick in.
If I ruin, for example, some capacitor on the driver, in theory, will I accomplish “alwasy on high”, or “always neyt mode”??
I would like to have it always on high, or at least shorter time for memory to kick in.
PS: Also, regarding that memory time: are “on time” required for memory to kick in and “switched off time ” required for memory to kick in always the same?
BTW, this is the driver I modded it width - it fits perfectly (pic from one other topic here)
But as I said, to long time for memory…
Experts, is this fixable??
PS: BTW, with this driver, on mid-mode its significantly brighter hotspot than Small Sun T13 , hehe. Uf, how I wish too have good amalgam of these 2 drivers… :o
I'm no expert but I remember someone having the same problem and to fix it you just need to change a resistor. I just have no clue which ones and how it works. :(
